OBS GUI is not showing when opening the software, and OBS is running in the background.
The Changer
So, when I try to open up OBS on my pc, nothing appears. I check the task manager to see that OBS is running, but in the background, and I have no way to get the obs window to appear. OBS was working just fine last night, but all of a sudden it won't open up. There is no icon on the system tray or in the taskbar.
  • 2022-11-28 13-58-46.txt
.norman.
this happens to me occasionally. typically i can end the task and relaunch OBS without any problems. if it still won't open for me, i will open it without admin, close it, then relaunch as admin and it will open.
