Bug Report OBS crashes me - I crash OBS | Can't stream :'( help?
Poochman
Hello! I'm trying to get streaming to work on my computer but i've been having probelms recently with bluescreens and other crashes, OBS is not an exception. I was trying to stream Skyrim fullscreen and it will work perfectly, for a couple seconds, then crashes either Skyrim or OBS itself. I've tried with other games and same result.
Hopefully y'all can help me out with this one! Thanks in advance
Idk if this is necessary PC Specs
EVGA P67 SLI motherboard
8gb ram
i7 3770k @ Stock
Evga gtx 760
running 2 Monitors
This crash appears to have occured in the 'c:\program files (x86)\obs\64bit\libx264-140.dll' module.
Fault address: 000000007201E18F (c:\program files (x86)\obs\64bit\libx264-140.dll)
OBS version: Open Broadcaster Software v0.592b
Windows version: 6.1 (Build 7600)
CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Crashing thread stack trace:
000000000B92EE38 000000007201E18F 0000000000000000 0000000000000000 0000000000000000 0000000000000000 libx264-140.dll!0x7201e18f
000000000B92EE40 000000007200B0C0 0000000000000000 0000000000000000 0000000000000000 0000000000000000 libx264-140.dll!0x7200b0c0
000000000B92EEA0 0000000071FC7A2F 0000000000000000 0000000000000000 000000000B92F900 0000000000000004 libx264-140.dll!0x71fc7a2f
000000000B92F800 0000000071F96CEE 0000000009D24100 000000001CD05C10 000000001CD05C20 00000000778E81C1 libx264-140.dll!0x71f96cee
000000000B92FC40 0000000071F97BC4 0000000000000000 0000000000000000 0000000000000000 000007FEFE0913F2 libx264-140.dll!0x71f97bc4
000000000B92FCD0 000000007200992E 00000000003B70E0 00000000003B70E0 0000000000000000 0000000000000000 libx264-140.dll!0x7200992e
000000000B92FD20 0000000072009E23 00000000003B70E0 0000000000000000 0000000000000000 0000000000000000 libx264-140.dll!0x72009e23
000000000B92FD50 000007FEFE09428F 000007FEFE121EA0 00000000003B70E0 0000000000000000 0000000000000000 msvcrt.dll!0x7fefe09428f
000000000B92FD80 000007FEFE09742D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 msvcrt.dll!0x7fefe09742d
000000000B92FDB0 00000000772DF34D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x772df34d
000000000B92FDE0 0000000077882CA1 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x77882ca1
A minidump was saved to C:\Users\Matthew\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-12-31_5.dmp.
List of loaded modules:
Base Address Module
Lain
Lain
Okay, there are two things I need to note here:
1.) You have been having bluescreens. This is indicative of hardware or driver issues. Bad hardware, unstable hardware, overheating hardware can cause this as well.
2.) When the crash occurs in libx264, it's almost always indicative of a hardware issue due to x264's heavy usage of advanced instructions. I've never seen a case where a crash occurs in libx264 and it didn't turn out to be hardware problems.
Really sorry to have to tell you this though, I know it's probably not something you want to hear, but regardless, you should hear it.
