Bug Report OBS crashes exactly after 3Hours20Minutes.
Streamcouple
I have a really annoying Problem. OBS crashes exactly after 3Hours20Minutes. I streamed for 18 Hours and it happened always exactly after the same time. Before i had some Crashes.. but always after a really long time. 8Hours+. Then i tried an older OBS version 0.624b and it worked for 1 week. Then i had an crash after like 9 hours. Maybe its just random. But now exact after 3hours20min which is really weird. I changed the Motherboard. SSD, almost everything to get rid off it. But every Test passed. Memtest. Prime95 everything. It must be OBS i think. The Crash Message is always Out of Memory while trying to allocate 'number* out of 'number'. I will try today the new beta but i have no idea anymore what to do.
Using a Asus n53 @ 5GHZ Wireless Lan.
Starting with a Log:
19:43:28: CLR host plugin strings not found, dynamically loading 4 strings
19:43:28: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
19:43:28: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
19:43:28: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
19:43:28: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
19:43:28: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
19:43:28: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
19:43:28: CLRHost:: Could not find/load browser settings at location C:\Users\Thea\AppData\Roaming\OBS\pluginData\browser.json
19:43:28: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
19:43:30: Open Broadcaster Software v0.624b - 32bit (´・ω・`)
19:43:30: -------------------------------
19:43:30: CPU Name: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
19:43:30: CPU Speed: 3192MHz
19:43:30: Physical Memory: 4095MB Total, 2742MB Free
19:43:30: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
19:43:30: monitor 1: pos={0, 0}, size={1920, 1080}
19:43:30: Windows Version: 6.1 Build 7601 S
19:43:30: Aero is Enabled
19:43:30: OBS Modules:
19:43:30: Base Address Module
19:43:30: 00250000 OBS.exe
19:43:30: 65F80000 OBSApi.dll
19:43:30: 66620000 CLRHostPlugin.dll
19:43:30: 66550000 DShowPlugin.dll
19:43:30: 66520000 GraphicsCapture.dll
19:43:30: 664F0000 NoiseGate.dll
19:43:30: 65CD0000 PSVPlugin.dll
19:43:30: ------------------------------------------
19:43:30: Adapter 1
19:43:30: Video Adapter: NVIDIA GeForce GTX 770
19:43:30: Video Adapter Dedicated Video Memory: 2087387136
19:43:30: Video Adapter Shared System Memory: 2147807232
19:43:30: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
19:43:30: Adapter 2
19:43:30: Video Adapter: Intel(R) HD Graphics 4600
19:43:30: Video Adapter Dedicated Video Memory: 67108864
19:43:30: Video Adapter Shared System Memory: 1711276032
19:43:30: =====Stream Start: 2014-08-17, 19:43:30===============================================
19:43:30: Multithreaded optimizations: On
19:43:30: Base resolution: 1920x1080
19:43:30: Output resolution: 1280x720
19:43:30: Loading up D3D10 on NVIDIA GeForce GTX 770 (Adapter 1)...
19:43:30: Audio Format: 44100 Hz
19:43:30: Audio Channels: 2 Ch
19:43:30: Playback device Default
19:43:30: Using desktop audio input: Lautsprecher (ASUS Xonar Essence STX Audio Device)
19:43:30: Global Audio time adjust: 0
19:43:30: Using 7.1 surround speaker setup
19:43:30: Using auxilary audio input: Mikrofon (Samson Meteor Mic)
19:43:30: Mic time offset: 0
19:43:30: Audio Encoding: AAC
19:43:30: bitrate: 128
19:43:30: Using text output
19:43:30: Using bitmap image
19:43:31: ------------------------------------------
19:43:31: device: Microsoft LifeCam Studio,
19:43:31: device id \\?\usb#vid_045e&pid_0772&mi_00#6&15be71b5&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
19:43:31: chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-666666
19:43:31: use buffering: false - 0, fourCC: 'YUY2'
19:43:31: audio device: Disable,
19:43:31: audio device id Disabled,
19:43:31: audio time offset 0,
19:43:31:
19:43:31: Using directshow input
19:43:31: Using graphics capture
19:43:31: Trying to hook process: dota.exe
19:43:31: Scene buffering time set to 700
19:43:31: Video Encoding: x264
19:43:31: fps: 30
19:43:31: width: 1280, height: 720
19:43:31: preset: superfast
19:43:31: profile: main
19:43:31: keyint: 60
19:43:31: CBR: yes
19:43:31: CFR: yes
19:43:31: max bitrate: 2100
19:43:31: buffer size: 2100
19:43:31: SharedTexCapture hooked
19:43:33: Using RTMP service: Twitch / Justin.tv
19:43:33: Server selection: rtmp://live-fra.justin.tv/app
19:43:33: Interface: ASUS USB-N53 802.11a/b/g/n Network Adapter (802.11, 300 mbps)
19:43:34: Completed handshake with rtmp://live-fra.justin.tv/app in 923 ms.
