DerBlackAngel
Hello
I have a problem here that has been going on through several versions of OBS and is particularly noticeable with graphics-intensive applications. When OBS is running and I start a stream and then a game, OBS freezes so that I can no longer change the sources but the stream continues to run normally. If I click around a lot, OBS crashes completely at some point.
I have already tried
- a clean installation
- Switched to OBS via steam
- Updated the graphics card driver
Nothing helps, googling the error doesn't help either as nobody seems to have this problem.
I add some logs from OBS but unfortunately there are no crash reports, the folder remains empty.
I've had this problem for a few months now.
