Question / Help OBS Images Artifacts / glitches
DarkVoice
Hi,
I've been trying to stream Diablo 3 but all I get is a Pixelparty ;/ You can't see anything.
This is the Result of my Speedtest
http://www.speedtest.net/my-result/2970380938
This is how y Diablo 3 stream looks like
This are my OBS and Diablo3 Settings
My Computer Specs
i5 2.80 Quadcore
12GB RAM
Nvidia GeForec GTX470
Any Idea how to fix this?
Sapiens
You're trying to stream at 1080p using only 1 Mbps, a CPU that isn't up to the task and the ultrafast preset, so it's not surprising that the stream is a mess. Up your bitrate to ~2000 and downscale the stream to 720p or 540p. If performance is okay you should also try the superfast or veryfast presets.
