Bug Report OBS Issues on Mac Pro (Early 2008) + C920
molotov
Having issues getting my Logitech C920 to play nicely with OBS 0.15.1 on a Mac Pro (2008), running El Capitan.
Strangely the C920 works fine with OBS on a newer Macbook Pro, also running El Capitan.
When selecting the C920 as a video input, the picture just freezes. Oddly, it does pick up the C920 microphones.
The C920 is working perfectly with other apps like Skype and Quicktime on the same Mac Pro.
Any suggestions to get it working on this machine greatly appreciated!
https://gist.github.com/409ffefb1c413b6c96fcbfb4872ca73c
  • 2016-09-05 21-13-37.txt
c3r1c3
Hmm...
21:13:39.840: Video Capture Device: Could not initialize device with unique ID '0xfd500000046d082d'
21:13:55.683: Video Capture Device: Device with unique id '0xfd500000046d082d' not found
Seems OBS is having trouble grabbing your webcam. Is it in use in another program when you're running OBS?
molotov
Nothing else running, I just force quit everything just in case, then ran OBS. Still the same issues.
Thanks for the suggestion though! :)
c3r1c3
Hmm... I must admit that I've only used the built-in webcam in my laptop and monitor. I have heard bad things about Logitech+MacOS+their drivers in the past year, so maybe try some older drivers from them?
