Bug Report OBS Keeps Starting a Stream [woops, was hotkey]
caLviN1260
After I open the program, as soon as I click anywhere on my screen, OBS starts streaming. It doesn't matter where I click while the app is open, if I click anywhere on my monitor, even on another program, my stream just starts. I can stop the stream, but as soon as I click anything again like Settings, or my desktop, the app starts streaming again. I can't just do Preview Stream either, because when I click the Preview Stream button it it starts a real stream.
I removed my stream key from the settings when I figured out this was happening so that my stream wasn't always going up and my Twitter wouldn't be spammed with stream updates. However, because I removed the stream key, an error message appears every time I click something with OBS open. The error is saying it doesn't have a place to stream to, because every time I click "start streaming" still activates. With the constant pop up appaearing every time I click, the program is virtually unusable, even if I just want to change settings. It has even made it a hassle to close the program itself, because when exit is clicked, the stream STILL starts up.
I honest to god have no idea what to do. I've tried uninstalling and reinstalling different builds. All the same problem.
I'm using Windows 8 if that makes a difference.
Lain
Lain
Re: OBS Keeps Starting a Stream
You most likely have your mouse button assigned to the "start stream" hotkey or something.
