Question / Help OBS FPS PROBLEM
boshy32
Hello. I'm trying to stream CS:GO but the stream is extremely choppy. I have no idea why. My computer is great and my internet dl/up speeds are good. I spent 3k on my pc with the goal of being able to stream and i still can't do it. Please help.
I think i know the problem though. But i just don't know how to fix it. No matter what i set my fps to be on the stream, it won't go past around 14 fps. It doesn't matter if i set it to 50,60, or even 100. It will stay at around 10 fps.
When i look at the log, the only thing that looks fishy about it is that the number of frames that lagged is around 90%. That's waaaay too much. I don't know why though. PLEASE HELP!
My parts:
Video Cards: 2 GeForce GTX 680's
Memory: 32 GB (16 GB USABLE) RAM
Processor: AMD FX(tm)-8350 Eight-Core Processor
Window Edition: Windows 7
System Type: 64-bit Operating System
My internet:
Upload Speed: ~11
Download Speed: ~65
OBS Logs:
In the posted attachements.
Please help me!!! Thanks.
  • 2013-07-03-2352-13.log
  • 2013-07-05-1441-31.log
alpinlol
cant really find the stupid aero settings nor the scenes.
i assume you turned aero off and use game capture if not do so.
also you should be able to stream 720p@60fps without a problem. would leave the bitrate at 3000 also the buffer and quality 7.
http://testmy.net/
choose the cloesest server to where you live
even tho you are only lagging 99% of your frames and not dropping, but still.
might also consider trying to use custom x264 encoder settings opencl=true
alpinlol
looks like this stream crashing is a common problem right now I've seen a lot posts about it, try forum search for it if theres not already a answer given to that problem since that problem has never happened to me.
still post the new log after the changes to see what changed especially in case of the crash.
Krazy
Town drunk
Are you talking about an actual program crash or just a disconnect? Those are two very different things.
boshy32
alpin: i can't attach it for some reason.. "Temporary folder could not be found. Please check your PHP installation." wtf..
krazy: i keep disconnecting. The program OBS itself says that it's still online, but then when i look on twitch, it's offline. it disconnects for NO reason. OBS still has the "stop stream" option even when it's actually offline on twitch that is.
Kharay
That may simply be a disconnect on Twitch's end that OBS simply has not been informed of or something. Could you post a log of a session that seemed to have disconnected like that?
R1CH
You have a large number of frame drops. Try changing servers or reducing your bitrate.
boshy32
15:52:17: Open Broadcaster Software v0.542b - 64bit ( ^ω^)
15:52:17: -------------------------------
15:52:17: CPU Name: AMD FX(tm)-8350 Eight-Core Processor
15:52:17: CPU Speed: 4013MHz
15:52:17: Physical Memory: 16384MB Total, 14170MB Free
15:52:17: stepping id: 0, model 2, family 15, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 8, total cores 4
15:52:17: monitor 1: pos={0, 0}, size={1920, 1080}
15:52:17: Windows Version: 6.1 Build 7601 S
15:52:17: Aero is Disabled
15:52:17: OBS Modules:
15:52:17: Base Address Module
15:52:17: 000000003F520000 OBS.exe
15:52:17: 00000000EDD40000 OBSApi.dll
15:52:17: 00000000F8100000 DShowPlugin.dll
15:52:17: 00000000F80D0000 GraphicsCapture.dll
15:52:17: 00000000F80B0000 NoiseGate.dll
15:52:17: 00000000F8090000 PSVPlugin.dll
15:52:17: ------------------------------------------
15:52:17: Adapter 1
15:52:17: Video Adapter: NVIDIA GeForce GTX 680
15:52:17: Video Adapter Dedicated Video Memory: 4203413504
15:52:17: Video Adapter Shared System Memory: 4026531840
15:52:17: =====Stream Start: 2013-07-22, 15:52:17===============================================
15:52:17: Multithreaded optimizations: On
15:52:17: Base resolution: 1280x720
15:52:17: Output resolution: 1280x720
15:52:17: Loading up D3D10...
