Bug Report OBS Keeps Crashing
Costellotv
Crashed 4 times within 2hours:
This crash appears to have occured in the 'c:\windows\system32\kernelbase.dll' module.
**** UNHANDLED EXCEPTION: 80000003
Fault address: 000007FEFD7D3C52 (c:\windows\system32\kernelbase.dll)
OBS version: Open Broadcaster Software v0.655b
CPU: AMD FX(tm)-9370 Eight-Core Processor
Crashing thread stack trace:
000000000017F358 000007FEFD7D3C52 000007FEDFD20C60 0000000000007532 000000000017F2B8 000000000017F3F9 kernelbase.dll!0x7fefd7d3c52
000000000017F360 000007FEDFCF14B3 0000000001E8D9A0 000000013FE16400 0000000001E8D9A0 000007FE00000002 obsapi.dll!OSTerminateThread+0x33
000000000017F390 000000013FD5E773 000000000000F060 0000000001E8D9A0 000000000000F060 0000000000000000 obs.exe!OBS::Stop+0x213
000000000017F460 000000013FD568ED 0000000000000000 0000000000000000 0000000000000001 0000000001E70090 obs.exe!OBS::~OBS+0x4d
000000000017F8E0 000000013FD56874 00000000007E01E3 00000000007E01E3 000007FEFE9D2170 0000000001E70090 obs.exe!OBS::`vector deleting destructor'+0x14
000000000017F910 000000013FD4D88E 0000000000000000 000000013FD20000 0000000000000000 0000000000000000 obs.exe!WinMain+0xbae
000000000017FED0 000000013FDCE730 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!__tmainCRTStartup+0x148
000000000017FF10 0000000077575A4D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x77575a4d
000000000017FF40 00000000777AB831 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x777ab831
Video thread stack trace:
00000000122FEED8 000007FEFFA2140A 00000000122FEF88 0000000001F1C668 0000000001F1C668 000007FEF6B905AF gdi32.dll!0x7feffa2140a
00000000122FEEE0 000007FEF6B91983 00000000034DBCE0 0000000000000000 0000000000000000 000007FEF58EFC64 d3d11.dll!0x7fef6b91983
00000000122FEF40 000007FEF58F0110 00000000034D3AE0 0000000000000001 00000000122FF250 0000000000000000 atidxx64.dll!0x7fef58f0110
00000000122FEFE0 000007FEF58F31B8 0000000000000000 00000000034D3AE0 0000000000000005 000007FEF58F31B8 atidxx64.dll!0x7fef58f31b8
00000000122FF010 000007FEF587E48E 00000000034D19D8 0000000000000006 00000000122FF250 000007FEF58C28EB atidxx64.dll!0x7fef587e48e
00000000122FF090 000007FEF587E1E6 00000000034D89A0 000007FE00000000 0000000000000000 0000000000000001 atidxx64.dll!0x7fef587e1e6
00000000122FF0D0 000007FEF5876636 0000000000000004 0000000002D3EE00 00000000122FF250 0000000000000000 atidxx64.dll!0x7fef5876636
00000000122FF110 000007FEF5E1AAE0 0000000000000001 0000000000000000 0000000000000000 0000000000000004 atidxx64.dll!0x7fef5e1aae0
00000000122FF1A0 000007FEF588D563 0000000001F1D5C0 0000000001F3B450 0000000000000001 00000000122FF200 atidxx64.dll!0x7fef588d563
00000000122FF1E0 000007FEF6687413 0000000001DD0000 0000000000000800 0000000001DE0000 0000000000000800 atiuxp64.dll!0x7fef6687413
00000000122FF220 000007FEF6BFAC1B 0000000001F1D5C0 0000000000000004 00000000FFFFFFFF 0000000001F3B450 d3d11.dll!0x7fef6bfac1b
00000000122FF290 000007FEF6C20ACA 0000000000000000 0000000000000000 0000000000000000 0000000000000000 d3d11.dll!0x7fef6c20aca
00000000122FF2D0 000007FEF6C52FE3 0000000001F1CC28 0000000001F1D630 0000000001F3B450 0000000000000000 d3d11.dll!0x7fef6c52fe3
00000000122FF310 000007FEF6C26237 0000000000000009 00000000122FF510 0000000000001050 0000000000000000 d3d11.dll!0x7fef6c26237
00000000122FF360 000007FEF6BA315F FFFFFFFF00000000 000007FEF58EC20D 0000000000000000 0000000077698D3C d3d11.dll!0x7fef6ba315f
00000000122FF3B0 000000013FD32785 000000000033C020 00000000122FF510 000000000033C020 0000000002D5C530 obs.exe!D3D10Texture::SetImage+0xb5
00000000122FF410 000000013FD34C82 00000007D43B4D00 00000715AE681266 0000000001F4A2E0 00000715AF993F66 obs.exe!DesktopImageSource::Preprocess+0x4a2
00000000122FF710 000007FEDFCD7BF6 0000000000000000 0000000000000000 00000000122FF840 000000000000018C obsapi.dll!Scene::Preprocess+0x36
00000000122FF740 000000013FD646A4 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::MainCaptureLoop+0x9f4
00000000122FFBD0 000000013FD621C9 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::MainCaptureThread+0x9
00000000122FFC00 0000000077575A4D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x77575a4d
00000000122FFC30 00000000777AB831 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x777ab831
R1CH
Don't use monitor capture on AMD drivers, and make sure compatibility mode is enabled for window capture.
Costellotv
Thank you for the quick reply! I am still crashing, but I did receive this Error MSG:
Error: Texture->Map failed: 0x887a0005 0x887a0007
Your video card or driver froze and was reset. Please check for possible hardware / driver issues. This error can also occur if you have enabled opencl in x264 custom settings.
I have read your post on texture map fail and will try the suggested. I recently bought an XFX R9 390x if anyone has this GPU and could lend helpful information that would be great!
