So I upgraded from a 1080p monitor to the RoG swift and all of a sudden whenever I try to stream OBS just constantly crashes. It took no longer than about 5min to crash, but now it crashes after about 15min or so. I've made no changes to my OBS settings after upgrading monitors except for it having to capture at a base res of 1440p instead of 1080p.
https://obsproject.com/ - include the contents of this crash log and the
This crash appears to have occured in the 'c:\program files\obs\libx264-146.dll' module.
**** UNHANDLED EXCEPTION: c000001d
Fault address: 0000000064061458 (c:\program files\obs\libx264-146.dll)
OBS version: Open Broadcaster Software v0.655b
CPU: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
Crashing thread stack trace:
000000859B3483F8 0000000064061458 4F4F4F4E4D4E4C4B 5759585652505150 4F4F4F4E4C4D4C4B 585C595753515050 libx264-146.dll!0x64061458
000000859B348400 000000006404E853 0000000000000000 0000000000000000 0000000000000000 0000000000000000 libx264-146.dll!0x6404e853
000000859B348470 000000006400A657 0000000000000000 0000000000000000 0000000000000001 0000000000000000 libx264-146.dll!0x6400a657
000000859B348A50 000000006400E410 0000008599A3CE40 000000859B348FB0 000000859B348F90 0000000000000003 libx264-146.dll!0x6400e410
000000859B348EC0 0000000064000BE9 0000008599A3CE40 0000000000000000 0000000000000000 0000000000000000 libx264-146.dll!0x64000be9
000000859B34DD00 000000006403CFF0 00000085F95B26A0 000000006404D9A1 00000085F95B2740 000000006404D725 libx264-146.dll!0x6403cff0
000000859B34FB60 000000006403F6DF 00000085F95B26A0 00000000FFFFFFFE 0000000000000000 00007FF88074AB9A libx264-146.dll!0x6403f6df
000000859B34FBC0 000000006404D05E 00000085F95C16D0 00000085F95C16D0 0000000000000000 0000000000000000 libx264-146.dll!0x6404d05e
000000859B34FC10 000000006404D473 00000085F9566790 0000000000000000 0000000000000000 0000000000000000 libx264-146.dll!0x6404d473
000000859B34FC40 00007FF88074B097 00000085F95C16D0 00000085F95C16D0 0000000000000000 0000000000000000 msvcrt.dll!0x7ff88074b097
000000859B34FC70 00007FF88074B16C 0000000000000000 0000000000000000 0000000000000000 0000000000000000 msvcrt.dll!0x7ff88074b16c
000000859B34FCA0 00007FF87E1D2D92 00007FF87E1D2D70 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ff87e1d2d92
000000859B34FCD0 00007FF880AF9F64 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff880af9f64
A minidump was saved to C:\Users\anime\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-08-30_3.dmp.
List of loaded modules:
Base Address Module
11:25:58: CLR host plugin strings not found, dynamically loading 4 strings
11:25:58: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
11:25:58: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
11:25:58: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
11:25:58: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
11:25:58: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
11:25:58: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
11:25:58: CLRHost:: Could not find/load browser settings at location C:\Users\anime\AppData\Roaming\OBS\pluginData\browser.json
11:25:58: CLRHost:: Exception: System.IO.FileNotFoundException: Could not find file 'C:\Users\anime\AppData\Roaming\OBS\pluginData\browser.json'.
11:25:58: File name: 'C:\Users\anime\AppData\Roaming\OBS\pluginData\browser.json'
11:25:58: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
11:25:58: at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
11:25:58: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
11:25:58: at CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
11:25:58: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
11:26:41: No Intel graphics adapter visible in QSVHelper.exe, Optimus problem?