15:52:17: Playback device {0.0.0.00000000}.{cc7f7ada-05e4-4e4c-ba4d-68e19eea196f}
15:52:17: Using desktop audio input: Speakers (Plantronics GameCom 780)
15:52:17: Using auxilary audio input: Microphone (Plantronics GameCom 780)
15:52:17: Audio Encoding: AAC
15:52:17: bitrate: 128
15:52:17: Video Encoding: x264
15:52:17: fps: 60
15:52:17: width: 1280, height: 720
15:52:17: preset: superfast
15:52:17: CBR: no
15:52:17: CFR: no
15:52:17: max bitrate: 2000
15:52:17: buffer size: 2000
15:52:17: quality: 7
15:52:18: Using RTMP service: Twitch / Justin.tv
15:52:18: Server selection: rtmp://live-mia.justin.tv/app
15:52:21: SO_SNDBUF was at 8192
15:52:21: SO_SNDBUF is now 65536
15:52:40: Total frames rendered: 675, number of frames that lagged: 293 (43.41%) (it's okay for some frames to lag)
15:52:40: RTMPPublisher::SocketLoop: Aborting due to bStopping
15:52:40: Number of times waited to send: 0, Waited for a total of 0 bytes
15:52:40: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:52:40: =====Stream End: 2013-07-22, 15:52:40=================================================
15:53:49: =====Stream Start: 2013-07-22, 15:53:49===============================================
15:53:49: Multithreaded optimizations: On
15:53:49: Base resolution: 1280x720
15:53:49: Output resolution: 1280x720
15:53:49: ------------------------------------------
15:53:49: Loading up D3D10...
15:53:50: Playback device {0.0.0.00000000}.{cc7f7ada-05e4-4e4c-ba4d-68e19eea196f}
15:53:50: ------------------------------------------
15:53:50: Using desktop audio input: Speakers (Plantronics GameCom 780)
15:53:50: Using auxilary audio input: Microphone (Plantronics GameCom 780)
15:53:50: Audio Encoding: AAC
15:53:50: bitrate: 128
15:53:50: Video Encoding: x264
15:53:50: fps: 60
15:53:50: width: 1280, height: 720
15:53:50: preset: superfast
15:53:50: CBR: no
15:53:50: CFR: no
15:53:50: max bitrate: 2000
15:53:50: buffer size: 2000
15:53:50: quality: 7
15:54:24: Total frames rendered: 860, number of frames that lagged: 440 (51.16%) (it's okay for some frames to lag)
15:54:25: =====Stream End: 2013-07-22, 15:54:25=================================================
15:54:27: =====Stream Start: 2013-07-22, 15:54:27===============================================
15:54:27: Multithreaded optimizations: On
15:54:27: Base resolution: 1280x720
15:54:27: Output resolution: 1280x720
15:54:27: ------------------------------------------
15:54:27: Loading up D3D10...
15:54:28: Playback device {0.0.0.00000000}.{cc7f7ada-05e4-4e4c-ba4d-68e19eea196f}
15:54:28: ------------------------------------------
15:54:28: Using desktop audio input: Speakers (Plantronics GameCom 780)
15:54:28: Using auxilary audio input: Microphone (Plantronics GameCom 780)
15:54:28: Audio Encoding: AAC
15:54:28: bitrate: 128
15:54:28: Video Encoding: x264
15:54:28: fps: 60
15:54:28: width: 1280, height: 720
15:54:28: preset: superfast
15:54:28: CBR: no
15:54:28: CFR: no
15:54:28: max bitrate: 2000
15:54:28: buffer size: 2000
15:54:28: quality: 7
15:55:26: Total frames rendered: 1241, number of frames that lagged: 765 (61.64%) (it's okay for some frames to lag)
15:55:26: =====Stream End: 2013-07-22, 15:55:26=================================================
15:55:57: =====Stream Start: 2013-07-22, 15:55:57===============================================
15:55:57: Multithreaded optimizations: On
15:55:57: Base resolution: 1280x720
15:55:57: Output resolution: 1280x720
15:55:57: ------------------------------------------
15:55:57: Loading up D3D10...
15:55:57: Playback device {0.0.0.00000000}.{cc7f7ada-05e4-4e4c-ba4d-68e19eea196f}
15:55:57: Using desktop audio input: Speakers (Plantronics GameCom 780)
15:55:57: Using auxilary audio input: Microphone (Plantronics GameCom 780)
15:55:57: Audio Encoding: AAC
15:55:57: bitrate: 128
15:55:57: Video Encoding: x264
15:55:57: fps: 60
15:55:57: width: 1280, height: 720
15:55:57: preset: superfast
15:55:57: CBR: no
15:55:57: CFR: no
15:55:57: max bitrate: 2000
15:55:57: buffer size: 2000
15:55:57: quality: 7
15:56:06: Total frames rendered: 222, number of frames that lagged: 123 (55.41%) (it's okay for some frames to lag)
15:56:07: =====Stream End: 2013-07-22, 15:56:07=================================================
15:56:17: =====Stream Start: 2013-07-22, 15:56:17===============================================
15:56:17: Multithreaded optimizations: On
15:56:17: Base resolution: 1280x720
15:56:17: Output resolution: 1280x720
15:56:17: ------------------------------------------
15:56:17: Loading up D3D10...
