OBS Doesn't work with Minecraft
pinky_madinky
I used to be able to stream Minecraft perfectly fine but randomly last week I was unable to. When I launch the game and change to the scene to capture the game it crashes and gives me a message saying I either need to update graphics drivers or stop using my recording software. I have searched the internet for a solution but nothing has worked so if anyone knows any information about this issue please help. I'm attaching my OBS logs if that will provide any information.
  • 2025-09-09 17-32-45.txt
qhobbes
1. The Hardware-accelerated GPU scheduling ("HAGS") feature in Windows s currently known to cause performance and capture issues with OBS, games and overlay tools. It's an experimental feature and we recommend disabling it via these instructions.
2. Display and Game Capture Sources interfere with each other. Never put them in the same scene (Games, Roblox and minecraft).
3. Multiple Game Capture sources are usually not needed, and can sometimes interfere with each other (Games). You can use the same Game Capture for all your games. If you change games often, try out the hotkey mode, which lets you press a key to select your active game. If you play games in fullscreen, use 'Capture any fullscreen application' mode.