19:43:34: SO_SNDBUF was at 8192
19:43:34: SO_SNDBUF is now 65536
19:43:35: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 5912 / 284672)
19:43:36: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 0 / 284672)
19:43:44: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 524288 (buffer: 0 / 284672)
19:52:03: ------------------------------------------
19:52:03: device: Logitech HD Pro Webcam C910,
19:52:03: device id \\?\usb#vid_046d&pid_0821&mi_02#6&62b8607&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
19:52:03: chosen type: I420, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000
19:52:03: use buffering: false - 0, fourCC: 'I420'
19:52:03: audio device: Disable,
19:52:03: audio device id Disabled,
19:52:03: audio time offset 0,
19:52:03:
19:52:03: Using directshow input
Here are the Crash-Logs
1.
This crash appears to have occured in the '<unknown>' module.
**** UNHANDLED EXCEPTION: dead0b5
Fault address: 7715C42D (<unknown>)
OBS version: Open Broadcaster Software v0.625b
CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
Crashing thread stack trace:
14B1FD28 7715C42D 0DEAD0B5 00000001 00000000 00000000 <unknown>!0x7715c42d
14B1FD80 5D8683DF 5D892740 002F8000 67825872 008BC4C0 <unknown>!0x5d8683df
14B1FDB4 5D85B2A4 002F7600 678404E8 002AE99C 1C067B18 <unknown>!0x5d85b2a4
14B1FDE0 67825872 008BC4C0 00000000 00000001 00000000 <unknown>!0x67825872
14B1FE04 67821A0F 002AE984 1C067B18 08D42B98 00000000 <unknown>!0x67821a0f
14B1FE20 67821A3E 002AE984 000AA0A0 00000001 14B1FE58 <unknown>!0x67821a3e
14B1FE3C 6431A8A6 00000000 00000000 14B1FE8C 759D338A <unknown>!0x6431a8a6
14B1FE78 6431AB7C 1C067408 14B1FECC 77C29F72 1C067408 <unknown>!0x6431ab7c
14B1FE88 759D338A 1C067408 62C3081E 00000000 00000000 <unknown>!0x759d338a
14B1FE94 77C29F72 6431AB66 1C067408 00000000 00000000 <unknown>!0x77c29f72
14B1FED4 77C29F45 6431AB66 1C067408 00000000 00000000 <unknown>!0x77c29f45
List of loaded modules:
Base Address Module
2.
17D4FDC8 7715C42D 0DEAD0B5 00000001 00000000 00000000 <unknown>!0x7715c42d
17D4FE20 5DA783DF 5DAA2740 002F8000 64345872 0063F2C0 <unknown>!0x5da783df
17D4FE54 5DA6B2A4 002F7600 643604E8 0026D79C 003F48B8 <unknown>!0x5da6b2a4
17D4FE84 64345872 0063F2C0 00000000 00000001 00000000 <unknown>!0x64345872
17D4FEA8 64341A0F 0026D784 003F48B8 124A7B60 00000000 <unknown>!0x64341a0f
17D4FEC4 64341A3E 0026D784 00959FD0 00000001 17D4FEFC <unknown>!0x64341a3e
17D4FEE0 5D73A8A6 00000000 00000000 17D4FF30 759D338A <unknown>!0x5d73a8a6
17D4FF1C 5D73AB7C 003F8AB0 17D4FF70 77C29F72 003F8AB0 <unknown>!0x5d73ab7c
17D4FF2C 759D338A 003F8AB0 6263566E 00000000 00000000 <unknown>!0x759d338a
17D4FF38 77C29F72 5D73AB66 003F8AB0 00000000 00000000 <unknown>!0x77c29f72
17D4FF78 77C29F45 5D73AB66 003F8AB0 00000000 00000000 <unknown>!0x77c29f45
Base Address Module
Streamcouple
Fault address: 74A0C42D (<unknown>)
OBS version: Open Broadcaster Software v0.624b
274CF940 74A0C42D 0DEAD0B5 00000001 00000000 00000000 <unknown>!0x74a0c42d
274CF998 65FA839F 65FD2598 002F8000 65D05862 007489A0 <unknown>!0x65fa839f
274CF9CC 65F9B244 002F7600 65D204E8 0042861C 1AB92F60 <unknown>!0x65f9b244
274CF9F8 65D05862 007489A0 00000000 00000001 00000000 <unknown>!0x65d05862
274CFA1C 65D01A0F 00428604 1AB92F60 005BB188 00000000 <unknown>!0x65d01a0f
274CFA38 65D01A3E 00428604 0076A0C0 00000001 274CFA70 <unknown>!0x65d01a3e
274CFA54 6076A8A6 00000000 00000000 274CFAA4 769D338A <unknown>!0x6076a8a6
274CFA90 6076AB7C 1AF7C6F8 274CFAE4 76F09F72 1AF7C6F8 <unknown>!0x6076ab7c
274CFAA0 769D338A 1AF7C6F8 51B14A17 00000000 00000000 <unknown>!0x769d338a
274CFAAC 76F09F72 6076AB66 1AF7C6F8 00000000 00000000 <unknown>!0x76f09f72
274CFAEC 76F09F45 6076AB66 1AF7C6F8 00000000 00000000 <unknown>!0x76f09f45
Base Address Module
4.
