OBS Keeps Disconnecting and Reconnecting durring streams
Sgt. Pickle
Hi all,
Hoping someone can help here. Once per stream, OBS has a little popup that says disconnecting and then another that says reconnecting shortly after. The stream on Twitch then stops down and starts back up again. Locally, OBS doesn't seem to crash or stop recording and streaming. I'm hardwired over ethernet as well. ISP is Verizon Fios with 500 up and 500 down. Any help here would be appreciated as it's been rather frustrating trying to get to the bottom of this. Thank you!
The two logs from before and after the event are attached below from the last time that it happened.
  • 2024-01-18 20-12-25.txt
  • 2024-01-18 20-12-07.txt
