Bug Report OBS Crashed a couple of times
jslupik
This crash appears to have occured in the 'c:\users\john\downloads\obs_0_625b (1)\64bit\libx264-142.dll' module.
Fault address: 000000005F017C90 (c:\users\john\downloads\obs_0_625b (1)\64bit\libx264-142.dll)
OBS version: Open Broadcaster Software v0.625b
CPU: AMD FX(tm)-8350 Eight-Core Processor
Crashing thread stack trace:
0000009DAC8D8B20 000000005F017C90 0000000000000000 0000000000000000 0000000000000000 0000000000000000 libx264-142.dll!0x5f017c90
0000009DAC8D8C30 000000005F03E23C 0000000000000000 0000000000000000 0000000000000000 0000000000000000 libx264-142.dll!0x5f03e23c
0000009DAC8DDA80 000000005F06D959 0000009DA6A6DD18 000000005F070333 0000009DA6A6DCA0 000000005EFAECE9 libx264-142.dll!0x5f06d959
0000009DAC8DF900 000000005EFA963E 0000009DA6A6DCA0 00000000FFFFFFFE 0000000000000000 000007FB1B5E18D2 libx264-142.dll!0x5efa963e
0000009DAC8DF960 000000005F06FE1D 0000009DA6A71BC0 0000009DA6A71BC0 0000000000000000 0000000000000000 libx264-142.dll!0x5f06fe1d
0000009DAC8DF9B0 000000005F070163 0000009DA69C6140 0000000000000000 0000000000000000 0000000000000000 libx264-142.dll!0x5f070163
0000009DAC8DF9E0 000007FB1B5E707B 000007FB1B66E9E0 0000009DA6A71BC0 0000000000000000 0000000000000000 msvcrt.dll!0x7fb1b5e707b
0000009DAC8DFA10 000007FB1B605E6D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 msvcrt.dll!0x7fb1b605e6d
0000009DAC8DFA40 000007FB1B321842 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7fb1b321842
0000009DAC8DFA70 000007FB1DB0D609 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7fb1db0d609
A minidump was saved to C:\Users\John\AppData\Roaming\OBS\crashDumps\OBSCrashDump2014-07-02_2.dmp.
List of loaded modules:
Base Address Module
and the first instance
Fault address: 000000005F05866B (c:\users\john\downloads\obs_0_625b (1)\64bit\libx264-142.dll)
000000AB15F2D760 000000005F05866B 0000000000000000 0000000000000000 0000000000000000 0000000000000000 libx264-142.dll!0x5f05866b
000000AB15F2D890 000000005F06DA79 000000AB159C70F8 000000005F070333 000000AB159C7080 000000005EFAECE9 libx264-142.dll!0x5f06da79
000000AB15F2F710 000000005EFA963E 000000AB159C7080 00000000FFFFFFFE 0000000000000000 000007FB1B5E18D2 libx264-142.dll!0x5efa963e
000000AB15F2F770 000000005F06FE1D 000000AB159C0FE0 000000AB159C0FE0 0000000000000000 0000000000000000 libx264-142.dll!0x5f06fe1d
000000AB15F2F7C0 000000005F070163 000000AB159C3730 0000000000000000 0000000000000000 0000000000000000 libx264-142.dll!0x5f070163
000000AB15F2F7F0 000007FB1B5E707B 000007FB1B66E9E0 000000AB159C0FE0 0000000000000000 0000000000000000 msvcrt.dll!0x7fb1b5e707b
000000AB15F2F820 000007FB1B605E6D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 msvcrt.dll!0x7fb1b605e6d
000000AB15F2F850 000007FB1B321842 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7fb1b321842
000000AB15F2F880 000007FB1DB0D609 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7fb1db0d609
A minidump was saved to C:\Users\John\AppData\Roaming\OBS\crashDumps\OBSCrashDump2014-07-02_1.dmp.
Base Address Module
jslupik
I've ran all mem tests possible already and none of my sticks are faulty, i already tested my harddrive as well as my windows files for any corruptions/misconfigurations and nothing comes back. Ive checked my BIOS settings and everything is fine and Biocheck comes clean
I use Xpslit hours on end and have no issues with it, so it has to be some configuration in OBS settings or some file not working properly. I am still crashing OBS and System freeze only when running OBS the only thing that i would figure out is that by default my computer is overclocked at 4.5 but that is at its default setting my true overclock i can go up to 5 and push 5.1 before reaching an unstable point, so it could be a possibility i would need to go back down to 4.0
Some things i do notice :
When running OBS i stream and have nightbot running with Auto DJ and have google chrome up, when monitoring usage
I spike up to 61% total MEM usage, majority of it being WoW retail at 2gigs but i do notice OBS starting from 200mb and slowly climbing, after about an half hour or so its at 500+MB and then continues to spike up to 1g of usage. When i use xsplit its a stable 215mb usage no increase/spike. Both 1 hr test times
I run on a 64 bit system with backwards compatability and can usually run 32bit or 64 bit programs on Win 8.1, i was constantly blue screening when using the 32 bit version, and when i went to 64 it stopped blue screening.
R1CH
You should probably investigate whatever is causing the blue screening, that doesn't sound right.
jslupik
It doesn't blue screen just freezes up requiring a hard reset that's about it, the blue screen stopped when i went from 32bit to 64bit I really don't know what to test really,
R1CH
Freezing, blue screens and crashing definitely point to hardware / driver issues more than OBS itself.
