Question / Help OBS Issue - Framerate drop
checkm8
I've lurked for awhile and tried a couple of fixes. No such luck. I'm trying to stream awesomenauts on twitch so I would assume I can use a lower FPS. However, even when I'm not in the thick of the fight my recording is not smooth.
If you need more info, I'd be more than happy to. Please help <3
18:43:18: Open Broadcaster Software v0.542b - 32bit (´・ω・`)
18:43:18: -------------------------------
18:43:18: CPU Name: Intel(R) Core(TM)2 Duo CPU     E8500  @ 3.16GHz
18:43:18: CPU Speed: 3166MHz
18:43:18: Physical Memory:  4094MB Total, 1748MB Free
18:43:18: stepping id: 10, model 7, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 2, total cores 2
18:43:18: monitor 1: pos={0, 0}, size={1842, 1026}
18:43:18: Windows Version: 6.1 Build 7601 S
18:43:18: Aero is Enabled
18:43:18: OBS Modules:
18:43:18: Base Address     Module
18:43:18: 00C90000         OBS.exe
18:43:18: 6A600000         OBSApi.dll
18:43:18: 73050000         DShowPlugin.dll
18:43:18: 73030000         GraphicsCapture.dll
18:43:18: 73010000         NoiseGate.dll
18:43:18: 72FF0000         PSVPlugin.dll
18:43:18: ------------------------------------------
18:43:18: Adapter 1
18:43:18:   Video Adapter: NVIDIA GeForce GTX 460
18:43:18:   Video Adapter Dedicated Video Memory: 1025966080
18:43:18:   Video Adapter Shared System Memory: 1878282240
18:43:18: =====Stream Start: 2013-08-06, 18:43:18===============================================
18:43:18:   Multithreaded optimizations: On
18:43:18:   Base resolution: 1842x1026
18:43:18:   Output resolution: 612x342
18:43:18: Loading up D3D10...
18:43:18: Playback device Default
18:43:18: Using desktop audio input: Speakers (7- Logitech USB Headset)
18:43:18: Using auxilary audio input: Microphone (7- Logitech USB Headset)
18:43:18: Audio Encoding: AAC
18:43:18:     bitrate: 128
18:43:18: Using graphics capture
18:43:18: Video Encoding: x264
18:43:18:     fps: 30
18:43:18:     width: 612, height: 342
18:43:18:     preset: veryfast
18:43:18:     CBR: yes
18:43:18:     CFR: no
18:43:18:     max bitrate: 2900
18:43:18: SharedTexCapture hooked
18:43:19: Using RTMP service: Twitch / Justin.tv
18:43:19:   Server selection: rtmp://live.justin.tv/app
18:43:20: SO_SNDBUF was at 8192
18:43:20: SO_SNDBUF is now 65536
18:55:30: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
19:29:13: Total frames rendered: 48943, number of frames that lagged: 6790 (13.87%) (it's okay for some frames to lag)
19:29:13: RTMPPublisher::SocketLoop: Aborting due to bStopping
19:29:13: Number of times waited to send: 107, Waited for a total of 395582 bytes
19:29:13: Number of b-frames dropped: 491 (1%), Number of p-frames dropped: 536 (1.1%), Total 1027 (2.1%)
19:29:14: =====Stream End: 2013-08-06, 19:29:14=================================================
19:29:22:
19:29:22: Profiler results:
19:29:22:
19:29:22: ==============================================================
19:29:22: frame - [100%] [avg time: 29.458 ms (cpu time: avg 1.611 ms, total 78874.1 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.0272%]
19:29:22: | frame preprocessing and rendering - [2.45%] [avg time: 0.722 ms (cpu time: avg 0.476 ms, total 23306.5 ms)] [avg calls per frame: 1] [children: 0.00679%] [unaccounted: 2.44%]
19:29:22: | | scene->Preprocess - [0.00679%] [avg time: 0.002 ms (cpu time: avg 0.002 ms, total 109.201 ms)] [avg calls per frame: 1]
19:29:22: | video encoding and uploading - [97.5%] [avg time: 28.728 ms (cpu time: avg 1.133 ms, total 55474 ms)] [avg calls per frame: 1] [children: 96.6%] [unaccounted: 0.944%]
19:29:22: | | flush - [0.703%] [avg time: 0.207 ms (cpu time: avg 0.05 ms, total 2496.02 ms)] [avg calls per frame: 1]
19:29:22: | | CopyResource - [0.109%] [avg time: 0.032 ms (cpu time: avg 0.01 ms, total 514.805 ms)] [avg calls per frame: 0]
19:29:22: | | conversion to 4:2:0 - [0.017%] [avg time: 0.005 ms (cpu time: avg 0.003 ms, total 171.602 ms)] [avg calls per frame: 0]
19:29:22: | | call to encoder - [95.4%] [avg time: 28.107 ms (cpu time: avg 0.978 ms, total 47892.3 ms)] [avg calls per frame: 0]
19:29:22: | | sending stuff out - [0.336%] [avg time: 0.099 ms (cpu time: avg 0.065 ms, total 3229.22 ms)] [avg calls per frame: 0]
19:29:22: | Convert444Threads - [191%] [avg time: 56.288 ms (cpu time: avg 0.652 ms, total 31917.8 ms)] [avg calls per frame: 0]
19:29:22:
