Bug Report OBS crashes everytime I try to stream or preview stream
Status
Not open for further replies.
Scitty89
I have looked everywhere and still have found no solution to this. It is very frustrating and any help would be much appreciated! I have windows 8 32-bit with x64-based processor. I have AMD FX(tm) - 8150 eight-Core processor 3.60 GHz.
When i try to stream it says woops! OBS has crashed! and here is the crash report
This crash appears to have occured in the 'c:\program files\obs\libx264-129.dll' module.
Fault address: 6D7396EA (c:\program files\obs\libx264-129.dll)
OBS version: Open Broadcaster Software v0.472b
Crashing thread stack trace:
Stack    EIP      Arg0     Arg1     Arg2     Arg3     Address
0916AC04 6D7396EA 1028ABC0 0A8ABEEE 0A8AC96F 0A8AC971 libx264-129.dll!0x6d7396ea
0916AC10 6D6CD3DE 0A8ABEEE 0A8AC96F 0A8AC971 00000540 libx264-129.dll!0x6d6cd3de
0916AC14 1028ABC0 0A8AC96F 0A8AC971 00000540 0916ADB0 <unknown>!0x1028abc0
0916AC18 0A8ABEEE 0A8AC971 00000540 0916ADB0 0916ADB0 <unknown>!0xa8abeee
0916AC1C 0A8AC96F 00000540 0916ADB0 0916ADB0 00000000 <unknown>!0xa8ac96f
0916AC20 0A8AC971 00000000 00000000 00000000 0C6EFC01 <unknown>!0xa8ac971
0916AD20 6D6CCBE2 10286010 0916BB30 0916D820 6D6A1BA9 libx264-129.dll!0x6d6ccbe2
0916B120 6D72AEBA 1028AC48 00000010 0916B1D0 00000008 libx264-129.dll!0x6d72aeba
0916B130 6D6A1BA9 00000000 00000000 6D74D040 162D7588 libx264-129.dll!0x6d6a1ba9
0916D828 0892E1D0 00000000 6D74D040 162D7588 163D8A08 <unknown>!0x892e1d0
A minidump was saved to C:\Users\Scott Anderson\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-03-13_2.dmp.
List of loaded modules:
Base Address      Module
002C0000-003E8000 C:\Program Files\OBS\OBS.exe
77460000-775C7000 C:\WINDOWS\SYSTEM32\ntdll.dll
765B0000-766A8000 C:\WINDOWS\system32\KERNEL32.DLL
74D80000-74E3D000 C:\WINDOWS\system32\KERNELBASE.dll
72F30000-72FD7000 C:\WINDOWS\system32\apphelp.dll
736D0000-736D8000 C:\WINDOWS\SYSTEM32\AVRT.dll
72C60000-72C79000 C:\WINDOWS\SYSTEM32\dwmapi.dll
72B90000-72BEC000 C:\WINDOWS\SYSTEM32\dxgi.dll
72C30000-72C58000 C:\WINDOWS\SYSTEM32\d3d10_1.dll
64570000-645E4000 C:\WINDOWS\SYSTEM32\d3dx10_43.dll
76B50000-76BA0000 C:\WINDOWS\system32\WS2_32.dll
72570000-72590000 C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL
59AF0000-59CDC000 C:\Program Files\OBS\OBSApi.dll
74FE0000-760A6000 C:\WINDOWS\system32\SHELL32.dll
702C0000-70423000 C:\WINDOWS\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9200.16502_none_ba1c7f1de09f65fb\gdiplus.dll
6E720000-6E7A2000 C:\WINDOWS\SYSTEM32\WINHTTP.dll
6D640000-6D828000 C:\Program Files\OBS\libx264-129.dll
73C50000-73CF7000 C:\WINDOWS\SYSTEM32\UxTheme.dll
76160000-76281000 C:\WINDOWS\system32\USER32.dll
74EB0000-74FBA000 C:\WINDOWS\system32\GDI32.dll
76D10000-76DBE000 C:\WINDOWS\system32\ADVAPI32.dll
772D0000-773E9000 C:\WINDOWS\system32\ole32.dll
71750000-71771000 C:\WINDOWS\SYSTEM32\WINMM.dll
76F70000-76FA4000 C:\WINDOWS\SYSTEM32\sechost.dll
76EA0000-76F51000 C:\WINDOWS\system32\msvcrt.dll
