OBS Freezes Randomly
Hello! My OBS has been freezing randomly the last couple of weeks. The stream will be fine for an hour or so then everything freezes. Upon using task manager to close the program and reopening OBS and going live, it seems to freeze again within a minute or so. I suspect it is a memory leak but do not know how to fix it. When I completely reinstalled OBS it worked fine for a few days, then the freeze happened again. Attached are two logs from my the streams that froze. I think I have the right logs. Any help is appreciated!
  • 2024-08-12 21-49-40.txt
  • 2024-08-12 21-47-11.txt
qhobbes
1. The Hardware-accelerated GPU scheduling ("HAGS") feature in Windows is currently known to cause performance and capture issues with OBS, games and overlay tools. It's an experimental feature and we recommend disabling it via these instructions.
2. Multiple Game Capture sources are usually not needed, and can sometimes interfere with each other (scenes 'Main Lobby', 'Close Up Cam', 'PUBG Lobby', 'Piano Lobby 2', 'Internet Lobby 1', '420 Main Lobby', '420 Game Screen' and '420 Closeup'). You can use the same Game Capture for all your games. If you change games often, try out the hotkey mode, which lets you press a key to select your active game. If you play games in fullscreen, use 'Capture any fullscreen application' mode.
If that doesn't fix it, try disabling Twitch Multitrack Video/Enhanced Broadcasting.