166DFD38 74A0C42D 0DEAD0B5 00000001 00000000 00000000 <unknown>!0x74a0c42d
166DFD90 65FA839F 65FD2598 002F8000 66505862 0072FE40 <unknown>!0x65fa839f
166DFDC4 65F9B244 002F7600 665204E8 0024D99C 00417BC8 <unknown>!0x65f9b244
166DFDF4 66505862 0072FE40 00000000 00000001 00000000 <unknown>!0x66505862
166DFE18 66501A0F 0024D984 00417BC8 10F3D690 00000000 <unknown>!0x66501a0f
166DFE34 66501A3E 0024D984 00A0A1E0 00000001 166DFE6C <unknown>!0x66501a3e
166DFE50 600CA8A6 00000000 00000000 166DFEA0 769D338A <unknown>!0x600ca8a6
166DFE8C 600CAB7C 00416008 166DFEE0 76F09F72 00416008 <unknown>!0x600cab7c
166DFE9C 769D338A 00416008 602224DE 00000000 00000000 <unknown>!0x769d338a
166DFEA8 76F09F72 600CAB66 00416008 00000000 00000000 <unknown>!0x76f09f72
166DFEE8 76F09F45 600CAB66 00416008 00000000 00000000 <unknown>!0x76f09f45
5.
2608FB60 74A0C42D 0DEAD0B5 00000001 00000000 00000000 <unknown>!0x74a0c42d
2608FBB8 65D9839F 65DC2598 002F8000 65D35862 00D7CB00 <unknown>!0x65d9839f
2608FBEC 65D8B244 002F7600 65D504E8 0015D51C 00904C78 <unknown>!0x65d8b244
2608FC18 65D35862 00D7CB00 00000000 00000001 00000000 <unknown>!0x65d35862
2608FC3C 65D31A0F 0015D504 00904C78 255752E8 00000000 <unknown>!0x65d31a0f
2608FC58 65D31A3E 0015D504 0067A020 00000001 2608FC90 <unknown>!0x65d31a3e
2608FC74 65D1A8A6 00000000 00000000 2608FCC4 769D338A <unknown>!0x65d1a8a6
2608FCB0 65D1AB7C 16FF1430 2608FD04 76F09F72 16FF1430 <unknown>!0x65d1ab7c
2608FCC0 769D338A 16FF1430 5199FB16 00000000 00000000 <unknown>!0x769d338a
2608FCCC 76F09F72 65D1AB66 16FF1430 00000000 00000000 <unknown>!0x76f09f72
2608FD0C 76F09F45 65D1AB66 16FF1430 00000000 00000000 <unknown>!0x76f09f45
Base Address Module
I really need help im desperate :( have no idea what to do. Always after 3 hours 2 minutes. I stream Dota2.
Lain
Lain
Could you include the crash dump file? Those crash logs are not so useful because they're not tracking the modules in the backtrace.
Streamcouple
I just checked the how to i shall zip/rar the crash dump? which is a .txt right? local/obs/crashdumps. just tell me how :) i will
Lain
Lain
Whichever works to put on the forums as an attachment. The crashdump is a .dmp file.
Streamcouple
i just found out that there should be a minidump. But the Crashlog does not say "a minidum was created" so there is no .dmp file :(
Streamcouple
Could this really be the Problem? i installed 16GB for testing aswell. Same Crash. It just took longer. RAM was used about ~60%. So in Theory my Memory runs out every 3horus20minutes? it should be more Random i think. Using a Logitech C910 & Microsoft LifeStudio Cam. Had 0 Crashes on my old system which was way weaker. Same BroadcastSettings.
Would it help if downscale the 1920x1080 to 720? for testing?
Streamcouple
ok thank you i will try that :) and stream now for atleast 3h20m. I think its the Microsoft Life Studio cam. just having problems all day with that. both resolutions are at 1280x720. and as i said 16gb didnt fix it aswell. :) i will report.
Streamcouple
4h30m in. No Crash. May it was because i put that LifeStudioCam into 1920x1080 when its just able to 720? :X not sure i will keep on reporting if no fails
