Bug Report OBS keeps crashing while streaming
KingRapp
Everything will work fine for a few minutes but it recently began to crash after the new update. Here's my Log Files of that stream ( The Link is while the stream was up. The File was to large to upload). Also the Elgato audio time stamp continues the whole time the stream is up.
http://pastebin.com/FBDtgW84
  • 2015-12-07-0250-36.log
  • 2015-12-07-0255-28.log
R1CH
None of those logs show any crashing. Please post the crash report you get when OBS crashes.
KingRapp
That's the problem. I was Looking for the crash report but I don't have one. When obs crash i only get a pop up message from windows saying OBS has crashed. Or am I looking in the wrong place. I go to my Log files and look there correct.
KingRapp
Ok when I try to use the 64 bit version of OBS the stream crashes right away and creates a crash report but when i use the 32 bit version the streams crashes ten minutes in with no crash report. Attached are the crash report for the 64 bit version with a screen shot of whats pop up. Now like i stated above the 32 version doesn't create a crash report it just simply stop and a windows pop up occurs just like in that screen shot
  • 2015-12-07-2012-55.log
KingRapp
https://obsproject.com/ - include the contents of this crash log and the
This crash appears to have occured in the '<unknown>' module.
Fault address: 000008F9AE5266C0 (<unknown>)
OBS version: Open Broadcaster Software v0.657b
Windows version: 10.0 (Build 10240)
CPU: AMD FX(tm)-6300 Six-Core Processor
Crashing thread stack trace:
0000004DBE56E448 000008F9AE5266C0 0000000000000BC8 0000000180018768 0000004DBE56E4B0 0000000000002736 <unknown>!0x8f9ae5266c0
0000004DBE56E450 000000018002E658 0000004DBE6BBF30 0000004DBE6BBF30 0000000000000000 0000000000000000 lavasofttcpservice64.dll!0x18002e658
0000004DBE56E490 0000000180008838 0000000000000BC8 00007FFECC283B01 0000000000000000 0000000000000000 lavasofttcpservice64.dll!0x180008838
0000004DBE56E4E0 00007FFECC27F881 0000004D00000000 0000004DBE6BBF30 0000000000000000 0000000000000000 libcef.dll!0x7ffecc27f881
0000004DBE56E520 00007FFECC284116 0000000000000003 0000004D00000003 0000000000000000 0000004DBE6BBEA0 libcef.dll!0x7ffecc284116
0000004DBE56E6C0 00007FFECC280DAB FFFFFFFF00000000 0000004DBE6BBEA0 0000000000000000 0000004DBE56E8B0 libcef.dll!0x7ffecc280dab
0000004DBE56E6F0 00007FFECC27935C 0000004DBE56EA60 FFFFFFFFFFFFFFFF 0000004DBC572A40 FFFFFFFFFFFFFFFF libcef.dll!0x7ffecc27935c
0000004DBE56E860 00007FFECC278FF9 FFFFFFFFFFFFFFFF 0000004DBE56EA60 0000004DBE678D20 FFFFFFFFFFFFFFFF libcef.dll!0x7ffecc278ff9
0000004DBE56EA20 00007FFECC279691 00007FFECC278F40 FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF libcef.dll!0x7ffecc279691
0000004DBE56EAB0 00007FFECC2798C7 FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF libcef.dll!0x7ffecc2798c7
0000004DBE56EB10 00007FFECBA07F59 0000004DBC57C780 0000004D00000000 0000004DBC4E15B0 0000004D03C7F691 libcef.dll!0x7ffecba07f59
0000004DBE56F3F0 00007FFECBA07383 0000004DBC4DE480 0000004DBC4E15B0 0000000000000000 0000004DBC4DE480 libcef.dll!0x7ffecba07383
0000004DBE56F4A0 00007FFECBA349EB 0000000010FDCAE0 0000000EC51AFB70 0000000000000000 00007FFECBA07AFE libcef.dll!0x7ffecba349eb
0000004DBE56F4E0 00007FFECBA34F4B 0000004DBE56F580 00007FFEF2D4BCF4 0000004DBBDC85B0 0000000000000001 libcef.dll!0x7ffecba34f4b
0000004DBE56F530 00007FFECBA204E0 0000004D00000000 000000000000001B 0000000000000000 0000004DBBDC85B0 libcef.dll!0x7ffecba204e0
0000004DBE56F560 00007FFECBA07AD8 0000000000000010 0000004DBE56F6A0 0000000000000010 00007FFEF2D4B9DC libcef.dll!0x7ffecba07ad8
0000004DBE56F5C0 00007FFECBCF70DE 0000004DBC4E15B0 0000004DBC57C780 0000004DBC50D680 0000004DBE56F768 libcef.dll!0x7ffecbcf70de
0000004DBE56F710 00007FFECBCF785F 0000000000000000 0000000000000000 0000004D00000006 0000004DBC4E15B0 libcef.dll!0x7ffecbcf785f
0000004DBE56F850 00007FFECBA20B87 0000000000000000 0000000000000A4C 0000000000000A4C 0000000000000000 libcef.dll!0x7ffecba20b87
0000004DBE56F9A0 00007FFECBA056CF 0000000000000A4C 00007FFECBA05620 0000004DBC4C0060 0000000000000000 libcef.dll!0x7ffecba056cf
0000004DBE56FB10 00007FFEF5E32D92 00007FFEF5E32D70 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ffef5e32d92
0000004DBE56FB40 00007FFEF64B9F64 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ffef64b9f64
A minidump was saved to C:\Users\King Rapp\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-12-08_1.dmp.
List of loaded modules:
Base Address Module
R1CH
Uninstall whatever Lavasoft product is messing with your system (lavasofttcpservice64).
