Bug Report OBS crashing constantly
peruna
What is going on here? Up until recently OBS was working fine. Now suddenly OBS is acting like it is having a seizure everytime it is used. Only thing changed and that is seen in the logs is lavasoft (Antivir) - Is that causing the crashes? If so, it can be uninstalled.
This crash appears to have occured in the 'c:\windows\system32\lavasofttcpservice64.dll' module.
**** UNHANDLED EXCEPTION: c000001d
Fault address: 000000018000890B (c:\windows\system32\lavasofttcpservice64.dll)
OBS version: Open Broadcaster Software v0.651b
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Crashing thread stack trace:
000000ECF5F3E0D0 000000018000890B 000000ECF5F3E140 0000000000002736 0000000000000001 000000000000001F lavasofttcpservice64.dll!0x18000890b
000000ECF5F3E0F0 0000000180018768 000000ECF606D900 000000ECF606D900 0000000000000000 0000000000000000 lavasofttcpservice64.dll!0x180018768
000000ECF5F3E120 0000000180008838 0000000000000CDC 00007FFC5B3A3B01 0000000000000000 000000ECF3EA5800 lavasofttcpservice64.dll!0x180008838
000000ECF5F3E170 00007FFC5B39F881 000000EC00000000 000000ECF606D900 000000ECF5F3E400 00007FFC5AB51B1C libcef.dll!0x7ffc5b39f881
000000ECF5F3E1B0 00007FFC5B3A4116 0000000000000003 000000EC00000003 0000000000000000 000000ECF3EA22D0 libcef.dll!0x7ffc5b3a4116
000000ECF5F3E350 00007FFC5B3A0DAB FFFFFFFF00000000 000000ECF3EA22D0 0000000000000000 000000ECF5F3E540 libcef.dll!0x7ffc5b3a0dab
000000ECF5F3E380 00007FFC5B39935C 000000ECF5F3E6F0 FFFFFFFFFFFFFFFF 000000ECF3F33BC0 FFFFFFFFFFFFFFFF libcef.dll!0x7ffc5b39935c
000000ECF5F3E4F0 00007FFC5B398FF9 FFFFFFFFFFFFFFFF 000000ECF5F3E6F0 000000ECF604DA00 FFFFFFFFFFFFFFFF libcef.dll!0x7ffc5b398ff9
000000ECF5F3E6B0 00007FFC5B399691 00007FFC5B398F40 FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF libcef.dll!0x7ffc5b399691
000000ECF5F3E740 00007FFC5B3998C7 FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF libcef.dll!0x7ffc5b3998c7
000000ECF5F3E7A0 00007FFC5AB27F59 000000ECF3F3D8C0 000000EC00000000 000000ECF3EA34D0 000000EC0005C6C4 libcef.dll!0x7ffc5ab27f59
000000ECF5F3F080 00007FFC5AB27383 000000ECF3EA2480 000000ECF3EA34D0 0000000000000000 000000ECF3EA2480 libcef.dll!0x7ffc5ab27383
000000ECF5F3F130 00007FFC5AB549EB 00000000115DC530 00000000169069B8 0000000000000000 00007FFC5AB27AFE libcef.dll!0x7ffc5ab549eb
000000ECF5F3F170 00007FFC5AB54F4B 000000ECF5F3F210 0000000000000000 0000000000000000 0000000000000000 libcef.dll!0x7ffc5ab54f4b
000000ECF5F3F1C0 00007FFC5AB404E0 000000EC00000000 0000000000000001 0000000000000010 000000ECF5F3F310 libcef.dll!0x7ffc5ab404e0
000000ECF5F3F1F0 00007FFC5AB27AD8 000000008007000E 00007FFC8D38105C 000000ECF5F3F310 0000000000000000 libcef.dll!0x7ffc5ab27ad8
000000ECF5F3F250 00007FFC5AE170DE 000000ECF3EA34D0 000000ECF3F3D8C0 000000ECF3ED1500 000000ECF5F3F3F8 libcef.dll!0x7ffc5ae170de
000000ECF5F3F3A0 00007FFC5AE1785F 0000000000000000 0000000000000000 000000EC00000006 000000ECF3EA34D0 libcef.dll!0x7ffc5ae1785f
000000ECF5F3F4E0 00007FFC5AB40B87 0000000000000000 0000000000000AF8 0000000000000AF8 0000000000000000 libcef.dll!0x7ffc5ab40b87
000000ECF5F3F630 00007FFC5AB256CF 0000000000000AF8 00007FFC5AB25620 000000ECF3F26D50 0000000000000000 libcef.dll!0x7ffc5ab256cf
000000ECF5F3F7A0 00007FFC8E4D13D2 00007FFC8E4D13B0 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ffc8e4d13d2
000000ECF5F3F7D0 00007FFC90315444 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ffc90315444
A minidump was saved to C:\Users\Kit\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-06-25_6.dmp.
List of loaded modules:
Base Address Module
