Hello. I have this weird problem that OBS crashes when I try to stream/preview OSU!
It doesn't happen when I try to stream/preview other games.
This crash only happened recently. I've been able to stream/preview the game before.
logfile
Crash Log
logfile
19:02:48: Open Broadcaster Software v0.638b - 32bit (´・ω・`)
19:02:48: -------------------------------
19:02:48: CPU Name: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
19:02:48: CPU Speed: 2294MHz
19:02:48: Physical Memory: 1023MB Total, 1023MB Free
19:02:48: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
19:02:48: monitor 1: pos={0, 0}, size={1920, 1080}
19:02:48: monitor 2: pos={1920, 0}, size={1680, 1050}
19:02:48: Windows Version: 6.1 Build 7600
19:02:48: Aero is Enabled
19:02:48: OBS Modules:
19:02:48: Base Address Module
19:02:48: 01380000 OBS.exe
19:02:48: 6E2D0000 OBSApi.dll
19:02:48: 6E1D0000 DShowPlugin.dll
19:02:48: 6E1A0000 GraphicsCapture.dll
19:02:48: 6E170000 NoiseGate.dll
19:02:48: 65ED0000 PSVPlugin.dll
19:02:48: ------------------------------------------
19:02:48: Adapter 1
19:02:48: Video Adapter: NVIDIA GeForce GTX 660M
19:02:48: Video Adapter Dedicated Video Memory: 2087518208
19:02:48: Video Adapter Shared System Memory: 2147676160
19:02:48: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
19:02:48: Video Adapter Output 2: pos={1920, 0}, size={1680, 1050}, attached=true
19:02:48: Adapter 2
19:02:48: =====Stream Start: 2014-12-28, 19:02:48===============================================
19:02:48: Multithreaded optimizations: On
19:02:48: Base resolution: 1920x1080
19:02:48: Output resolution: 1280x720
19:02:48: Nvidia optimus detected, second adapter selected, ignoring useless second adapter, I guess.
19:02:48: Loading up D3D10 on NVIDIA GeForce GTX 660M (Adapter 1)...
19:02:50: ------------------------------------------
19:02:50: Audio Format: 44100 Hz
19:02:50: Audio Channels: 2 Ch
19:02:50: Playback device {0.0.0.00000000}.{2c7ad847-c7dd-4c04-9fd7-b56a5b91c6e3}
19:02:50: Using desktop audio input: Headset (Siberia v2 Frost Blue)
19:02:50: Global Audio time adjust: 0
19:02:50: Using auxilary audio input: Microphone (Siberia v2 Frost Blue)
19:02:50: Mic time offset: 0
19:02:50: Audio Encoding: MP3
19:02:50: bitrate: 128
19:02:50: Using graphics capture
19:02:50: Using bitmap image
19:02:50: Using text output
19:02:51: Using Slide Show
19:02:51: Trying to hook process: osu!.exe
19:02:51: Scene buffering time set to 700
19:02:51: ------------------------------------------
19:02:51: Video Encoding: x264
19:02:51: fps: 30
19:02:51: width: 1280, height: 720
19:02:51: preset: veryfast
19:02:51: profile: main
19:02:51: keyint: 60
19:02:51: CBR: yes
19:02:51: CFR: yes
19:02:51: max bitrate: 2000
19:02:51: buffer size: 2000
Crash Log
This crash appears to have occured in the 'c:\windows\system32\nvwgf2um.dll' module.
Fault address: 0F78A697 (c:\windows\system32\nvwgf2um.dll)
OBS version: Open Broadcaster Software v0.638b
Windows version: 6.1 (Build 7600)
CPU: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Crashing thread stack trace:
0573F3B0 0F78A697 00000000 052BA518 052BA518 05406548 nvwgf2um.dll!0xf78a697
0573F3C0 0F78A808 052BA518 00000000 14E4EE80 00000000 nvwgf2um.dll!0xf78a808
0573F3E0 0F9460E5 052BA518 07E69DDC 00000000 65EFD07C nvwgf2um.dll!0xf9460e5
0573F8F0 0F25A910 052BA518 0537AC80 0529FF68 0F257991 nvwgf2um.dll!0xf25a910
0573F920 0F259578 0537AD70 4DD91EA7 00000000 05396BA8 nvwgf2um.dll!0xf259578
0573F948 0FAADA00 00000000 0573F990 7566338A 0529FF68 nvwgf2um.dll!0xfaada00
0573F980 0FAADB28 0529FF68 0573F9D0 77819F72 0529FF68 nvwgf2um.dll!0xfaadb28
0573F98C 7566338A 0529FF68 72F869D1 00000000 00000000 kernel32.dll!0x7566338a
0573F998 77819F72 0FAADAAC 0529FF68 00000000 00000000 ntdll.dll!0x77819f72
0573F9D8 77819F45 0FAADAAC 0529FF68 00000000 00000000 ntdll.dll!0x77819f45
A minidump was saved to C:\Users\Lycoriz Hellscythe\AppData\Roaming\OBS\crashDumps\OBSCrashDump2014-12-28_18.dmp.
List of loaded modules:
Base Address Module
