Bug Report OBS crashes and Gaming-PC freezes ! Only with GTA 5 need help
SockePower
Hello together !
I got some issues with my obs and my pc.
I have a good setup : intel i7 4770k @3,5ghz a nvidia gtx980 4gb and 16gb ram
I can stream live on twitch but after like 30 or 60 minutes my pc freezes completly i need to press the restart button.
That only happens when i stream gta 5 i dont know why !
i stream at 1280x720 with 60 FPS and x264 encoding. All settings choosen from a official tutorial from obs.
[10:59:08: CLR host plugin strings not found, dynamically loading 4 strings
10:59:08: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
10:59:08: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
10:59:08: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
10:59:08: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
10:59:08: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
10:59:09: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
10:59:09: CLRHost:: Could not find/load browser settings at location C:\Users\Dado\AppData\Roaming\OBS\pluginData\browser.json
10:59:09: CLRHost:: Exception: System.IO.FileNotFoundException: Die Datei "C:\Users\Dado\AppData\Roaming\OBS\pluginData\browser.json" konnte nicht gefunden werden.
10:59:09: Dateiname: 'C:\Users\Dado\AppData\Roaming\OBS\pluginData\browser.json'
10:59:09: bei System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
10:59:09: bei System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
10:59:09: bei System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
10:59:09: bei CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
10:59:09: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
10:59:14: Open Broadcaster Software v0.651b - 32bit (´・ω・`)
10:59:14: -------------------------------
10:59:14: CPU Name: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
10:59:14: CPU Speed: 3499MHz
10:59:14: Physical Memory: 4095MB Total, 4095MB Free
10:59:14: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
10:59:14: monitor 1: pos={0, 0}, size={1920, 1080}
10:59:14: monitor 2: pos={-1280, 0}, size={1280, 1024}
10:59:14: Windows Version: 6.2 Build 9200
10:59:14: Aero is Enabled
10:59:14: OBS Modules:
10:59:14: Base Address Module
10:59:14: 00A20000 OBS.exe
10:59:14: 69310000 OBSApi.dll
10:59:14: 64440000 CLRHostPlugin.dll
10:59:14: 612E0000 DShowPlugin.dll
10:59:14: 612B0000 GraphicsCapture.dll
10:59:14: 61280000 NoiseGate.dll
10:59:14: 61260000 PSVPlugin.dll
10:59:14: 60450000 scenesw.dll
10:59:14: ------------------------------------------
10:59:14: Adapter 1
10:59:14: Video Adapter: NVIDIA GeForce GTX 980
10:59:14: Video Adapter Dedicated Video Memory: 3221225472
10:59:14: Video Adapter Shared System Memory: 1073676288
10:59:14: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
10:59:14: Video Adapter Output 2: pos={-1280, 0}, size={1280, 1024}, attached=true
10:59:14: Using fixed low latency mode, factor 20
10:59:14: =====Stream Start: 2015-05-11, 10:59:14===============================================
10:59:14: Multithreaded optimizations: On
10:59:14: Base resolution: 1920x1080
10:59:14: Output resolution: 1280x720
10:59:14: Loading up D3D10 on NVIDIA GeForce GTX 980 (Adapter 1)...
10:59:14: Audio Format: 48000 Hz
10:59:14: Audio Channels: 2 Ch
10:59:14: Playback device Default
10:59:14: Using desktop audio input: Lautsprecher (RODE NT-USB)
10:59:14: Global Audio time adjust: 0
10:59:14: Using auxilary audio input: Mikrofon (RODE NT-USB)
10:59:14: Mic time offset: 90
10:59:14: Audio Encoding: AAC
10:59:14: bitrate: 128
10:59:14: Using bitmap image
10:59:14: device: Logitech HD Webcam C270,
10:59:14: device id \\?\usb#vid_046d&pid_0825&mi_00#6&10183b38&1&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
10:59:14: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
10:59:14: use buffering: false - 0, fourCC: 'I420'
10:59:14: audio device: Deaktivieren,
10:59:14: audio device id Disabled,
10:59:14: audio time offset 0,
10:59:14:
10:59:14: Using directshow input
10:59:14: Using Window Capture
10:59:14: Scene buffering time set to 700
10:59:14: Video Encoding: x264
10:59:14: fps: 60
10:59:14: width: 1280, height: 720
10:59:14: preset: veryfast
10:59:14: profile: main
10:59:14: keyint: 120
10:59:14: CBR: yes
10:59:14: CFR: yes
10:59:14: max bitrate: 1600
10:59:14: buffer size: 1600
10:59:14: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
10:59:15: CLRHost:: Browser 1: Status message:
10:59:16: CLRHost:: Browser 1: TypeError: Cannot read property 'length' of undefined @http://www.twitchalerts.com/widgets/alert-box?token=F50052462767DEDA36EE356
10:59:16: Using RTMP service: Twitch
10:59:16: Server selection: rtmp://live-fra.twitch.tv/app
10:59:16: Interface: Intel(R) Ethernet-Verbindung I217-V (ethernet, 1000 mbps)
10:59:17: Completed handshake with rtmp://live-fra.twitch.tv/app in 924 ms.
10:59:18: SO_SNDBUF was at 65536
10:59:46: CLRHost:: Browser 1: TypeError: Cannot read property 'length' of undefined @http://www.twitchalerts.com/widgets/alert-box?token=F50052462767DEDA36EE356
10:59:47: ------------------------------------------
10:59:47: device: Logitech HD Webcam C270,
10:59:47: device id \\?\usb#vid_046d&pid_0825&mi_00#6&10183b38&1&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
10:59:47: chosen type: I420, usingFourCC: false, res: 1280x960 - 1280x960, frameIntervals: 333333-2000000
10:59:47: use buffering: false - 0, fourCC: 'I420'
10:59:47: audio device: Deaktivieren,
10:59:47: audio device id Disabled,
10:59:47: audio time offset 0,
10:59:47:
11:00:03: ------------------------------------------
11:00:03: device: Logitech HD Webcam C270,
11:00:03: device id \\?\usb#vid_046d&pid_0825&mi_00#6&10183b38&1&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
11:00:03: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
11:00:03: use buffering: false - 0, fourCC: 'I420'
11:00:03: audio device: Deaktivieren,
11:00:03: audio device id Disabled,
11:00:03: audio time offset 0,
11:00:03:
11:00:17: CLRHost:: Browser 1: TypeError: Cannot read property 'length' of undefined @http://www.twitchalerts.com/widgets/alert-box?token=F50052462767DEDA36EE356
11:00:48: CLRHost:: Browser 1: TypeError: Cannot read property 'length' of undefined @http://www.twitchalerts.com/widgets/alert-box?token=F50052462767DEDA36EE356
11:01:19: CLRHost:: Browser 1: TypeError: Cannot read property 'length' of undefined @http://www.twitchalerts.com/widgets/alert-box?token=F50052462767DEDA36EE356
  • 2015-05-11-1059-08.log
Isegrim
Open the windows search. Search for cmd, rightclick > as administrator. Type sfc /scannow.
This should find corrupted files on your pc, if you have any and will try to fix them.
This helped me with obs and two freezes in a row.
