I never encountered any problems in OBS then, as of a week ago maybe it started to crash, it always seems to be from the same type of thing, when I switch to have it show a game capture. However, it doesn't not work every time, there are many times that it does but I just can't tell when it will or won't it is extremely unpredictable and frustrating. Any help would be appreciated!
This crash appears to have occured in the 'c:\windows\system32\nvwgf2um.dll' module.
Fault address: 0D3C34E7 (c:\windows\system32\nvwgf2um.dll)
OBS version: Open Broadcaster Software v0.651b
CPU: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Crashing thread stack trace:
0BD4F8D0 0D3C34E7 00000000 0E020048 0E020048 0E12CE30 nvwgf2um.dll!0xd3c34e7
0BD4F8E0 0D3C3658 0E020048 00000000 2092F170 00000000 nvwgf2um.dll!0xd3c3658
0BD4F900 0D57FB95 0E020048 1223AA1C 00000000 634BD07C nvwgf2um.dll!0xd57fb95
0BD4FE0C 0CE98E00 00000000 0E0DB8F8 070A14F0 0E0200E0 nvwgf2um.dll!0xce98e00
0BD4FE3C 0CE95CE1 0E0E9360 0BD4FE90 0D6E7360 0E0DB8F8 nvwgf2um.dll!0xce95ce1
0BD4FE54 0D3CC1B5 0E0DB8F8 D0F27B26 00000000 0E0E9360 nvwgf2um.dll!0xd3cc1b5
0BD4FE60 0D6E7360 00000000 0BD4FEA8 76E8337A 070A14F0 nvwgf2um.dll!0xd6e7360
0BD4FE98 0D6E7488 070A14F0 0BD4FEE8 77E892E2 070A14F0 nvwgf2um.dll!0xd6e7488
0BD4FEA4 76E8337A 070A14F0 7C0891A5 00000000 00000000 kernel32.dll!0x76e8337a
0BD4FEB0 77E892E2 0D6E740C 070A14F0 00000000 00000000 ntdll.dll!0x77e892e2
0BD4FEF0 77E892B5 0D6E740C 070A14F0 00000000 00000000 ntdll.dll!0x77e892b5
A minidump was saved to C:\Users\Chris\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-05-14_3.dmp.
List of loaded modules:
Base Address Module
My most recent Log
16:15:05: CLR host plugin strings not found, dynamically loading 4 strings
16:15:05: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
16:15:05: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
16:15:05: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
16:15:05: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
16:15:05: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
16:15:06: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
16:15:07: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
16:15:16: Open Broadcaster Software v0.651b - 32bit (´・ω・`)
16:15:16: -------------------------------
16:15:16: CPU Name: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
16:15:16: CPU Speed: 2294MHz
16:15:16: Physical Memory: 4095MB Total, 3035MB Free
16:15:16: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
16:15:16: monitor 1: pos={0, 0}, size={1366, 768}
16:15:16: Windows Version: 6.1 Build 7601 S
16:15:16: Aero is Enabled
16:15:16: OBS Modules:
16:15:16: Base Address Module
16:15:16: 00B60000 OBS.exe
16:15:16: 63060000 OBSApi.dll
16:15:16: 6EAA0000 CLRHostPlugin.dll
16:15:16: 64A20000 DShowPlugin.dll
16:15:16: 6EE70000 GraphicsCapture.dll
16:15:16: 044E0000 NoiseGate.dll
16:15:16: 6F190000 PSVPlugin.dll
16:15:16: 6E3B0000 scenesw.dll
16:15:16: ------------------------------------------
16:15:16: Adapter 1
16:15:16: Video Adapter: NVIDIA GeForce GT 650M
16:15:16: Video Adapter Dedicated Video Memory: 1019019264
16:15:16: Video Adapter Shared System Memory: 2901571584
16:15:16: Video Adapter Output 1: pos={0, 0}, size={1366, 768}, attached=true
16:15:16: Adapter 2
16:15:16: Using fixed low latency mode, factor 20
16:15:16: =====Stream Start: 2015-05-14, 16:15:16===============================================
16:15:16: Multithreaded optimizations: On
16:15:16: Base resolution: 1366x768
16:15:16: Output resolution: 1364x768
16:15:16: Nvidia optimus detected, second adapter selected, ignoring useless second adapter, I guess.
16:15:16: Loading up D3D10 on NVIDIA GeForce GT 650M (Adapter 1)...
16:15:17: ------------------------------------------
16:15:17: Audio Format: 48000 Hz
16:15:17: Audio Channels: 2 Ch
16:15:17: Playback device Default
16:15:17: Using desktop audio input: Speakers (Sound Blaster Recon3Di)
16:15:17: Global Audio time adjust: 0
16:15:17: Using auxilary audio input: Microphone Array (Sound Blaster Recon3Di)
16:15:17: Mic time offset: 0
16:15:17: Audio Encoding: AAC
16:15:17: bitrate: 128
16:15:17: device: Integrated Webcam,
16:15:17: device id \\?\usb#vid_064e&pid_8128&mi_00#7&ae4b2c1&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
16:15:17: chosen type: MJPG, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
16:15:17: use buffering: false - 0, fourCC: 'MJPG'
16:15:17: audio device: Disable,
16:15:17: audio device id Disabled,
16:15:17: audio time offset 0,
16:15:17:
16:15:17: Using directshow input
16:15:17: Using graphics capture
16:15:17: Trying to hook process: Cube.exe
16:15:17: Scene buffering time set to 700
16:15:17: x264: MB rate (247680) > level limit (245760)
16:15:17: Video Encoding: x264
16:15:17: fps: 60
16:15:17: width: 1364, height: 768
16:15:17: preset: veryfast
16:15:17: profile: main
16:15:17: keyint: 120
16:15:17: CBR: yes
16:15:17: CFR: yes
16:15:17: max bitrate: 3500
16:15:17: buffer size: 3500
16:15:17: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
16:15:19: CLRHost:: Browser 1: Status message:
Base Address Module
My most recent Log
16:15:16: Adapter 1
16:15:16: Adapter 2
16:15:17:
16:15:17: fps: 60
16:15:17: CBR: yes
16:15:17: CFR: yes
