Bug Report OBS Crash
hagspam
After hitting preview my screen goes black and obs crashes. Doesn't matter what settings I use or if it's a blank scene. I also get a message that my display driver failed. I also tried reinstalling my video drivers and OBS as well with same error happening. Any help would be appreciated.
https://obsproject.com/ - include the contents of this crash log and the
This crash appears to have occured in the 'c:\windows\syswow64\kernelbase.dll' module.
**** UNHANDLED EXCEPTION: e0434352
Fault address: 7556C42D (c:\windows\syswow64\kernelbase.dll)
OBS version: Open Broadcaster Software v0.655b
CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Crashing thread stack trace:
0A0DEDD8 7556C42D E0434352 00000001 00000005 0A0DEE94 kernelbase.dll!0x7556c42d
0A0DEE30 73308FDB 00000000 C59A6644 68581BD1 0A0DEFCC clr.dll!0x73308fdb
0A0DEED0 73309C19 0434BA9C 0700F170 00D56663 CF971E97 clr.dll!0x73309c19
0A0DEFA4 00D533EB 00000000 3F800000 3E100000 3C000000 <unknown>!0xd533eb
0A0DEFE4 00D5704A 00000000 00000000 065409B0 731B2070 <unknown>!0xd5704a
0A0DF314 00D53A08 00000000 68581BD1 00D539C8 0700F170 <unknown>!0xd53a08
0A0DF350 00CAA326 0702E558 00000000 00000000 CF971E97 <unknown>!0xcaa326
0A0DF380 03F70F4C 00000000 00000000 00000000 0434B068 <unknown>!0x3f70f4c
0A0DF3C0 00D561D8 0051A280 00000000 00000000 00000000 <unknown>!0xd561d8
0A0DF730 00EB2C08 00000000 00521000 00D539C8 0700F170 obs.exe!D3D10System::DrawSpriteEx+0x78
0A0DF754 00CAA4DA 0702E558 00000000 00000000 00000000 <unknown>!0xcaa4da
0A0DF784 03F72F5C 755E336A 00000000 0A0DFB1C 774D9882 <unknown>!0x3f72f5c
0A0DFAD4 00EDCAD5 00000000 0A0DFB1C 774D9882 00000000 obs.exe!OBS::MainCaptureThread+0x5
0A0DFAD8 755E336A 00000000 7D574D93 00000000 00000000 kernel32.dll!0x755e336a
0A0DFAE4 774D9882 00EDCAD0 00000000 00000000 00000000 ntdll.dll!0x774d9882
0A0DFB24 774D9855 00EDCAD0 00000000 00000000 00000000 ntdll.dll!0x774d9855
A minidump was saved to C:\Users\Jake\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-09-28_12.dmp.
List of loaded modules:
Base Address Module
  • OBSCrashDump2015-09-28_12.dmp
hagspam
I realized what caused it, it was MSI Gaming App. I had the OSD turned on to show FPS, and i guess it crashes the program
