OBS Network Framedrop issue
Bublik
Hello everybody,
I've had dropped frames while streaming for a long time.
As far as the OBS settings are concerned, I have already adjusted the whole thing so far that it should not be the case.
I also checked the problems with the provider and there is no disturbance. The problem also persists with the connection directly from the router (currently still connected to a switch) to the computer.
Since I am unfortunately not familiar with the log, I hope that someone can possibly find the problem.
I have already checked / tried the following:
- Drivers all up to date
- The latest updates installed
- Malfunctions checked
- LAN cable replaces CAT8 in both directions
attached the last log file.
  • 2021-02-19 08-37-33.txt
Bublik
can you please disable the streamelemts shit and create a new los cant read this !
did you have isntall any VPN software Network gamebooster or so ?
Hello Cyclemat,
I haven't installed any VPN programs or anything like that.
Should I just deactivate the source and save a new log or what do you mean exactly?
