OBS freezing during stream on BRB screen
seePyou
Very often OBS will freeze when I switch to BRB screen while streaming. The effect is that the stream will terminate (i don't know the technical reason, whether it's because there is no more data streaming or whether the program is so frozen that there is no data streaming, cannot say exactly and for sure) and the OBS application will remain on screen but frozen and I will have to use the Task Manager to terminate it.
I have attached a log of the last time this happened, where I started a stream at 17:55 local time and OSB froze at 19:56 local time and I had to terminate it.
As far as I know, this only happens with the BRB scene.
Any assistance would be appreciated.
  • 2024-03-30 17-54-14.txt
