Using both the 32 and 64 bit versions of OBS, on Windows 7, OBS crashes when using the same hotkey for the Start Replay Buffer, Stop Replay Buffer and Save Replay Buffer functions.
This doesn't happen all the time, but when outputting a larger file (typically using a replay buffer of 300+ seconds, and bitrate of 50k) it has a better chance of happening - and it happens quite frequently
This is easily replicated. The workaround I've found is basically using one hotkey for the Start/Stop Replay Buffer functions, and a second hotkey for the Save Replay Buffer function.
Hope this helps.
Hope this helps.
