dark3tar15
I've been trying to get back into streaming, so I open up OBS and the settings are all still there from when I used to stream. It's set up to my El Gato HD (not the HD60), Youtube settings, everything's there. But every time I click preview, or record, or start stream, it crashes and gives me an error log stating this:
https://obsproject.com/ - include the contents of this crash log and the
This crash appears to have occured in the 'b:\prgram files (x86)\obs\plugins\dshowplugin.dll' module.
Fault address: 0F2DD5B0 (b:\prgram files (x86)\obs\plugins\dshowplugin.dll)
OBS version: Open Broadcaster Software v0.655b
CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
Crashing thread stack trace:
2987F960 0F2DD5B0 05DE8000 2A890000 00001E00 000001E0 dshowplugin.dll!DeviceSource::Convert422To444+0x110
2987F980 0F2D60F8 00F71000 0F86C8F0 00FDEC98 00FDCAD0 dshowplugin.dll!DeviceSource::Preprocess+0x1c8
2987F9D4 0F865908 00FDCAD0 00FDCAD0 00FFFFFF 01010001 obsapi.dll!Scene::Preprocess+0x28
2987F9E0 00FDEC98 76BE3744 00000000 76BE3720 55E96ABC obs.exe!OBS::MainCaptureLoop+0xaf8
2987FD1C 00FDCAD5 00000000 76BE3720 55E96ABC 2987FD74 obs.exe!OBS::MainCaptureThread+0x5
2987FD20 76BE3744 00000000 C261A6D7 00000000 00000000 kernel32.dll!0x76be3744
2987FD34 7702A064 FFFFFFFF 7704D7BB 00000000 00000000 ntdll.dll!0x7702a064
2987FD7C 7702A02F 00FDCAD0 00000000 00000000 00000000 ntdll.dll!0x7702a02f
A minidump was saved to b:\Users\NAME\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-08-26_3.dmp.
List of loaded modules:
Base Address Module
What is going on? It works with other sources like Window Capture, Monitor Capture, etc. Why is it screwing up with my El Gato HD capture? I've updated OBS and El Gato several times, logged out, reinstalled, changed settings, everything. What's up?
Base Address Module
