Bug Report OBS crash
luckystrikex
it crashes everytime i try to preview a stream. [crash text]
https://obsproject.com/ - include the contents of this crash log and the
This crash appears to have occured in the 'c:\windows\system32\nvwgf2um.dll' module.
Fault address: 03D900B3 (c:\windows\system32\nvwgf2um.dll)
OBS version: Open Broadcaster Software v0.653b
CPU: Intel(R) Core(TM) i7-2860QM CPU @ 2.50GHz
Crashing thread stack trace:
03A9F3E4 03D900B3 0046E610 00000000 12D9F210 00000000 nvwgf2um.dll!0x3d900b3
03A9F418 043790F6 0046E610 04F229DC 00000000 5E09D07C nvwgf2um.dll!0x43790f6
03A9F8B0 03D9E0C0 0046E610 04EDE900 0041CD88 03D9AF71 nvwgf2um.dll!0x3d9e0c0
03A9F8E0 03D9CD08 04EDE9F0 8F3BB8F9 00000000 04EF3C88 nvwgf2um.dll!0x3d9cd08
03A9F908 0459983C 00000000 03A9F950 75BF337A 0041CD88 nvwgf2um.dll!0x459983c
03A9F940 04599964 0041CD88 03A9F990 776992E2 0041CD88 nvwgf2um.dll!0x4599964
03A9F94C 75BF337A 0041CD88 782B03EF 00000000 00000000 kernel32.dll!0x75bf337a
03A9F958 776992E2 045998E8 0041CD88 00000000 00000000 ntdll.dll!0x776992e2
03A9F998 776992B5 045998E8 0041CD88 00000000 00000000 ntdll.dll!0x776992b5
A minidump was saved to C:\Users\Alienware\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-07-30_4.dmp.
List of loaded modules:
Base Address Module
[end crash text]
luckystrikex
This keep happening too me its Peeing me off so much.... How do we fix this OBS ?????????
hey so i think i figured it out cause mines working now. go through your program files and look for OBS. DELETE EVERYTHING! if you cant delete something because a file is "running" restart your computer and delete it, then reinstall.
Update: i take back everything. it's broken again. same error code.
R1CH
This is usually caused by poor laptop GPU drivers. Use a desktop if possible.