15:56:17: Playback device {0.0.0.00000000}.{cc7f7ada-05e4-4e4c-ba4d-68e19eea196f}
15:56:17: Using desktop audio input: Speakers (Plantronics GameCom 780)
15:56:17: Using auxilary audio input: Microphone (Plantronics GameCom 780)
15:56:17: Audio Encoding: AAC
15:56:17: bitrate: 128
15:56:17: Video Encoding: x264
15:56:17: fps: 60
15:56:17: width: 1280, height: 720
15:56:17: preset: superfast
15:56:17: CBR: no
15:56:17: CFR: no
15:56:17: max bitrate: 2000
15:56:17: buffer size: 2000
15:56:17: quality: 7
15:56:19: Using RTMP service: Twitch / Justin.tv
15:56:19: Server selection: rtmp://live-mia.justin.tv/app
15:56:22: SO_SNDBUF was at 8192
15:56:22: SO_SNDBUF is now 65536
15:56:23: Using graphics capture
15:56:29: SharedTexCapture hooked
15:56:48: GraphicsCaptureSource::NewCapture: eliminating old capture
15:56:48: SharedTexCapture hooked
Warning -- SharedTexCapture::Init: Could not open file mapping: 2
15:57:16: SharedTexCapture hooked
15:57:36: GraphicsCaptureSource::NewCapture: eliminating old capture
15:57:36: SharedTexCapture hooked
15:58:06: GraphicsCaptureSource::NewCapture: eliminating old capture
15:58:06: SharedTexCapture hooked
15:58:47: GraphicsCaptureSource::NewCapture: eliminating old capture
15:58:47: SharedTexCapture hooked
16:00:10: Capture window 0x001103FC invalid or changing, terminating capture
16:00:15: Total frames rendered: 3228, number of frames that lagged: 3103 (96.13%) (it's okay for some frames to lag)
16:00:15: RTMPPublisher::SocketLoop: Aborting due to loop exit
16:00:15: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
16:00:15: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
16:00:15: Number of times waited to send: 59, Waited for a total of 218787 bytes
16:00:15: Number of b-frames dropped: 250 (8%), Number of p-frames dropped: 592 (19%), Total 842 (27%)
16:00:15: =====Stream End: 2013-07-22, 16:00:15=================================================
16:06:36: =====Stream Start: 2013-07-22, 16:06:36===============================================
16:06:36: Multithreaded optimizations: On
16:06:36: Base resolution: 1280x720
16:06:36: Output resolution: 1280x720
16:06:36: ------------------------------------------
16:06:36: Loading up D3D10...
16:06:37: Playback device {0.0.0.00000000}.{cc7f7ada-05e4-4e4c-ba4d-68e19eea196f}
16:06:37: ------------------------------------------
16:06:37: Using desktop audio input: Speakers (Plantronics GameCom 780)
16:06:37: Using auxilary audio input: Microphone (Plantronics GameCom 780)
16:06:37: Audio Encoding: AAC
16:06:37: bitrate: 128
16:06:37: Using graphics capture
16:06:37: Video Encoding: x264
16:06:37: fps: 60
16:06:37: width: 1280, height: 720
16:06:37: preset: superfast
16:06:37: CBR: no
16:06:37: CFR: yes
16:06:37: max bitrate: 1500
16:06:37: buffer size: 1500
16:06:37: quality: 5
16:06:38: Using RTMP service: Twitch / Justin.tv
16:06:38: Server selection: rtmp://live-mia.justin.tv/app
16:06:41: SO_SNDBUF was at 8192
16:06:41: SO_SNDBUF is now 65536
16:09:00: Total frames rendered: 3527, number of frames that lagged: 1906 (54.04%) (it's okay for some frames to lag)
16:09:00: Total duplicated frames: 5081 (144.06%)
16:09:00: RTMPPublisher::SocketLoop: Aborting due to bStopping
16:09:00: Number of times waited to send: 0, Waited for a total of 0 bytes
16:09:00: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:09:00: =====Stream End: 2013-07-22, 16:09:00=================================================
