Question / Help OBS lag spikes
contacttom2006
So I just started streaming recently, and i've noticed a problem with OBS, that I don't notice, nearly as much with Xsplit, which I've also tried. When I stream with OBS, the stream lag spikes (freezes for around 3-4 seconds) every 20-30 seconds or so. My speedtest.net upload speed is 5000kb/s or 5 MB/s upload, and I set the max bitrate to 4000kb/s and buffer to 3500 bk/s. I've tried much lower before. My quality is set to 7, and resolution set to 720p. It still continues to spike like this.. I use the same settings with Xsplit (and twitch.tv server) , but I get a much smoother stream, only problem is the large amount of CPU usage that xsplit uses(which causes FPS issues). Please take a look at my log for anything you need. Thanks.
  • 2013-02-27-1854-05.log
R1CH
You are getting lagged frames, put your preset back to veryfast. Nothing else seems wrong though. Does the problem show in a VOD?
contacttom2006
Yes the problem does occur in the VODS. I haven't tried changing the preset to very fast yet, but I will tomorrow.
contacttom2006
Some other useful information:
I'm not watching the stream on the same PC that I'm streaming on.
I can easily watch others stream at 1080p with no lag at all
Question:
With my PC stats and Internet stats, what resolution AND quality do you think I should stream at? (Open question)
^for no lag at all^ (I know the Buffer and bit rate come into play too, so feel free to add those)
Again I get 5 Mb/s up and 50 MB/s down