72BF0000-72C2D000 C:\WINDOWS\SYSTEM32\d3d10_1core.dll
729E0000-72B83000 C:\WINDOWS\SYSTEM32\d3d11.dll
77010000-770E2000 C:\WINDOWS\system32\RPCRT4.dll
772B0000-772B8000 C:\WINDOWS\system32\NSI.dll
72560000-72568000 C:\WINDOWS\SYSTEM32\WINNSI.DLL
773F0000-773F6000 C:\WINDOWS\system32\PSAPI.DLL
767D0000-76906000 C:\WINDOWS\SYSTEM32\combase.dll
76310000-76350000 C:\WINDOWS\system32\SHLWAPI.dll
71720000-7174A000 C:\WINDOWS\SYSTEM32\WINMMBASE.dll
76350000-7637B000 C:\WINDOWS\system32\IMM32.DLL
76DC0000-76E9D000 C:\WINDOWS\system32\MSCTF.dll
76290000-76305000 C:\WINDOWS\SYSTEM32\shcore.dll
749B0000-749B9000 C:\WINDOWS\SYSTEM32\CRYPTBASE.dll
74950000-749A1000 C:\WINDOWS\SYSTEM32\bcryptPrimitives.dll
727E0000-729D7000 C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.9200.16384_none_893961408605e985\Comctl32.dll
760B0000-7613B000 C:\WINDOWS\system32\OLEAUT32.DLL
69220000-69248000 C:\Program Files\OBS\plugins\DShowPlugin.dll
6FC20000-6FC40000 C:\Program Files\OBS\plugins\GraphicsCapture.dll
76380000-763F4000 C:\WINDOWS\SYSTEM32\clbcatq.dll
73100000-7314D000 C:\WINDOWS\System32\MMDevApi.dll
74E40000-74E5E000 C:\WINDOWS\system32\DEVOBJ.dll
74BA0000-74BE6000 C:\WINDOWS\SYSTEM32\cfgmgr32.dll
70FE0000-70FE8000 C:\WINDOWS\SYSTEM32\VERSION.dll
70FC0000-70FDF000 C:\WINDOWS\SYSTEM32\atiuxpag.dll
53440000-53647000 C:\WINDOWS\SYSTEM32\d3dcompiler_43.dll
70810000-70864000 C:\WINDOWS\SYSTEM32\AUDIOSES.DLL
742F0000-7432F000 C:\WINDOWS\SYSTEM32\powrprof.dll
70FF0000-710DF000 C:\WINDOWS\SYSTEM32\aticfx32.dll
70950000-70FB6000 C:\WINDOWS\SYSTEM32\atidxx32.dll
73A30000-73A40000 C:\WINDOWS\system32\NLAapi.dll
6D5B0000-6D5C0000 C:\WINDOWS\system32\napinsp.dll
6D5C0000-6D5D4000 C:\WINDOWS\system32\pnrpnsp.dll
04690000-046B1000 C:\Program Files\Bonjour\mdnsNSP.dll
744D0000-7451A000 C:\WINDOWS\System32\mswsock.dll
74360000-743D5000 C:\WINDOWS\SYSTEM32\DNSAPI.dll
6D5E0000-6D5E9000 C:\WINDOWS\System32\winrnr.dll
71360000-7139F000 C:\WINDOWS\System32\fwpuclnt.dll
6CEF0000-6CEF7000 C:\Windows\System32\rasadhlp.dll
6B650000-6B779000 C:\WINDOWS\SYSTEM32\DBGHELP.DLL
Scitty89
Jim, I can help you out basically whenever you want I would also love to know what is causing this crash I will try out those builds and see if it helps! thanks for the help :)
paibox
heros in an halfshel
I seem to recall other people having the exact same problem, and the cause was the 32-bit version of Windows 8. I'm not sure what the underlying cause for the crash is, perhaps some incompatibility in the x264 encoder, but if possible you should just use the 64-bit version of Windows 8 anyway, as there is no performance or compatibility benefit to using the 32-bit version of the operating system.
Also, I doubt using a capture card would help, as you would still be encoding your stream either way.
Lain
Lain
You didn't state if the x264 125 build I gave you works or not. Did it not work?
Scitty89
The x264 125 build that you gave me did not work jim sorry forgot to let you know. The same problem persisted unfortunately
Status