16:09:16:
16:09:16: Profiler results:
16:09:16:
16:09:16: ==============================================================
16:09:16: frame - [100%] [avg time: 47.937 ms (cpu time: avg 46.427 ms, total 452809 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.00626%]
16:09:16: | frame preprocessing and rendering - [94.4%] [avg time: 45.276 ms (cpu time: avg 44.468 ms, total 433698 ms)] [avg calls per frame: 1] [children: 0.00209%] [unaccounted: 94.4%]
16:09:16: | | scene->Preprocess - [0.00209%] [avg time: 0.001 ms (cpu time: avg 0.001 ms, total 15.6 ms)] [avg calls per frame: 1]
16:09:16: | video encoding and uploading - [5.54%] [avg time: 2.658 ms (cpu time: avg 1.953 ms, total 19047.7 ms)] [avg calls per frame: 1] [children: 4.61%] [unaccounted: 0.939%]
16:09:16: | | flush - [0.357%] [avg time: 0.171 ms (cpu time: avg 0.076 ms, total 748.805 ms)] [avg calls per frame: 1]
16:09:16: | | CopyResource - [0.0522%] [avg time: 0.025 ms (cpu time: avg 0.02 ms, total 202.8 ms)] [avg calls per frame: 0]
16:09:16: | | conversion to 4:2:0 - [0.0417%] [avg time: 0.02 ms (cpu time: avg 0.001 ms, total 15.6 ms)] [avg calls per frame: 0]
16:09:16: | | call to encoder - [4.09%] [avg time: 1.962 ms (cpu time: avg 1.833 ms, total 17877.7 ms)] [avg calls per frame: 1]
16:09:16: | | sending stuff out - [0.0626%] [avg time: 0.03 ms (cpu time: avg 0.011 ms, total 109.201 ms)] [avg calls per frame: 1]
16:09:16: | Convert444Threads - [215%] [avg time: 103.287 ms (cpu time: avg 1.214 ms, total 11840.5 ms)] [avg calls per frame: 1]
16:09:16:
^That's my recent log. I'm sorry, i couldn't upload the attachment for some reason "Temporary folder could not be found. Please check your PHP installation.".
anyways, here's a link to show you guys how choppy it is for some reason.. http://www.twitch.tv/boshy32/b/434339839
PLEASE HELP ME GUYS! I SPENT 3K ON A PC JUST TO STREAMMMM. <3
Kharay
I have no idea how you managed to get that many laggy frames on a PC that strong. To be honest, I'm inclined to say -- just start from scratch.
  • Close OBS
  • Click Start
  • Click Run
  • Type %AppData%\OBS
  • Hit <ENTER>
  • Empty this folder
  • Open OBS again... it will have reset completely.
Now, run an upload test at testmy.net/upload (pick a server near the one you've been streaming to, ideally both are near yourself obviously). OBS settings -- Source: Game Capture, Encode: CBR at ~80% of your real world upload rate (the testmy.net result), Video: 720p at 60 FPS. And leave any advanced settings alone for the time being.
Krazy
Town drunk
You should maybe also look into completely wiping out your GPU drivers and reinstalling them. Almost all of your high frame times are due to the stuff that has to be done on the GPU. Also check your background processes. There is simply no reason for your system to be struggling that hard.
Kharay
Agreed. If for some reason my earlier suggestion of simply resetting OBS does not solve the issue, please consider reinstalling the GPU drivers as Krazy said and also consider running a boot time virus scan.
boshy32
http://www.twitch.tv/boshy32/b/434457394 (SKIP TO LIKE 4 MINUTES WHICH IS WHEN I START PLAYING)
it doesn't look smooth but the quality is good.
I used the settings you gave me Kharay.
The stream didn't crash at all and the quality of the stream is great.
For some reason, I THINK it still is showing the stream at ~10 FPS even though i set it to show it at 60 FPS.
^Not sure why.
