OBS crashes on auto-wizard
Arulin
Now I have run OBS on Linux before with no issues at all but I left the streaming world for a year to return...Then I started seeing a number of issues like my Black Magic Card not functioning in the latest version....So I rolled back to 26.0.0.0-1 to find that OBS is not finding my hardware or opening a rtmp_output.... Installed the version off of Snap as well, it works as far as streaming but no Black Magic Support...Can I get some help understanding this unhandled exception that should be clear of what is missing?
Here the log
09:03:47 AM.386: CPU Name: AMD Ryzen Threadripper 1950X 16-Core Processor
09:03:47 AM.387: CPU Speed: 2879.247MHz
09:03:47 AM.388: Physical Cores: 16, Logical Cores: 32
09:03:47 AM.388: Physical Memory: 32021MB Total, 20411MB Free
09:03:47 AM.388: Kernel Version: Linux 5.10.7-3-MANJARO
09:03:47 AM.388: Distribution: "Manjaro Linux" Unknown
09:03:47 AM.388: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.20.10
09:03:47 AM.389: Portable mode: false
09:03:47 AM.445: OBS 26.0.0-1 (linux)
09:03:47 AM.445: ---------------------------------
09:03:47 AM.445: audio settings reset:
09:03:47 AM.445: samples per sec: 48000
09:03:47 AM.445: speakers: 2
09:03:47 AM.449: ---------------------------------
09:03:47 AM.449: Initializing OpenGL...
09:03:47 AM.533: Loading up OpenGL on adapter AMD Radeon RX Vega (VEGA10, DRM 3.40.0, 5.10.7-3-MANJARO, LLVM 11.0.1)
09:03:47 AM.533: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 20.3.3, shading language 4.60
09:03:47 AM.544: ---------------------------------
09:03:47 AM.544: video settings reset:
09:03:47 AM.544: base resolution: 1920x1080
09:03:47 AM.544: output resolution: 1280x720
09:03:47 AM.544: downscale filter: Bicubic
09:03:47 AM.544: fps: 30/1
09:03:47 AM.544: format: NV12
09:03:47 AM.544: YUV mode: 709/Partial
09:03:47 AM.544: NV12 texture support not available
09:03:47 AM.550: Audio monitoring device:
09:03:47 AM.550: name: Default
09:03:47 AM.550: id: default
09:03:47 AM.550: ---------------------------------
09:03:47 AM.551: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
09:03:47 AM.614: Decklink API Compiled version 10.11.4
09:03:47 AM.614: Decklink API Installed version 12.0
09:03:47 AM.623: os_dlopen(libnvidia-encode.so.1->libnvidia-encode.so.1): libnvidia-encode.so.1: cannot open shared object file: No such file or directory
09:03:47 AM.623:
09:03:47 AM.623: FFMPEG VAAPI supported
09:03:47 AM.625: os_dlopen(/usr//lib/obs-plugins/obs-outputs.so->/usr//lib/obs-plugins/obs-outputs.so): libmbedtls.so.12: cannot open shared object file: No such file or directory
09:03:47 AM.625:
09:03:47 AM.625: Module '/usr//lib/obs-plugins/obs-outputs.so' not loaded
09:03:47 AM.630: VLC found, VLC video source enabled
09:03:47 AM.630: ---------------------------------
09:03:47 AM.630: Loaded Modules:
09:03:47 AM.630: vlc-video.so
09:03:47 AM.630: text-freetype2.so
09:03:47 AM.630: rtmp-services.so
09:03:47 AM.630: obs-x264.so
09:03:47 AM.630: obs-transitions.so
09:03:47 AM.630: obs-libfdk.so
09:03:47 AM.630: obs-filters.so
09:03:47 AM.630: obs-ffmpeg.so
09:03:47 AM.630: linux-v4l2.so
09:03:47 AM.630: linux-pulseaudio.so
09:03:47 AM.630: linux-jack.so
09:03:47 AM.630: linux-decklink.so
09:03:47 AM.630: linux-capture.so
09:03:47 AM.630: linux-alsa.so
09:03:47 AM.630: image-source.so
09:03:47 AM.630: frontend-tools.so
09:03:47 AM.630: decklink-ouput-ui.so
09:03:47 AM.630: ==== Startup complete ===============================================
09:03:47 AM.632: All scene data cleared
09:03:47 AM.632: ------------------------------------------------
09:03:47 AM.642: pulse-input: Server name: 'pulseaudio 14.2'
09:03:47 AM.642: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
09:03:47 AM.642: pulse-input: Started recording from 'alsa_output.usb-Blue_Microphones_Yeti_Stereo_Microphone_REV8-00.iec958-stereo.monitor'
09:03:47 AM.642: [Loaded global audio device]: 'Desktop Audio'
09:03:47 AM.643: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
09:03:47 AM.643: pulse-input: Started recording from 'alsa_input.usb-Blue_Microphones_Yeti_Stereo_Microphone_REV8-00.analog-stereo'
09:03:47 AM.643: [Loaded global audio device]: 'Mic/Aux'
09:03:47 AM.643: Switched to scene 'Scene'
09:03:47 AM.643: ------------------------------------------------
09:03:47 AM.643: Loaded scenes:
09:03:47 AM.643: - scene 'Scene':
09:03:48 AM.206: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Desktop Audio)
09:03:48 AM.206:
09:04:14 AM.961:
09:04:14 AM.961: ==== Auto-config wizard testing commencing ======
09:04:15 AM.017: ---------------------------------
09:04:15 AM.017: video settings reset:
09:04:15 AM.017: base resolution: 1920x1080
09:04:15 AM.017: output resolution: 128x128
09:04:15 AM.017: downscale filter: Bicubic
09:04:15 AM.017: fps: 60/1
09:04:15 AM.017: format: NV12
09:04:15 AM.017: YUV mode: 709/Partial
09:04:15 AM.017: NV12 texture support not available
09:04:15 AM.024: Output ID 'rtmp_output' not found
09:04:15 AM.024: Failed to create output 'test_stream'!
  • 2021-01-24 09-03-47.txt
