Bug Report OBS Crashes when adding window caps to scene
StoneyOC
Hi, just installed OBS on a clean OS build and it's crashing 9/10 when previewing the stream. If it makes it to actually preview a stream, it crashes when I switch scenes 100% of the time. Any help would be appreciated.
EDIT: changed title to reflect know crash cause
Log file is below and minidump attached.
This crash appears to have occured in the 'c:\program files (x86)\obs\64bit\obsapi.dll' module.
Fault address: 000007FEEF79AC6C (c:\program files (x86)\obs\64bit\obsapi.dll)
OBS version: Open Broadcaster Software v0.522b
Crashing thread stack trace:
Stack            EIP              Arg0             Arg1             Arg2             Arg3             Address
00000000002DE8F0 000007FEEF79AC6C 00000000000004D2 00000000002DE9B0 00000000000004D2 00000000002DE9D0 obsapi.dll!FastAlloc::_Allocate+0x17c
00000000002DE940 000007FEEF7A6D50 00000000000004D2 0000000000411800 00000000002DEA20 0000000000411800 obsapi.dll!String::String+0x70
00000000002DE980 000007FEEF788E69 00000000000004D2 00000000002DEB50 00000000003D1000 000000013F5E8098 obsapi.dll!XFile::ReadFileToString+0xb9
00000000002DE9D0 000007FEEF78FD08 0000000000000780 0000000000410000 0000000000410000 00000000000004B0 obsapi.dll!GraphicsSystem::CreateVertexShaderFromFile+0x78
00000000002DEA50 000000013F5578A4 0000000000000001 0000000000001395 00000000001103AC 00000000000502F8 obs.exe!OBS::Start+0x5a4
00000000002DEE50 000000013F576CD3 0000000000000070 FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF 0000000076D29B43 obs.exe!OBS::OBSProc+0x1833
00000000002DEFD0 0000000076D29BD1 0000000000A26060 000000013F5754A0 00000000FFFFFED1 00000000001103AC user32.dll!0x76d29bd1
00000000002DF090 0000000076D26AA8 00000000000502F8 0000000000000111 0000000000001395 000007FEFBAF0A29 user32.dll!0x76d26aa8
00000000002DF120 0000000076D26BAD 00000000004E7630 0000000000000001 0000000000000000 0000000000000000 user32.dll!0x76d26bad
00000000002DF170 000007FEFBAF0BBF 00000000001103AC 0000000000000001 00000000004E7630 000007FEFEFC1D18 comctl32.dll!0x7fefbaf0bbf
00000000002DF1B0 000007FEFBAF47FE 0000000000000000 0000000000000000 0000000000000000 0000000000000000 comctl32.dll!0x7fefbaf47fe
00000000002DF270 0000000076D29BD1 00000000002DF530 000007FEFBAF3B20 0000000000A26060 0000000000A456D0 user32.dll!0x76d29bd1
00000000002DF330 0000000076D298DA 0000000000000000 0000000000000000 000007FEFBAF3B20 0000000000000001 user32.dll!0x76d298da
00000000002DF3B0 0000000076D267C2 0000000000850361 0000000000850361 000007FEFEFC2164 00000000004D1470 user32.dll!0x76d267c2
00000000002DF440 000000013F54D309 0000000000000000 0000000000000000 000000013F530000 0000000000000000 obs.exe!WinMain+0x8d9
00000000002DF970 000000013F5BD850 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!strstr+0x1ac
00000000002DFA20 000000007674652D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7674652d
00000000002DFA50 0000000076E3C521 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x76e3c521
A minidump was saved to C:\Users\David\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-05-31_12.dmp.
List of loaded modules:
Base Address                      Module
000000013F530000-000000013F67A000 C:\Program Files (x86)\OBS\64bit\OBS.exe
0000000076E10000-0000000076FB9000 C:\Windows\SYSTEM32\ntdll.dll
0000000076730000-000000007684F000 C:\Windows\system32\kernel32.dll
000007FEFD490000-000007FEFD4FB000 C:\Windows\system32\KERNELBASE.dll
000007FEFC200000-000007FEFC209000 C:\Windows\system32\AVRT.dll
000007FEFEF40000-000007FEFEF5F000 C:\Windows\SYSTEM32\sechost.dll
000007FEFEE90000-000007FEFEF2F000 C:\Windows\system32\msvcrt.dll
000007FEFEBF0000-000007FEFED1D000 C:\Windows\system32\RPCRT4.dll
000007FEFB080000-000007FEFB098000 C:\Windows\system32\dwmapi.dll
000007FEFE8C0000-000007FEFE927000 C:\Windows\system32\GDI32.dll
0000000076D10000-0000000076E0A000 C:\Windows\system32\USER32.dll
000007FEFED20000-000007FEFED2E000 C:\Windows\system32\LPK.dll
000007FEFD6E0000-000007FEFD7A9000 C:\Windows\system32\USP10.dll
000007FEF6AD0000-000007FEF6B77000 C:\Windows\system32\dxgi.dll
000007FEFDA30000-000007FEFDB0B000 C:\Windows\system32\ADVAPI32.dll
  • OBSCrashDump2013-05-31_12.zip
R1CH
Re: OBS Crashes 9/10 when previewing stream
Does this happen even with a blank scene? If not, what items do you have on your scene?
StoneyOC
UPDATE: So I deleted all my scenes and rebuilt them all exactly as before, everything now works perfectly - was streaming for 2 hours last night with no issues at all.
Guessing a capture was corrupt or something?
StoneyOC
Ok so I've managed to be able to replicate the crash!
The exact same crash occurs when I add any window capture into the scene. Any thoughts guys?
Cheers,
Dave