Im gonna post the log of my most recent stream (which is the link above)
20:33:25: Open Broadcaster Software v0.542b - 64bit ( ^ω^)
20:33:25: -------------------------------
20:33:25: CPU Name: AMD FX(tm)-8350 Eight-Core Processor
20:33:25: CPU Speed: 4013MHz
20:33:25: Physical Memory: 16384MB Total, 14527MB Free
20:33:25: stepping id: 0, model 2, family 15, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 8, total cores 4
20:33:25: monitor 1: pos={0, 0}, size={1920, 1080}
20:33:25: Windows Version: 6.1 Build 7601 S
20:33:25: Aero is Enabled
20:33:25: OBS Modules:
20:33:25: Base Address Module
20:33:25: 000000003F050000 OBS.exe
20:33:25: 00000000F74F0000 OBSApi.dll
20:33:25: 00000000F7E40000 DShowPlugin.dll
20:33:25: 00000000F7E10000 GraphicsCapture.dll
20:33:25: 00000000F80D0000 NoiseGate.dll
20:33:25: 00000000F7F50000 PSVPlugin.dll
20:33:25: ------------------------------------------
20:33:25: Adapter 1
20:33:25: Video Adapter: NVIDIA GeForce GTX 680
20:33:25: Video Adapter Dedicated Video Memory: 4203413504
20:33:25: Video Adapter Shared System Memory: 4026531840
20:33:25: =====Stream Start: 2013-07-22, 20:33:25===============================================
20:33:25: Multithreaded optimizations: On
20:33:25: Base resolution: 1280x720
20:33:25: Output resolution: 1280x720
20:33:25: Loading up D3D10...
20:33:25: Playback device {0.0.0.00000000}.{cc7f7ada-05e4-4e4c-ba4d-68e19eea196f}
20:33:25: Using desktop audio input: Speakers (Plantronics GameCom 780)
20:33:25: Using auxilary audio input: Microphone (Plantronics GameCom 780)
20:33:25: Audio Encoding: AAC
20:33:25: bitrate: 128
20:33:25: Using graphics capture
20:33:25: Video Encoding: x264
20:33:25: fps: 60
20:33:25: width: 1280, height: 720
20:33:25: preset: veryfast
20:33:25: CBR: yes
20:33:25: CFR: no
20:33:25: max bitrate: 4500
20:33:27: Using RTMP service: Twitch / Justin.tv
20:33:27: Server selection: rtmp://live-iad.justin.tv/app
20:33:29: SO_SNDBUF was at 8192
20:33:29: SO_SNDBUF is now 65536
20:33:35: SharedTexCapture hooked
20:34:02: GraphicsCaptureSource::NewCapture: eliminating old capture
20:34:02: SharedTexCapture hooked
20:34:44: GraphicsCaptureSource::NewCapture: eliminating old capture
20:34:44: SharedTexCapture hooked
20:34:55: GraphicsCaptureSource::NewCapture: eliminating old capture
20:34:55: SharedTexCapture hooked
20:35:30: GraphicsCaptureSource::NewCapture: eliminating old capture
20:35:30: SharedTexCapture hooked
20:36:13: GraphicsCaptureSource::NewCapture: eliminating old capture
20:36:13: SharedTexCapture hooked
20:38:38: GraphicsCaptureSource::NewCapture: eliminating old capture
20:38:38: SharedTexCapture hooked
20:39:09: GraphicsCaptureSource::NewCapture: eliminating old capture
20:39:09: SharedTexCapture hooked
20:40:32: GraphicsCaptureSource::NewCapture: eliminating old capture
20:40:32: SharedTexCapture hooked
20:40:44: GraphicsCaptureSource::NewCapture: eliminating old capture
20:40:44: SharedTexCapture hooked
20:41:54: Capture window 0x0009034A invalid or changing, terminating capture
20:41:57: Total frames rendered: 5839, number of frames that lagged: 5805 (99.42%) (it's okay for some frames to lag)
20:41:57: RTMPPublisher::SocketLoop: Aborting due to loop exit
20:41:57: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
20:41:57: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
20:41:57: Number of times waited to send: 7, Waited for a total of 28679 bytes
20:41:57: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:41:57: =====Stream End: 2013-07-22, 20:41:57=================================================
20:42:00:
20:42:00: Profiler results:
20:42:00:
20:42:00: ==============================================================
20:42:00: frame - [100%] [avg time: 87.566 ms (cpu time: avg 84.075 ms, total 490920 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.00343%]
20:42:00: | frame preprocessing and rendering - [96.7%] [avg time: 84.651 ms (cpu time: avg 82.155 ms, total 479703 ms)] [avg calls per frame: 1] [children: 0.00228%] [unaccounted: 96.7%]
20:42:00: | | scene->Preprocess - [0.00228%] [avg time: 0.002 ms (cpu time: avg 0.002 ms, total 15.601 ms)] [avg calls per frame: 1]
20:42:00: | video encoding and uploading - [3.33%] [avg time: 2.912 ms (cpu time: avg 1.918 ms, total 11200.9 ms)] [avg calls per frame: 1] [children: 2.4%] [unaccounted: 0.928%]
20:42:00: | | flush - [0.258%] [avg time: 0.226 ms (cpu time: avg 0.048 ms, total 280.803 ms)] [avg calls per frame: 1]
20:42:00: | | CopyResource - [0.032%] [avg time: 0.028 ms (cpu time: avg 0.016 ms, total 93.602 ms)] [avg calls per frame: 0]
20:42:00: | | conversion to 4:2:0 - [0.016%] [avg time: 0.014 ms (cpu time: avg 0.002 ms, total 15.6 ms)] [avg calls per frame: 0]
20:42:00: | | call to encoder - [1.89%] [avg time: 1.658 ms (cpu time: avg 1.661 ms, total 9703.27 ms)] [avg calls per frame: 0]
20:42:00: | | sending stuff out - [0.198%] [avg time: 0.173 ms (cpu time: avg 0.152 ms, total 889.208 ms)] [avg calls per frame: 0]
20:42:00: | Convert444Threads - [200%] [avg time: 175.106 ms (cpu time: avg 1.327 ms, total 7753.25 ms)] [avg calls per frame: 1]
20:42:00:
AGAIN, THE "number of frames that lagged: 5805 (99.42%)" IS AT 99 PERCENT. I have NO idea why. I am hesitant to reinstall my GPU drivers as i do not know how to do so. :(
Krazy
Town drunk
And if you REALLY want to be sure, use a tool called Driver Sweeper after you have uninstalled your drivers.
