Also crashed when i tried to stream.
19:27:15: Server Ping plugin strings not found, dynamically loading 24 strings
19:28:25: Failed loading CUDA dll
19:29:13: Settings::Video: Enabling Aero
19:38:07: Open Broadcaster Software v0.638b - 64bit ( ^ω^)
19:38:07: -------------------------------
19:38:07: CPU Name: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
19:38:07: CPU Speed: 3500MHz
19:38:07: Physical Memory: 8086MB Total, 3712MB Free
19:38:07: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
19:38:07: monitor 1: pos={0, 0}, size={1920, 1080}
19:38:07: monitor 2: pos={1920, 0}, size={1280, 1024}
19:38:07: monitor 3: pos={3200, 0}, size={1024, 768}
19:38:07: Windows Version: 6.1 Build 7601 S
19:38:07: Aero is Disabled
19:38:07: OBS Modules:
19:38:07: Base Address Module
19:38:07: 000000003FF60000 OBS.exe
19:38:07: 00000000D5070000 OBSApi.dll
19:38:07: 00000000DB380000 DShowPlugin.dll
19:38:07: 00000000D9E10000 GraphicsCapture.dll
19:38:07: 00000000D9DE0000 NoiseGate.dll
19:38:07: 00000000D9DB0000 PSVPlugin.dll
19:38:07: 00000000D9D80000 ServerPingPlugin.dll
19:38:07: ------------------------------------------
19:38:07: Adapter 1
19:38:07: Video Adapter: AMD Radeon HD 7900 Series
19:38:07: Video Adapter Dedicated Video Memory: 3199393792
19:38:07: Video Adapter Shared System Memory: 3970967552
19:38:07: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
19:38:07: Video Adapter Output 2: pos={1920, 0}, size={1280, 1024}, attached=true
19:38:07: Adapter 2
19:38:07: Video Adapter: Intel(R) HD Graphics 4000
19:38:07: Video Adapter Dedicated Video Memory: 67108864
19:38:07: Video Adapter Shared System Memory: 1711276032
19:38:07: Video Adapter Output 1: pos={3200, 0}, size={1024, 768}, attached=true
19:38:07: =====Stream Start: 2014-12-13, 19:38:07===============================================
19:38:07: Multithreaded optimizations: On
19:38:07: Base resolution: 1920x1080
19:38:07: Output resolution: 1280x720
19:38:07: Loading up D3D10 on AMD Radeon HD 7900 Series (Adapter 1)...
19:38:07: Audio Format: 48000 Hz
19:38:07: Audio Channels: 2 Ch
19:38:07: Playback device {0.0.0.00000000}.{a6461985-126d-44eb-a4f3-ebe1643e9b6e}
19:38:07: Using desktop audio input: Speakers (Realtek High Definition Audio)
19:38:07: Global Audio time adjust: 0
19:38:07: Using auxilary audio input: Microphone (Siberia v2 Frost Blue)
19:38:07: Mic time offset: 0
19:38:07: Audio Encoding: AAC
19:38:07: bitrate: 128
19:38:07: Using graphics capture
19:38:07: Trying to hook process: Wow-64.exe
19:38:07: Scene buffering time set to 700
19:38:07: Found QSV hardware support
19:38:07: QSV version 1.8 using MFX_IMPL_HARDWARE_ANY | MFX_IMPL_VIA_D3D9 (actual: MFX_IMPL_HARDWARE3 | MFX_IMPL_VIA_D3D9)
19:38:07: Using 13 bitstreams and 16 frame buffers
19:38:07: Video Encoding: QSV
19:38:07: fps: 30
19:38:07: width: 1280, height: 720
19:38:07: target-usage: MFX_TARGETUSAGE_1_BEST_QUALITY
19:38:07: profile: MFX_PROFILE_AVC_HIGH
19:38:07: CBR: no
19:38:07: CFR: yes
19:38:07: max bitrate: 2500
19:38:07: buffer size: 2496
19:38:07: rate control: VBR
19:38:08: SharedTexCapture hooked
19:38:08: Audio timestamp for device 'Microphone (Siberia v2 Frost Blue)' was behind target timestamp by 20696760
19:38:09: Using RTMP service: Twitch
19:38:09: Server selection: rtmp://live-fra.twitch.tv/app
19:38:09: Interface: Realtek RTL8139/810x Family Fast Ethernet NIC (ethernet, 100 mbps)
19:38:10: Completed handshake with rtmp://live-fra.twitch.tv/app in 947 ms.
19:38:11: SO_SNDBUF was at 8192
19:38:11: SO_SNDBUF is now 65536
19:52:17: Error: all frames are in use
Warning -- Terminating QSVHelper.exe after timeout
Error: QSVHelper.exe was killed, encode failed
19:52:18: Error: all frames are in use
19:52:47: RTMPPublisher::SocketLoop: Received FD_CLOSE, 30028 ms since last send (buffer: 0 / 335872)
19:52:47: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
19:53:17: WARNING: Forcibly terminating a thread after 30001 ms timeout!
