Bug Report OBS Crashes when using Logitech G430 headset
Rebcart
I can't explain why this happens but it ALWAYS happens about 30-40 minutes into a stream. I'm using the USB dongle that came with it. OBS will first disallow me to interact with anything on the UI (I can still see the video preview during streaming), then the program will just crash. This happens with both the Logitech Gaming Software running and not running so that's not the issue. Happens when my webcam is running and not running so that's not the issue. Also the mic randomly stops working during a stream and won't work again until I restart the stream. This computer is using an onboard soundcard (Realtek HD Audio) so I'm not sure if that is an issue. Using the same pair of headphones through the analog audio jacks works just fine although the quality is not as good as through the USB.
The log file is absolutely flooded with messages about the microphone (the log file is 35 MEGS from a 40 minute stream), it's a bit spammy so here is a shortened Pastebin of the log file in question.
http://pastebin.com/Z10sLujH
I really do hope a solution to my problem can be found. The issue seems to have something to do with the "audio timestamp" of the microphone.
Rebcart
I honestly don't know why, but after doing some more searching it looks like this might be the issue. Tomorrow I will test to see if it was and I'll supply my results
