BeardedMonkee
Hey guys and fellows streamers i had a question when i stream using obs multi now it doesnt do when i use it and ps3 and obs together but when i use it and play pc games it cause the osb program to temp freeze until i click on obs again then its about another 5 mins and then freezes again thanks so much for the help - BeardedMonkee
Current Log
23:00:06.315: CPU Name: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
23:00:06.316: CPU Speed: 3392MHz
23:00:06.316: Physical Cores: 4, Logical Cores: 8
23:00:06.316: Physical Memory: 2047MB Total, 2047MB Free (NOTE: 4 gigs max is normal for 32bit programs)
23:00:06.316: Windows Version: 10.0 Build 10240 (revision: 16384)
23:00:06.316: Aero is Enabled (Aero is always on for windows 8 and above)
23:00:06.324: OBS 0.12.0 (windows)
23:00:06.324: ---------------------------------
23:00:06.324: audio settings reset:
23:00:06.324: samples per sec: 48000
23:00:06.324: speakers: 2
23:00:06.324: buffering (ms): 2000
23:00:06.355: ---------------------------------
23:00:06.355: Initializing D3D11..
23:00:06.355: Available Video Adapters:
23:00:06.356: Adapter 0: NVIDIA GeForce GT 640
23:00:06.358: Loading up D3D11 on adapter NVIDIA GeForce GT 640 (0)
23:00:06.488: D3D11 loaded sucessfully, feature level used: 45056
23:00:06.964: ---------------------------------
23:00:06.964: video settings reset:
23:00:06.964: base resolution: 1920x1080
23:00:06.964: output resolution: 1280x720
23:00:06.964: fps: 60/1
23:00:06.964: format: NV12
23:00:06.965: ---------------------------------
23:00:06.999: Loading module: coreaudio-encoder.dll
23:00:07.234: [CoreAudio encoder]: Failed loading library 'CoreAudioToolbox.dll'
23:00:07.234: [CoreAudio encoder]: Couldn't load CoreAudio AAC encoder
23:00:07.234: ---------------------------------
23:00:07.251: Loading module: image-source.dll
23:00:07.255: ---------------------------------
23:00:07.276: Loading module: obs-ffmpeg.dll
23:00:07.293: ---------------------------------
23:00:07.305: Loading module: obs-filters.dll
23:00:07.309: ---------------------------------
23:00:07.334: Loading module: obs-outputs.dll
23:00:07.348: ---------------------------------
23:00:07.365: Loading module: obs-x264.dll
23:00:07.378: ---------------------------------
23:00:07.395: Loading module: rtmp-services.dll
23:00:07.400: ---------------------------------
23:00:07.438: Loading module: text-freetype2.dll
23:00:07.902: ---------------------------------
23:00:07.972: Loading module: win-capture.dll
23:00:08.566: ---------------------------------
23:00:08.595: Loading module: win-decklink.dll
23:00:08.625: No blackmagic support
23:00:08.625: Failed to start search for DeckLink devices
23:00:08.625: ---------------------------------
23:00:08.667: Loading module: win-dshow.dll
23:00:08.734: ---------------------------------
23:00:08.800: Loading module: win-mf.dll
23:00:08.854: [Media Foundation encoder]: Adding Media Foundation AAC Encoder
23:00:09.091: ---------------------------------
23:00:09.116: Loading module: win-wasapi.dll
23:00:09.125: =====================================================================
23:00:09.125: output 'simple_stream' (rtmp_output) created
23:00:09.125: encoder 'simple_h264_stream' (obs_x264) created
23:00:09.125: AAC encoder bitrate mapping:
23:00:09.125: 32 kbit/s: 'FFmpeg Default AAC Encoder' (ffmpeg_aac)
23:00:09.125: 64 kbit/s: 'FFmpeg Default AAC Encoder' (ffmpeg_aac)
23:00:09.125: 96 kbit/s: 'Media Foundation AAC Encoder' (mf_aac)
23:00:09.125: 128 kbit/s: 'Media Foundation AAC Encoder' (mf_aac)
23:00:09.125: 160 kbit/s: 'Media Foundation AAC Encoder' (mf_aac)
23:00:09.125: 192 kbit/s: 'Media Foundation AAC Encoder' (mf_aac)
23:00:09.125: 224 kbit/s: 'FFmpeg Default AAC Encoder' (ffmpeg_aac)
23:00:09.125: 256 kbit/s: 'FFmpeg Default AAC Encoder' (ffmpeg_aac)
23:00:09.125: 288 kbit/s: 'FFmpeg Default AAC Encoder' (ffmpeg_aac)
23:00:09.125: 320 kbit/s: 'FFmpeg Default AAC Encoder' (ffmpeg_aac)
23:00:09.125: encoder 'simple_aac' (mf_aac) created
23:00:09.125: output 'simple_file_output' (ffmpeg_muxer) created
23:00:09.127: service 'default_service' (rtmp_common) created
23:00:09.130: All scene data cleared
23:00:09.130: ------------------------------------------------
23:00:09.146: WASAPI: Device 'Speakers / Headphones (IDT High Definition Audio CODEC)' initialized
23:00:09.146: source 'Desktop Audio' (wasapi_output_capture) created
23:00:09.147: source 'Noise Gate' (noise_gate_filter) created
23:00:09.156: WASAPI: Device 'Microphone (2- Samson GoMic)' initialized
23:00:09.156: source 'Mic/Aux' (wasapi_input_capture) created
23:00:09.156: source 'Noise Gate' (noise_gate_filter) created
23:00:09.156: source 'Game' (scene) created
23:00:09.157: source 'webcam' (dshow_input) created
23:00:09.199: Audio line 'Mic/Aux' audio data currently getting cut off. This could be due to a negative sync offset that's larger than the current audio buffering time.
