Bug Report OBS Crashes when I try to remove Compressor Audio filter
coola
Hi,
When I try to remove the Compressor Audio filter or other audio filters, OBS studio crashes. Here is the crash report:
Unhandled exception: c0000005
Date/Time: 2019-08-24, 12:05:32
Fault address: 7FFA0587FC18 (c:\program files\obs-studio\bin\64bit\qt5core.dll)
libobs version: 23.2.1 (64-bit)
Windows version: 10.0 build 17763 (revision: 678; 64-bit)
CPU: Intel(R) Core(TM) i7-8850H CPU @ 2.60GHz
More detailed logs are attached due to size of the log.
  • obs-filter_removal_error.txt
