Question / Help OBS picking up game sound but not streaming/recording it
fskt
Hi, whenever I try to stream or record osu! OBS recognizes that there's audio (the bar moves up and down with the audio that's being played) but on my stream/in test recordings the desktop audio isn't there. My mic is being picked up perfectly fine, though.
Here are my logs:
18:03:19.919: CPU Name: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
18:03:19.919: CPU Speed: 3696MHz
18:03:19.919: Physical Cores: 6, Logical Cores: 12
18:03:19.919: Physical Memory: 16338MB Total, 9219MB Free
18:03:19.919: Windows Version: 10.0 Build 17134 (revision: 345; 64-bit)
18:03:19.919: Running as administrator: false
18:03:19.919: Aero is Enabled (Aero is always on for windows 8 and above)
18:03:19.920: Windows 10 Gaming Features:
18:03:19.920:     Game Bar: Off
18:03:19.920:     Game DVR: Off
18:03:19.920:     Game DVR Background Recording: Off
18:03:19.920: Sec. Software Status:
18:03:19.921:     Windows Defender Antivirus: enabled (AV)
18:03:19.922:     Windows Firewall: enabled (FW)
18:03:19.922:     Windows Defender Antivirus: enabled (ASW)
18:03:19.922: Portable mode: false
18:03:19.994: OBS 21.1.0 (64bit, windows)
18:03:19.994: ---------------------------------
18:03:19.995: ---------------------------------
18:03:19.995: audio settings reset:
18:03:19.995:     samples per sec: 44100
18:03:19.995:     speakers:        2
18:03:19.996: ---------------------------------
18:03:19.996: Initializing D3D11...
18:03:19.996: Available Video Adapters:
18:03:19.997:     Adapter 1: NVIDIA GeForce GTX 1070 Ti
18:03:19.997:       Dedicated VRAM: 4177526784
18:03:19.997:       Shared VRAM:    4271323136
18:03:19.997:       output 1: pos={0, 0}, size={1920, 1080}, attached=true
18:03:19.997:       output 2: pos={-1440, -1080}, size={1920, 1080}, attached=true
18:03:19.997:       output 3: pos={-1920, 0}, size={1920, 1080}, attached=true
18:03:19.998: Loading up D3D11 on adapter NVIDIA GeForce GTX 1070 Ti (0)
18:03:20.033: D3D11 loaded successfully, feature level used: 45056
18:03:20.574: ---------------------------------
18:03:20.574: video settings reset:
18:03:20.574:     base resolution:   1920x1080
18:03:20.574:     output resolution: 1920x1080
18:03:20.574:     downscale filter:  Bicubic
18:03:20.574:     fps:               60/1
18:03:20.574:     format:            NV12
18:03:20.574:     YUV mode:          601/Partial
18:03:20.575: Audio monitoring device:
18:03:20.575:     name: Default
18:03:20.575:     id: default
18:03:20.575: ---------------------------------
18:03:20.576: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
18:03:20.580: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
18:03:20.610: [AMF] AMF Test failed due to one or more errors.
18:03:20.610: Failed to initialize module 'enc-amf.dll'
18:03:20.623: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
18:03:20.623: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
18:03:20.623:  (127)
18:03:20.623: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
18:03:20.623: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
18:03:20.626: [browser_source: 'Version: 1.31.0']
18:03:20.633: NVENC supported
18:03:20.735: Couldn't find VLC installation, VLC video source disabled
18:03:20.776: No blackmagic support
18:03:20.784: ---------------------------------
18:03:20.784:   Loaded Modules:
18:03:20.784:     win-wasapi.dll
18:03:20.784:     win-mf.dll
18:03:20.784:     win-dshow.dll
18:03:20.784:     win-decklink.dll
18:03:20.784:     win-capture.dll
18:03:20.784:     vlc-video.dll
18:03:20.784:     text-freetype2.dll
18:03:20.784:     rtmp-services.dll
18:03:20.784:     obs-x264.dll
18:03:20.784:     obs-vst.dll
18:03:20.784:     obs-transitions.dll
18:03:20.784:     obs-text.dll
18:03:20.784:     obs-qsv11.dll
18:03:20.784:     obs-outputs.dll
18:03:20.784:     obs-filters.dll
18:03:20.784:     obs-ffmpeg.dll
18:03:20.784:     obs-browser.dll
