OBS Keeps Disconnecting from Twitch
swoopdeedoo
I just started streaming a few months now and my stream has been working fine up until a week ago. There were maybe two updates for OBS and i installed them and now it disconnects frequently and I'm not sure why. I ran the log files through the analyzer and made some changes, but the stream still runs fine and then OBS drops to 0 kbps. Here are three log files of test streams I tried to do. Some went for over an hour before disconnecting and some disconnected after a few minutes. I'm connected to an ethernet and I tried changing the Twitch server to see if it helps but the same problem comes up. Should I revert OBS to a previous version? Is OBS ok and something wrong with my internet? My connection seems fine though since none of my devices and game drop connection. If it is my internet, wouldn't it have caused problems from the start?
  • 2024-04-09 19-53-33.txt
  • 2024-04-09 20-04-12.txt
  • 2024-04-10 00-28-48.txt
