Bug Report OBS Crash
Skraluk
Hi,
Obs crashed after testing the record function for a longer time (i want to record a training in my Company next week). i started recording and left the pc alone for about 1:30h. i didn't Change any Settings except the file path. i left some YouTube Video in endless Loop running so that something happens on Screen. the pc went to lock mode (sry for my bad english) the Screen where you log in to Windows, could be related but iam not sure.
iam running Windows 8.1 Pro 64Bit with 64 Bit OBS, on an i7-4790, 32Gb RAM, Samsung SSD 840 EVO 500GB (there is enough space on the hard drive)
the recording was done at a Resolution of 3840 x 2160 with no scaling down.
when i record smaller time periods everything is fine.
do i Need to disable some sleep mode or something like that
here is the log
[URL]http://www.obsproject.com/[/URL] - include the contents of this crash log and the
This crash appears to have occured in the 'c:\windows\system32\kernelbase.dll' module.
**** UNHANDLED EXCEPTION: 80000003
Fault address: 00007FF838C59E3A (c:\windows\system32\kernelbase.dll)
OBS version: Open Broadcaster Software v0.625b
CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
Crashing thread stack trace:
Stack  EIP  Arg0  Arg1  Arg2  Arg3  Address
0000009ECAEAEF48 00007FF838C59E3A 00007FF82CA108E0 0000000000007530 0000009ECAEAEEA8 0000000000000000 kernelbase.dll!0x7ff838c59e3a
0000009ECAEAEF50 00007FF82C9E16B3 0000009ECB1B1000 00007FF7AB41C728 0000009ECB1B1000 00007FF800000002 obsapi.dll!OSTerminateThread+0x33
0000009ECAEAEF80 00007FF7AB375E13 0000009ECAEAF150 0000000000000400 0000000002450309 0000000000000000 obs.exe!OBS::Stop+0x163
0000009ECAEAF020 00007FF7AB373EF2 0000000000001389 0000000000000000 00000000003D062C 00007FF83B728CA8 obs.exe!OBS::StopRecording+0x22
0000009ECAEAF050 00007FF7AB39B85A 0000000000000000 0000000000000000 0000000000000070 FFFFFFFFFFFFFFFF obs.exe!OBS::OBSProc+0x8ba
0000009ECAEAF280 00007FF83B112434 0000009ECB607BC0 00007FF7AB39AFA0 0000000000000111 00000000000A02F6 user32.dll!0x7ff83b112434
0000009ECAEAF340 00007FF83B13422F 0000000000000000 0000000000000000 0000000000001389 0000009ECB607BC0 user32.dll!Ordinal2540+0x12b
0000009ECAEAF3D0 00007FF83B115191 0000009ECB070230 0000000054010000 0000000000000001 0000000000000001 user32.dll!0x7ff83b115191
0000009ECAEAF430 00007FF836CC4B18 0000000000000202 0000009ECAEAF529 0000009ECB070230 0000000000000000 comctl32.dll!0x7ff836cc4b18
0000009ECAEAF470 00007FF836CC4AF3 0000009ECAEAF6B8 00007FF7AB00E000 0000009ECAEAF698 00007FF83B113785 comctl32.dll!0x7ff836cc4af3
0000009ECAEAF590 00007FF83B112434 0000009ECB5EC820 0000009ECAEAF858 00007FF7AB00E800 00007FF836C74590 user32.dll!0x7ff83b112434
0000009ECAEAF650 00007FF83B112297 0000009ECB1F0000 0000000000000000 0000000000000001 0000000000000000 user32.dll!0x7ff83b112297
0000009ECAEAF6D0 00007FF83B136FD7 00000000003802D9 0000009ECAEAF830 0000009ECB1F0000 0000009ECB1F0000 user32.dll!0x7ff83b136fd7
0000009ECAEAF730 00007FF7AB367CE9 0000000000000000 0000000000000001 00007FF7AB340000 0000000000000000 obs.exe!WinMain+0xa29
0000009ECAEAFCD0 00007FF7AB3DD8C0 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!__tmainCRTStartup+0x148
0000009ECAEAFD10 00007FF83B4016AD 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ff83b4016ad
0000009ECAEAFD40 00007FF83B7634A5 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff83b7634a5
Video thread stack trace:
0000009EFFBBF978 00007FF83B78AD4A 0000000000000003 00007FF82C9CEC3A 0000009ECB1DDB78 00003A2ADA6B93D8 ntdll.dll!0x7ff83b78ad4a
0000009EFFBBF980 00007FF838B81148 0000000000000000 00003A2ADA6B93D8 00003A2A00000000 000000000000019C kernelbase.dll!0x7ff838b81148
0000009EFFBBFA20 00007FF7AB37BA00 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::MainCaptureLoop+0x1ab0
0000009EFFBBFEC0 00007FF7AB378899 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::MainCaptureThread+0x9
0000009EFFBBFEF0 00007FF83B4016AD 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ff83b4016ad
0000009EFFBBFF20 00007FF83B7634A5 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff83b7634a5
Encode thread stack trace:
0000009EFFABFBB8 00007FF83B78B04A 0000009EFFABFC78 004B24FA00001047 0000000000000022 00007FF82C9CEC3A ntdll.dll!0x7ff83b78b04a
0000009EFFABFBC0 00007FF838B8124A 0000000000000370 0000009E00000000 0000000040000024 0000000000000000 kernelbase.dll!0x7ff838b8124a
0000009EFFABFC60 00007FF7AB379ACB 0000000000000000 0000000000000000 000000000002554C 0000000000000049 obs.exe!OBS::EncodeLoop+0x60b
0000009EFFABFDA0 00007FF7AB378889 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::EncodeThread+0x9
0000009EFFABFDD0 00007FF83B4016AD 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ff83b4016ad
0000009EFFABFE00 00007FF83B7634A5 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff83b7634a5
A minidump was saved to C:\Users\Johannes.jockel\AppData\Roaming\OBS\crashDumps\OBSCrashDump2014-09-05_1.dmp.
List of loaded modules:
Base Address  Module
[code]
  • crashDumps.7z
Skraluk
a 25 Minute recording with the same conditions (Windows went to lock Screen, endless YouTube) went fine
Skraluk
another Crash after looking at the pc after a 1:30h session. i left the pc alone during that time, no other Person did interfere.
00000013B7C5EDB8 00007FF838C59E3A 00007FF82CA108E0 0000000000007530 00000013B7C5ED18 0000000000000000 kernelbase.dll!0x7ff838c59e3a
00000013B7C5EDC0 00007FF82C9E16B3 00000013BA4B1000 00007FF7AB41C728 00000013BA4B1000 00007FF800000002 obsapi.dll!OSTerminateThread+0x33
00000013B7C5EDF0 00007FF7AB375E13 00000013B7C5EFC0 0000000000000400 0000000004C10537 0000000000000000 obs.exe!OBS::Stop+0x163
00000013B7C5EE90 00007FF7AB373EF2 0000000000001389 0000000000000000 00000000001104BE 00007FF83B728CA8 obs.exe!OBS::StopRecording+0x22
00000013B7C5EEC0 00007FF7AB39B85A 0000000000000000 0000000000000000 0000000000000070 FFFFFFFFFFFFFFFF obs.exe!OBS::OBSProc+0x8ba
00000013B7C5F0F0 00007FF83B112434 00000013B8237950 00007FF7AB39AFA0 0000000000000111 00000000000E02D8 user32.dll!0x7ff83b112434
00000013B7C5F1B0 00007FF83B13422F 0000000000000000 0000000000000000 0000000000001389 00000013B8237950 user32.dll!Ordinal2540+0x12b
00000013B7C5F240 00007FF83B115191 00000013B7DA0CD0 0000000054010001 0000000000000001 0000000000000001 user32.dll!0x7ff83b115191
00000013B7C5F2A0 00007FF836CC4B18 0000000000000202 00000013B7C5F399 00000013B7DA0CD0 0000000000000000 comctl32.dll!0x7ff836cc4b18
00000013B7C5F2E0 00007FF836CC4AF3 00000013B7C5F528 00007FF7AAF3D000 00000013B7C5F508 00007FF83B113785 comctl32.dll!0x7ff836cc4af3
00000013B7C5F400 00007FF83B112434 00000013B820F900 00000013B7C5F6C8 00007FF7AAF3D800 00007FF836C74590 user32.dll!0x7ff83b112434
00000013B7C5F4C0 00007FF83B112297 00000013BA4E0000 0000000000000000 0000000000000001 0000000000000000 user32.dll!0x7ff83b112297
00000013B7C5F540 00007FF83B136FD7 0000000001B305D3 00000013B7C5F6A0 00000013BA4E0000 00000013BA4E0000 user32.dll!0x7ff83b136fd7
00000013B7C5F5A0 00007FF7AB367CE9 0000000000000000 0000000000000001 00007FF7AB340000 0000000000000000 obs.exe!WinMain+0xa29
00000013B7C5FB40 00007FF7AB3DD8C0 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!__tmainCRTStartup+0x148
00000013B7C5FB80 00007FF83B4016AD 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ff83b4016ad
00000013B7C5FBB0 00007FF83B7634A5 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff83b7634a5
00000013B0CDF718 00007FF83B78AD4A 0000000000000003 00007FF82C9CEC3A 00000013BA4C3878 000042CC110F3923 ntdll.dll!0x7ff83b78ad4a
00000013B0CDF720 00007FF838B81148 0000000000000001 000042CC110F3923 000042CC00000000 00000000000001A4 kernelbase.dll!0x7ff838b81148
00000013B0CDF7C0 00007FF7AB37BA00 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::MainCaptureLoop+0x1ab0
00000013B0CDFC60 00007FF7AB378899 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::MainCaptureThread+0x9
00000013B0CDFC90 00007FF83B4016AD 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ff83b4016ad
00000013B0CDFCC0 00007FF83B7634A5 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff83b7634a5
000000138E08F918 00007FF83B78B04A 000000138E08F9D8 0056AD1000001048 0000001300000043 00007FF82C9CEC3A ntdll.dll!0x7ff83b78b04a
000000138E08F920 00007FF838B8124A 000000000000036F 0000001300000000 0000000040000024 0000000000000000 kernelbase.dll!0x7ff838b8124a
000000138E08F9C0 00007FF7AB379AD9 0000000000000000 0000000000000000 0000000000029F88 000000000000007B obs.exe!OBS::EncodeLoop+0x619
000000138E08FB00 00007FF7AB378889 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::EncodeThread+0x9
000000138E08FB30 00007FF83B4016AD 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ff83b4016ad
000000138E08FB60 00007FF83B7634A5 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff83b7634a5
A minidump was saved to C:\Users\Johannes.jockel\AppData\Roaming\OBS\crashDumps\OBSCrashDump2014-09-05_2.dmp.
Base Address  Module
[code]
  • crashDumps2.7z