18:03:20.784:     image-source.dll
18:03:20.784:     frontend-tools.dll
18:03:20.784:     enc-amf.dll
18:03:20.784:     coreaudio-encoder.dll
18:03:20.784: ==== Startup complete ===============================================
18:03:20.794: All scene data cleared
18:03:20.794: ------------------------------------------------
18:03:20.827: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
18:03:20.842: WASAPI: Device 'VoiceMeeter Output (VB-Audio VoiceMeeter VAIO)' initialized
18:03:20.862: [window-capture: 'pp'] update settings:
18:03:20.862:     executable: Sync.exe
18:03:20.886: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
18:03:20.968: ---------------------------------
18:03:20.968: [DShow Device: 'handcam'] settings updated:
18:03:20.968:     video device: Logitech HD Webcam C510
18:03:20.968:     video path: \\?\usb#vid_046d&pid_081d&mi_02#6&733fdb7&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
18:03:20.968:     resolution: 640x480
18:03:20.968:     fps: 30.00 (interval: 333333)
18:03:20.968:     format: I420
18:03:21.439: [window-capture: 'Window Capture'] update settings:
18:03:21.439:     executable: LeagueClientUx.exe
18:03:21.471: Switched to scene 'Scene'
18:03:21.482: ------------------------------------------------
18:03:21.482: Loaded scenes:
18:03:21.482: - scene 'Scene':
18:03:21.482:     - source: 'display' (monitor_capture)
18:03:21.482:     - source: 'gamer' (game_capture)
18:03:21.482:     - source: 'handcam' (dshow_input)
18:03:21.482:     - source: 'Text (GDI+)' (text_gdiplus)
18:03:21.482:     - source: 'Text (GDI+) 2' (text_gdiplus)
18:03:21.482:     - source: 'pp' (window_capture)
18:03:21.482:         - filter: 'Color Key' (color_key_filter)
18:03:21.482:         - filter: 'Color Correction' (color_filter)
18:03:21.482:     - source: 'chat' (browser_source)
18:03:21.482:     - source: 'alerts' (browser_source)
18:03:21.482: - scene 'a':
18:03:21.482:     - source: 'brb' (text_gdiplus)
18:03:21.482: - scene 'gameonly':
18:03:21.482:     - source: 'desktop' (monitor_capture)
18:03:21.482:     - source: 'Game Capture' (game_capture)
18:03:21.482:     - source: 'Window Capture' (window_capture)
18:05:31.046: WASAPI: Device 'Speakers (Realtek High Definition Audio)' Terminated
18:05:31.069: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
18:05:36.017: WASAPI: Device 'VoiceMeeter Output (VB-Audio VoiceMeeter VAIO)' Terminated
18:05:36.031: WASAPI: Device 'VoiceMeeter Aux Output (VB-Audio VoiceMeeter AUX VAIO)' initialized
18:05:36.901: WASAPI: Device 'VoiceMeeter Aux Output (VB-Audio VoiceMeeter AUX VAIO)' Terminated
18:05:36.915: WASAPI: Device 'Microphone (Realtek High Definition Audio)' initialized
18:05:56.421: ---------------------------------
18:05:56.421: [NVENC encoder: 'simple_h264_recording'] settings:
18:05:56.421:     rate_control: CQP
18:05:56.421:     bitrate:      0
18:05:56.421:     cqp:          23
18:05:56.421:     keyint:       250
18:05:56.421:     preset:       hq
18:05:56.421:     profile:      high
18:05:56.421:     level:        auto
18:05:56.421:     width:        1920
18:05:56.421:     height:       1080
18:05:56.421:     2-pass:       true
18:05:56.421:     b-frames:     2
18:05:56.421:     GPU:          0
18:05:56.421:
18:05:56.596: warning: Using global_quality with nvenc is deprecated. Use qp instead.
18:05:56.661: ---------------------------------
18:05:56.662: [FFmpeg aac encoder: 'simple_aac_recording'] bitrate: 128, channels: 2, channel_layout: 3
18:05:56.662:
18:05:56.673: ==== Recording Start ===============================================
18:05:56.673: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/Tyler/Videos/2018-10-30 18-05-56.mp4'...
18:06:01.775: [game-capture: 'gamer'] attempting to hook fullscreen process: osu!.exe
18:06:01.779: [game-capture: 'gamer'] using helper (compatibility hook)
18:06:01.783: [game-capture: 'gamer'] hook not loaded yet, retrying..
