Bug Report OBS crashing when trying to stream Rust
vitorgatti
I don't know if it is a problem with all Unity games, but this is happening to me with Rust.
I added both crash log and crash dump if any dev want to check the problem.
My laptop:
Windows 8.1 Single 64 bits
CPU: Intel(R) Core(TM) i7-3537U CPU @ 2.00GHz
GPU: NVIDIA Optimus GT 730M + Intel HD Graphics 4000
8GB RAM, 1TB HDD
OBS version: 0.60b (latest)
NVIDIA driver version: 332.21 (latest stable)
I can stream heavier games and there is no problem.
I already tried forcing running the game with the NVIDIA discrete card, tried running as Administrator, and it doesn't work. When I try to preview the stream, OBS crashes.
Tried with Window Capture, Game Capture and even Monitor Capture.
Thanks in advance!
  • OBSCrashDump2014-02-14_1.dmp
  • OBSCrashLog2014-02-14_1.txt
R1CH
Laptops are known to cause random crashes like this with their multi-GPU setups due to driver bugs and such. There isn't much you can do other than try other capture methods.
vitorgatti
But no useful crash information can be get with the crashlog and dumplog?
Well, I updated the NVIDIA drivers to the latest Beta and forced, in NVIDIA Settings, to only use the NVIDIA discrete card and ignore the Intel HD Graphics. Streaming Rust is working now.
Not what I wanted to do to fix this problem, but it's working.
Thanks
dodgepong
Administrator
Community Helper
OBS does have a bug right now with Optimus laptops that will be fixed in the next version.