boshy32
it looks a lot better after reinstalling my drivers... but it still doesn't look like it's running @ 60 fps at all. more like ~20..
also, my stream keeps disconnecting 2-3 minutes after i start it almost every time. on the OBS Broadcaster it shows that it's still streaming when it's not....
bumppp pleaeseee..
boshy32
00:16:33: Open Broadcaster Software v0.542b - 64bit ( ^ω^)
00:16:33: -------------------------------
00:16:33: CPU Name: AMD FX(tm)-8350 Eight-Core Processor
00:16:33: CPU Speed: 4013MHz
00:16:33: Physical Memory: 16384MB Total, 13089MB Free
00:16:33: stepping id: 0, model 2, family 15, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 8, total cores 4
00:16:33: monitor 1: pos={0, 0}, size={1920, 1080}
00:16:33: Windows Version: 6.1 Build 7601 S
00:16:33: Aero is Enabled
00:16:33: OBS Modules:
00:16:33: Base Address Module
00:16:33: 000000003F1A0000 OBS.exe
00:16:33: 00000000EBB30000 OBSApi.dll
00:16:33: 00000000F2BB0000 DShowPlugin.dll
00:16:33: 00000000F2B80000 GraphicsCapture.dll
00:16:33: 00000000F85C0000 NoiseGate.dll
00:16:33: 00000000F2B60000 PSVPlugin.dll
00:16:33: ------------------------------------------
00:16:33: Adapter 1
00:16:33: Video Adapter: NVIDIA GeForce GTX 680
00:16:33: Video Adapter Dedicated Video Memory: 4224385024
00:16:33: Video Adapter Shared System Memory: 4026531840
00:16:33: Adapter 2
00:16:33: Video Adapter Dedicated Video Memory: 4224516096
00:16:33: =====Stream Start: 2013-07-23, 00:16:33===============================================
00:16:33: Multithreaded optimizations: On
00:16:33: Base resolution: 1280x720
00:16:33: Output resolution: 1280x720
00:16:33: Loading up D3D10...