18:06:08.808: [game-capture: 'gamer'] attempting to hook fullscreen process: osu!.exe
18:06:12.948: [game-capture: 'gamer'] gl shared texture capture successful
18:06:12.959: [game-capture: 'gamer'] shared texture capture successful
18:06:15.965: [game-capture: 'gamer'] ------------------ gl capture freed ------------------
18:06:15.994: [game-capture: 'gamer'] gl shared texture capture successful
18:06:15.999: [game-capture: 'gamer'] shared texture capture successful
18:06:17.654: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/Tyler/Videos/2018-10-30 18-05-56.mp4' stopped
18:06:17.654: Output 'simple_file_output': stopping
18:06:17.654: Output 'simple_file_output': Total frames output: 1242
18:06:17.654: Output 'simple_file_output': Total drawn frames: 1223 (1259 attempted)
18:06:17.654: Output 'simple_file_output': Number of lagged frames due to rendering lag/stalls: 36 (2.9%)
18:06:17.654: ==== Recording Stop ================================================
18:06:17.702: warning: 2 frames left in the queue on closing
18:06:22.342: adding 23 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
18:11:32.542: WASAPI: Device 'Microphone (Realtek High Definition Audio)' Terminated
18:11:32.554: WASAPI: Device 'VoiceMeeter Aux Output (VB-Audio VoiceMeeter AUX VAIO)' initialized
18:11:33.887: adding 23 milliseconds of audio buffering, total audio buffering is now 92 milliseconds
18:11:37.768: WASAPI: Device 'VoiceMeeter Aux Output (VB-Audio VoiceMeeter AUX VAIO)' Terminated
18:11:37.782: WASAPI: Device 'VoiceMeeter Output (VB-Audio VoiceMeeter VAIO)' initialized
18:11:42.184: ---------------------------------
18:11:42.184: [x264 encoder: 'simple_h264_stream'] preset: veryfast
18:11:42.184: [x264 encoder: 'simple_h264_stream'] settings:
18:11:42.184:     rate_control: CBR
18:11:42.184:     bitrate:      3000
18:11:42.184:     buffer size:  3000
18:11:42.184:     crf:          0
18:11:42.184:     fps_num:      60
18:11:42.184:     fps_den:      1
18:11:42.184:     width:        1920
18:11:42.184:     height:       1080
18:11:42.184:     keyint:       120
18:11:42.184:
18:11:42.184: [x264 encoder: 'simple_h264_stream'] custom settings: scenecut=0
18:11:42.189: ---------------------------------
18:11:42.189: [FFmpeg aac encoder: 'simple_aac'] bitrate: 160, channels: 2, channel_layout: 3
18:11:42.189:
18:11:42.190: [rtmp stream: 'simple_stream'] Connecting to RTMP URL rtmp://live-sjc.twitch.tv/app...
18:11:42.230: [rtmp stream: 'simple_stream'] Interface: TP-Link Wireless N PCI Express Adapter (802.11, 99 mbps)
18:11:42.934: [rtmp stream: 'simple_stream'] Connection to rtmp://live-sjc.twitch.tv/app successful
18:11:42.937: ==== Streaming Start ===============================================
18:11:44.314: [game-capture: 'gamer'] ------------------ gl capture freed ------------------
18:11:44.351: [game-capture: 'gamer'] gl shared texture capture successful
18:11:44.409: [game-capture: 'gamer'] shared texture capture successful
18:11:47.375: adding 23 milliseconds of audio buffering, total audio buffering is now 116 milliseconds
18:12:29.337: [game-capture: 'gamer'] ------------------ gl capture freed ------------------
18:12:29.379: [game-capture: 'gamer'] gl shared texture capture successful
18:12:29.402: [game-capture: 'gamer'] shared texture capture successful
18:12:42.152: [rtmp stream: 'simple_stream'] User stopped the stream
18:12:42.152: Output 'simple_stream': stopping
18:12:42.152: Output 'simple_stream': Total frames output: 3292 (3516 attempted)
18:12:42.152: Output 'simple_stream': Total drawn frames: 3581 (3598 attempted)
18:12:42.152: Output 'simple_stream': Number of lagged frames due to rendering lag/stalls: 17 (0.5%)
18:12:42.152: Output 'simple_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 224 (6.4%)
18:12:42.156: ==== Streaming Stop ================================================
18:12:42.228: warning: 2 frames left in the queue on closing
Thanks in advance for any help!
Zidakuh
This might be the reason