11:26:41: CUDA loaded successfully
11:26:41: 1 CUDA capable devices found
11:26:41: [ GPU #0 - < GeForce GTX 980 Ti > has Compute SM 5.2, NVENC Available ]
11:27:39: Open Broadcaster Software v0.655b - 64bit ( ^ω^)
11:27:39: -------------------------------
11:27:39: CPU Name: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
11:27:39: CPU Speed: 3300MHz
11:27:39: Physical Memory: 16306MB Total, 10960MB Free
11:27:39: stepping id: 2, model 63, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 12, total cores 6
11:27:39: monitor 1: pos={0, 0}, size={2560, 1440}
11:27:39: monitor 2: pos={0, -1152}, size={2048, 1152}
11:27:39: monitor 3: pos={-1920, 0}, size={1920, 1080}
11:27:39: Windows Version: 10.0 Build 10240 (revision 16384)
11:27:39: Aero is Enabled
11:27:39: OBS Modules:
11:27:39: Base Address Module
11:27:39: 00000000BEA50000 OBS.exe
11:27:39: 0000000061D30000 OBSApi.dll
11:27:39: 000000006E630000 CLRHostPlugin.dll
11:27:39: 000000006DB10000 DShowPlugin.dll
11:27:39: 00000000669C0000 GraphicsCapture.dll
11:27:39: 0000000074440000 NoiseGate.dll
11:27:39: 000000006FE50000 PSVPlugin.dll
11:27:39: 0000000066290000 scenesw.dll
11:27:39: ------------------------------------------
11:27:39: Adapter 1
11:27:39: Video Adapter: NVIDIA GeForce GTX 980 Ti
11:27:39: Video Adapter Dedicated Video Memory: 2047541248
11:27:39: Video Adapter Shared System Memory: 4254490624
11:27:39: Video Adapter Output 1: pos={0, 0}, size={2560, 1440}, attached=true
11:27:39: Video Adapter Output 2: pos={0, -1152}, size={2048, 1152}, attached=true
11:27:39: Video Adapter Output 3: pos={-1920, 0}, size={1920, 1080}, attached=true
11:27:39: Using fixed low latency mode, factor 20
11:27:39: =====Stream Start: 2015-08-30, 11:27:39===============================================
11:27:39: Multithreaded optimizations: On
11:27:39: Base resolution: 2560x1440
11:27:39: Output resolution: 1280x720
11:27:39: Loading up D3D10 on NVIDIA GeForce GTX 980 Ti (Adapter 1)...
11:27:40: ------------------------------------------
11:27:40: Audio Format: 48000 Hz
11:27:40: Audio Channels: 2 Ch
11:27:40: Playback device {0.0.0.00000000}.{b8325476-f17c-4f0b-8718-de9468b5c501}
11:27:40: Using desktop audio input: HD700 (USB Audio CODEC )
11:27:40: Global Audio time adjust: 0
11:27:40: Using auxilary audio input: MXL V67G (Scarlett Solo)
11:27:40: Mic time offset: 0
11:27:40: Audio Encoding: AAC
11:27:40: bitrate: 128
11:27:40: Using graphics capture
11:27:40: Trying to hook process: csgo.exe
11:27:40: Scene buffering time set to 700
11:27:40: Video Encoding: x264
11:27:40: fps: 60
11:27:40: width: 1280, height: 720
11:27:40: preset: veryfast
11:27:40: profile: main
11:27:40: keyint: 120
11:27:40: CBR: yes
11:27:40: CFR: yes
11:27:40: max bitrate: 3500
11:27:40: buffer size: 3500
11:27:40: CLRHost:: Browser 1: Status message:
11:27:40: CLRHost:: Browser 1: Failed to set referrer policy: The value 'no-referrer' is not one of 'always', 'default', 'never', or 'origin'. Defaulting to 'never'. @http://www.twitchalerts.com/alert-box/v3/6FA2C39D417A6990719210
11:27:40: CLRHost:: Browser 1: ----- PROMOTED! ----- @http://www.twitchalerts.com/scripts/alert-box3.min.js?211
11:27:41: Using RTMP service: Twitch
11:27:41: Server selection: rtmp://live-iad.twitch.tv/app
11:27:41: Interface: Intel(R) Ethernet Connection (2) I218-V (ethernet, 1000 mbps)
Warning -- D3D10Texture::CreateFromSharedHandle: Failed to open shared handle, result = 0x80070057
Warning -- SharedTexCapture::Init: Could not create shared texture
11:27:42: Completed handshake with rtmp://live-iad.twitch.tv/app in 342 ms.
11:27:42: SO_SNDBUF was at 65536
11:27:43: SharedTexCapture hooked
11:29:45: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 0 / 463872)
11:29:54: GraphicsCaptureSource::NewCapture: eliminating old capture
11:29:54: SharedTexCapture hooked