23:00:09.224: Audio line 'Mic/Aux' audio data no longer getting cut off.
23:00:09.225: source 'Chroma Key' (chroma_key_filter) created
23:00:09.225: source 'Video Delay (Async)' (async_delay_filter) created
23:00:09.262: source 'Color Key' (color_key_filter) created
23:00:09.263: source 'Game Capture' (game_capture) created
23:00:09.263: source 'Starting Stream' (scene) created
23:00:09.264: source 'Image' (image_source) created
23:00:09.265: source 'chat' (window_capture) created
23:00:09.280: source 'Crop' (crop_filter) created
23:00:09.280: source 'Color Key' (color_key_filter) created
23:00:09.340: device_vertexbuffer_create (D3D11): Cannot initialize vertex buffer with 0 vertices
23:00:09.340: Couldn't create UV vertex buffer.
23:00:09.340: source 'Now Playing' (text_ft2_source) created
23:00:09.342: source 'Scroll' (scroll_filter) created
23:00:09.342: source 'alert2' (window_capture) created
23:00:09.342: source 'Crop' (crop_filter) created
23:00:09.342: source 'Color Key' (color_key_filter) created
23:00:09.342: source 'overlay' (image_source) created
23:00:09.356: source 'follower' (text_ft2_source) created
23:00:09.357: source 'capcard' (dshow_input) created
23:00:09.357: source 'Chill' (scene) created
23:00:09.357: source 'chill' (image_source) created
23:00:09.365: device_get_size (D3D11): no active swap
23:00:09.656: device_get_size (D3D11): no active swap
23:00:09.657: device_get_size (D3D11): no active swap
23:00:09.665: device_get_size (D3D11): no active swap
23:00:09.675: == Profiler Results =============================
23:00:09.675: run_program_init: 3464.89 ms
23:00:09.675: ┣OBSApp::AppInit: 32.108 ms
23:00:09.675: ┃ ┗OBSApp::InitLocale: 28.784 ms
23:00:09.675: ┗OBSApp::OBSInit: 3373.95 ms
23:00:09.675: ┣obs_startup: 1.008 ms
23:00:09.675: ┗OBSBasic::OBSInit: 3350.7 ms
23:00:09.675: ┣OBSBasic::InitBasicConfig: 0.312 ms
23:00:09.675: ┣OBSBasic::ResetAudio: 0.162 ms
23:00:09.675: ┣OBSBasic::ResetVideo: 640.413 ms
23:00:09.675: ┣OBSBasic::InitOBSCallbacks: 0.015 ms
23:00:09.675: ┣OBSBasic::InitHotkeys: 0.036 ms
23:00:09.675: ┣obs_load_all_modules: 2159.81 ms
23:00:09.675: ┃ ┣obs_init_module(coreaudio-encoder.dll): 0.446 ms
23:00:09.675: ┃ ┣obs_init_module(image-source.dll): 0.002 ms
23:00:09.675: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.013 ms
23:00:09.676: ┃ ┣obs_init_module(obs-filters.dll): 0.005 ms
23:00:09.676: ┃ ┣obs_init_module(obs-outputs.dll): 0.004 ms
23:00:09.676: ┃ ┣obs_init_module(obs-x264.dll): 0.002 ms
23:00:09.676: ┃ ┣obs_init_module(rtmp-services.dll): 0.337 ms
23:00:09.676: ┃ ┣obs_init_module(text-freetype2.dll): 455.798 ms
23:00:09.676: ┃ ┣obs_init_module(win-capture.dll): 554.26 ms
23:00:09.676: ┃ ┣obs_init_module(win-decklink.dll): 3.276 ms
23:00:09.676: ┃ ┣obs_init_module(win-dshow.dll): 3.786 ms
23:00:09.676: ┃ ┣obs_init_module(win-mf.dll): 237.351 ms
23:00:09.676: ┃ ┗obs_init_module(win-wasapi.dll): 0.006 ms
23:00:09.676: ┣OBSBasic::ResetOutputs: 0.327 ms
23:00:09.676: ┣OBSBasic::CreateHotkeys: 0.014 ms
23:00:09.676: ┣OBSBasic::InitService: 1.649 ms
23:00:09.676: ┣OBSBasic::InitPrimitives: 0.163 ms
23:00:09.676: ┗OBSBasic::Load: 238.154 ms
23:00:09.676: =================================================
23:00:09.682: device_get_size (D3D11): no active swap
23:00:09.722: ---------------------------------
23:00:09.722: [DShow Device: 'webcam'] settings updated:
23:00:09.722: video device: Logitech HD Pro Webcam C920
23:00:09.722: video path: \\?\usb#vid_046d&pid_082d&mi_00#7&728ec77&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
23:00:09.722: resolution: 1920x1080
23:00:09.722: fps: 30.00 (interval: 333333)
23:00:09.722: format: I420
23:00:09.760: ---------------------------------
23:00:09.760: [DShow Device: 'capcard'] settings updated:
23:00:09.760: video device: Hauppauge Siena Video Capture
23:00:09.760: video path: \\?\usb#vid_2040&pid_e524#e524-00-00abbee9#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{9b365890-165f-11d0-a195-0020afd156e4}
23:00:09.760: resolution: 720x480
23:00:09.760: fps: 59.94 (interval: 166833)
23:00:09.760: format: H264
23:00:09.761: using video device audio: yes
23:00:09.761: sample rate: 48000
23:00:09.761: channels: 2
23:00:09.761: audio type: Capture
23:00:09.808: Update check: last known remote version is 0.12.0
Current Log
