OBS in Win10 it is freezing and then does not work anymore
zhuniqiAbedin
Hello OBS Support,
I have a new PC.
I7-11700KF with RTX 3070Suprim X.
I have streamed almost 2 weeks now and never occured an error.
Almost 2 days now I am facing with an error, which when I start stream then sometimes it is blocking OBS or I mean the Stream and need to restart the Stream to keep it up working.
I have looked into Logs but did not found something that can help me.
I checked GPU and CPU their temperature was 55C and use was around 35%.
So it cannot be my PC I think.
I have all the time 60Mbs Download and 35Mbs Upload Internet.
My stream Setting are 1600x900 with 6000 Kbps.
I use Nvidia NVEND H.264 New for encoder.
Preset: Quality,
Profile: High,
Gpu: 0
Max B-frames: 2,
But most of the times happens when I switch between scennes.
I have 2 of them.
1st Scenne: CS:GO with Game Capture within My Video Capture which is Logitech StreamCam.
2nd Scenne: A window where I show Chrome, recent followers, subs and other things.
But it happens not only when I switch between scennes sometimes it happens only if I stream CS.
In the attach are the logs when the Stream stopped.
  • 2022-04-11 21-11-56.txt