00:16:33: Playback device {0.0.0.00000000}.{cc7f7ada-05e4-4e4c-ba4d-68e19eea196f}
00:16:33: Using desktop audio input: Speakers (Plantronics GameCom 780)
00:16:34: ------------------------------------------
00:16:34: Using auxilary audio input: Microphone (Plantronics GameCom 780)
00:16:34: Audio Encoding: AAC
00:16:34: bitrate: 128
00:16:34: Using graphics capture
00:16:34: Video Encoding: x264
00:16:34: fps: 60
00:16:34: width: 1280, height: 720
00:16:34: preset: veryfast
00:16:34: CBR: yes
00:16:34: CFR: no
00:16:34: max bitrate: 4500
00:16:36: SharedTexCapture hooked
00:16:37: Using RTMP service: Twitch / Justin.tv
00:16:37: Server selection: rtmp://live-iad.justin.tv/app
00:16:38: SO_SNDBUF was at 8192
00:16:38: SO_SNDBUF is now 65536
00:16:47: GraphicsCaptureSource::NewCapture: eliminating old capture
00:16:47: SharedTexCapture hooked
00:17:17: GraphicsCaptureSource::NewCapture: eliminating old capture
00:17:17: SharedTexCapture hooked
00:18:52: GraphicsCaptureSource::NewCapture: eliminating old capture
00:18:52: SharedTexCapture hooked
00:19:00: GraphicsCaptureSource::NewCapture: eliminating old capture
00:19:00: SharedTexCapture hooked
00:22:34: GraphicsCaptureSource::NewCapture: eliminating old capture
00:22:34: SharedTexCapture hooked
00:23:25: GraphicsCaptureSource::NewCapture: eliminating old capture
00:23:25: SharedTexCapture hooked
00:32:55: Total frames rendered: 14675, number of frames that lagged: 13457 (91.70%) (it's okay for some frames to lag)
00:32:55: okay, this is strange
00:32:55: RTMPPublisher::SocketLoop: Aborting due to loop exit
00:32:55: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
00:32:55: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
00:32:55: Number of times waited to send: 15, Waited for a total of 53594 bytes
00:32:55: Number of b-frames dropped: 24 (0.16%), Number of p-frames dropped: 39 (0.27%), Total 63 (0.43%)
00:32:55: =====Stream End: 2013-07-23, 00:32:55=================================================
00:32:56: =====Stream Start: 2013-07-23, 00:32:56===============================================
00:32:56: Multithreaded optimizations: On
00:32:56: Base resolution: 1280x720
00:32:56: Output resolution: 1280x720
00:32:56: ------------------------------------------
00:32:56: Loading up D3D10...
00:32:56: Playback device {0.0.0.00000000}.{cc7f7ada-05e4-4e4c-ba4d-68e19eea196f}
00:32:56: Using desktop audio input: Speakers (Plantronics GameCom 780)
00:32:56: Using auxilary audio input: Microphone (Plantronics GameCom 780)
00:32:56: Audio Encoding: AAC
00:32:56: bitrate: 128
00:32:56: Using graphics capture
00:32:56: Video Encoding: x264
00:32:56: fps: 60
00:32:56: width: 1280, height: 720
00:32:56: preset: veryfast
00:32:56: CBR: yes
00:32:56: CFR: no
00:32:56: max bitrate: 4500
00:32:59: Using RTMP service: Twitch / Justin.tv
00:32:59: Server selection: rtmp://live-iad.justin.tv/app
00:33:00: SO_SNDBUF was at 8192
00:33:00: SO_SNDBUF is now 65536
00:33:01: SharedTexCapture hooked
00:33:07: GraphicsCaptureSource::NewCapture: eliminating old capture
00:33:07: SharedTexCapture hooked
00:38:56: Total frames rendered: 5407, number of frames that lagged: 4936 (91.29%) (it's okay for some frames to lag)
00:38:56: RTMPPublisher::SocketLoop: Aborting due to loop exit
00:38:56: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
00:38:56: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
00:38:56: Number of times waited to send: 2, Waited for a total of 8208 bytes
00:38:56: Number of b-frames dropped: 12 (0.23%), Number of p-frames dropped: 12 (0.23%), Total 24 (0.45%)
00:38:56: =====Stream End: 2013-07-23, 00:38:56=================================================
00:39:08: =====Stream Start: 2013-07-23, 00:39:08===============================================
00:39:08: Multithreaded optimizations: On
00:39:08: Base resolution: 1280x720
00:39:08: Output resolution: 1280x720
00:39:08: ------------------------------------------
00:39:08: Loading up D3D10...
00:39:08: Playback device {0.0.0.00000000}.{cc7f7ada-05e4-4e4c-ba4d-68e19eea196f}
00:39:08: Using desktop audio input: Speakers (Plantronics GameCom 780)
00:39:08: Using auxilary audio input: Microphone (Plantronics GameCom 780)
00:39:08: Audio Encoding: AAC
00:39:08: bitrate: 128
00:39:08: Using graphics capture
00:39:08: Video Encoding: x264
00:39:08: fps: 60
00:39:08: width: 1280, height: 720
00:39:08: preset: veryfast
00:39:08: CBR: yes
00:39:08: CFR: no
00:39:08: max bitrate: 3500
00:39:11: Using RTMP service: Twitch / Justin.tv
00:39:11: Server selection: rtmp://live-iad.justin.tv/app
00:39:12: SharedTexCapture hooked
00:39:12: SO_SNDBUF was at 8192
00:39:12: SO_SNDBUF is now 65536
00:40:25: Total frames rendered: 1122, number of frames that lagged: 1051 (93.67%) (it's okay for some frames to lag)
00:40:25: RTMPPublisher::SocketLoop: Aborting due to loop exit
00:40:25: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
00:40:25: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
00:40:25: Number of times waited to send: 2, Waited for a total of 8194 bytes
00:40:25: Number of b-frames dropped: 9 (0.89%), Number of p-frames dropped: 20 (2%), Total 29 (2.9%)
00:40:25: =====Stream End: 2013-07-23, 00:40:25=================================================
00:40:26: =====Stream Start: 2013-07-23, 00:40:26===============================================
00:40:26: Multithreaded optimizations: On
00:40:26: Base resolution: 1280x720
00:40:26: Output resolution: 1280x720
00:40:26: ------------------------------------------
00:40:26: Loading up D3D10...
