I'v been trying out OBS, and my initial thought was that it's a great piece of software! Though after using it for a while I'v noticed a huge problem. Sometimes or rather somedays OBS just drops and lags the fudge out, slowing any game until it is not playable any more.
This happens after every 8~10 minutes of gameplay, I can restart OBS and the Game instantly and then it works great, for about 8~10 minutes. After that it just randomly drops my frame-rate and makes the game lag something horrible.
Other days I can livestream the whole day without any slowdowns or such, it just works flawlessly. Yesterday was such a day, I streamed the entire day and I only got problems once night came, then the same problem. I was thinking that maybe my computer is very warm. But the problem persists today.
I'v decided to turn to the forums, is anyone else having these problems?
Here is an log-file, note that enabling or disabling multi-threading doesn't make a difference.
I know it's not the best computer, BUT how come it works sometimes ( for a full day ) without ANY problems?
Open Broadcaster Software v0.472b - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz
CPU Speed: 2394MHz
Physical Memory: 4001MB Total, 2211MB Free
stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 2
monitor 1: pos={0, 0}, size={1366, 768}
monitor 2: pos={-1366, 48}, size={1366, 768}
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GT 520M
Video Adapter Dedicated Video Memory: 1026097152
Video Adapter Shared System Memory: 1829275648
Adapter 2
Multithreaded optimizations: Off
Base resolution: 1280x720
Output resolution: 1280x720
Loading up D3D10...
Playback device {0.0.0.00000000}.{21c4d025-58b0-4c8d-9172-756114aaa408}
Using desktop audio input: Speakers (Realtek High Definition Audio)
Using auxilary audio input: Microphone (Realtek High Definition Audio)
Audio Encoding: AAC
bitrate: 128
Using bitmap image
device: ASUS USB2.0 WebCam,
device id \\?\usb#vid_058f&pid_a014&mi_00#7&335c350b&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
chosen type: YUY2, usingFourCC: false, res: 640x480 - 640x480, fps: 15-30.0001, fourCC: 'YUY2'
Using directshow input
Using Window Capture
Using bitmap image
x264: profile High, level 3.1
Video Encoding: x264
fps: 30
width: 1280, height: 720
preset: superfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 7
Total frames rendered: 27716, number of frames that lagged: 3510 (12.66%) (it's okay for some frames to lag)
x264: frame I:111 Avg QP:24.17 size: 56867
x264: frame P:8773 Avg QP:19.02 size: 5290
x264: frame B:18802 Avg QP:19.07 size: 1054
x264: consecutive B-frames: 9.1% 0.8% 0.5% 89.6%
x264: mb I I16..4: 36.9% 29.5% 33.5%
x264: mb P I16..4: 2.6% 0.7% 0.6% P16..4: 10.6% 0.0% 0.0% 0.0% 0.0% skip:85.5%
x264: mb B I16..4: 0.2% 0.0% 0.0% B16..8: 2.5% 0.0% 0.0% direct: 1.5% skip:95.8% L0:40.7% L1:53.7% BI: 5.6%
x264: 8x8 transform intra:20.5% inter:18.4%
x264: coded y,uvDC,uvAC intra: 35.9% 33.3% 25.1% inter: 1.8% 2.8% 0.8%
x264: i16 v,h,dc,p: 72% 24% 4% 0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 28% 17% 6% 5% 6% 6% 5% 8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 29% 12% 7% 6% 5% 5% 5% 7%
x264: i8c dc,h,v,p: 53% 24% 20% 3%
x264: Weighted P-Frames: Y:0.4% UV:0.0%
x264: kb/s:614.71
Profiler results:
frame - [100%] [avg time: 22.037 ms] [avg calls per frame: 1] [children: 48%] [unaccounted: 52%]
| scene->Preprocess - [17.9%] [avg time: 3.953 ms] [avg calls per frame: 1]
| video encoding and uploading - [30%] [avg time: 6.615 ms] [avg calls per frame: 1] [children: 29.8%] [unaccounted: 0.213%]
| | CopyResource - [0.449%] [avg time: 0.099 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [15.4%] [avg time: 3.402 ms] [avg calls per frame: 0]
| | call to encoder - [13.8%] [avg time: 3.043 ms] [avg calls per frame: 0]
| | sending stuff out - [0.109%] [avg time: 0.024 ms] [avg calls per frame: 0]
CPU Speed: 2394MHz
Aero is Disabled
Adapter 1
Adapter 2
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Using bitmap image
Using bitmap image
fps: 30
preset: superfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 7
x264: kb/s:614.71
Profiler results:
