OBS crashing on start up
Cryze
it crashes 99% of the time, sometimes it starts, if i just keep trying often enough, drivers are checked and updated, same for win
i run it on win10 22H2
AMD Ryzen 9 3900X 12-Core Processor 3.80 GHz
32,0 GB RAM
NVIDIA GeForce RTX 2080 SUPER, driver version: 31.0.15.4592
  • Crash 2023-10-27 22-43-04.txt
The GPU driver is causing the creash
If this don't solve the issue, it could be a plugin. Simple remove the plugin and all it's settings. Ask the creator of the plugin for more instructions.
Cryze
i noticed the crash happens when it tries to load scenes i imported from slobs - but it doesnt tell me what exactly the issue is.
i'm not aware of any plugins that im using
No idea how streamlabs desktop (slobs is gone) works internally as it's a separated development with customizations on their end. It could be something incompatible or calling something they have on their end and is not standard (AKA plugin)
Cryze
but isnt that what the crash report should give some insight on?
i tried the clean resintall of the driver, did not change the issue
It tell you what could be the main issue. Some times it's a plugin causing the crash.
Try creating a new scene collection and create a basic one, like the one most complex you have. Test it. If all goes well, then the issue is in the scenes you're importing.