00:40:26: Playback device {0.0.0.00000000}.{cc7f7ada-05e4-4e4c-ba4d-68e19eea196f}
00:40:26: Using desktop audio input: Speakers (Plantronics GameCom 780)
00:40:26: Using auxilary audio input: Microphone (Plantronics GameCom 780)
00:40:26: Audio Encoding: AAC
00:40:26: bitrate: 128
00:40:26: Using graphics capture
00:40:27: ------------------------------------------
00:40:27: Video Encoding: x264
00:40:27: fps: 60
00:40:27: width: 1280, height: 720
00:40:27: preset: veryfast
00:40:27: CBR: yes
00:40:27: CFR: no
00:40:27: max bitrate: 3500
00:40:29: Using RTMP service: Twitch / Justin.tv
00:40:29: Server selection: rtmp://live-iad.justin.tv/app
00:40:30: SharedTexCapture hooked
00:40:30: SO_SNDBUF was at 8192
00:40:30: SO_SNDBUF is now 65536
00:55:41: Capture window 0x00180458 invalid or changing, terminating capture
00:55:43: Total frames rendered: 16439, number of frames that lagged: 12509 (76.09%) (it's okay for some frames to lag)
00:55:43: RTMPPublisher::SocketLoop: Aborting due to loop exit
00:55:43: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
00:55:43: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
00:55:43: Number of times waited to send: 2, Waited for a total of 8208 bytes
00:55:43: Number of b-frames dropped: 5 (0.031%), Number of p-frames dropped: 6 (0.037%), Total 11 (0.067%)
00:55:43: =====Stream End: 2013-07-23, 00:55:43=================================================
00:55:44:
00:55:44: Profiler results:
00:55:44:
00:55:44: ==============================================================
00:55:44: frame - [100%] [avg time: 59.974 ms (cpu time: avg 58.794 ms, total 2.21322e+006 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.00667%]
00:55:44: | frame preprocessing and rendering - [96.1%] [avg time: 57.653 ms (cpu time: avg 56.755 ms, total 2.13645e+006 ms)] [avg calls per frame: 1] [children: 0.00333%] [unaccounted: 96.1%]
00:55:44: | | scene->Preprocess - [0.00333%] [avg time: 0.002 ms (cpu time: avg 0 ms, total 31.2 ms)] [avg calls per frame: 1]
00:55:44: | video encoding and uploading - [3.86%] [avg time: 2.317 ms (cpu time: avg 2.037 ms, total 76690.1 ms)] [avg calls per frame: 1] [children: 3.6%] [unaccounted: 0.263%]
00:55:44: | | flush - [0.222%] [avg time: 0.133 ms (cpu time: avg 0.07 ms, total 2652.02 ms)] [avg calls per frame: 1]
00:55:44: | | CopyResource - [0.0484%] [avg time: 0.029 ms (cpu time: avg 0.027 ms, total 1029.61 ms)] [avg calls per frame: 0]
00:55:44: | | conversion to 4:2:0 - [0.02%] [avg time: 0.012 ms (cpu time: avg 0.005 ms, total 202.803 ms)] [avg calls per frame: 0]
00:55:44: | | call to encoder - [2.93%] [avg time: 1.756 ms (cpu time: avg 1.719 ms, total 64740.4 ms)] [avg calls per frame: 0]
00:55:44: | | sending stuff out - [0.382%] [avg time: 0.229 ms (cpu time: avg 0.189 ms, total 7129.24 ms)] [avg calls per frame: 0]
00:55:44: | Convert444Threads - [207%] [avg time: 123.859 ms (cpu time: avg 1.591 ms, total 59920 ms)] [avg calls per frame: 1]
00:55:44:
the number of frames that lagged was over 90% as always... WHYYY!
