Bug Report OBS crash
Soliduz
I was using OBS a moment checked on the preview. then went to change settings and closed OBS then open again. I went to the check preview stream and it would crash with a notepad that pops up. it says:
This crash appears to have occured in the 'c:\program files (x86)\obs\plugins\dshowplugin.dll' module.
Fault address: 6B9DCA70 (c:\program files (x86)\obs\plugins\dshowplugin.dll)
OBS version: Open Broadcaster Software v0.625b
CPU: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
Crashing thread stack trace:
124BFB60 6B9DCA70 1BFB4000 1B880000 00001E00 000001E0 dshowplugin.dll!DeviceSource::Convert422To444+0x70
124BFB80 6B9D5B96 00380000 00000000 00106B46 00000000 dshowplugin.dll!DeviceSource::Preprocess+0x1e6
124BFBD4 62175438 00000000 00000000 77A59EE1 01000100 obsapi.dll!Scene::Preprocess+0x28
124BFBE0 00106B46 76C4338A 00000000 124BFF00 77A59F72 obs.exe!OBS::MainCaptureLoop+0x9c6
124BFEB8 00104E55 00000000 124BFF00 77A59F72 00000000 obs.exe!OBS::MainCaptureThread+0x5
124BFEBC 76C4338A 00000000 65FD27DA 00000000 00000000 kernel32.dll!0x76c4338a
124BFEC8 77A59F72 00104E50 00000000 00000000 00000000 ntdll.dll!0x77a59f72
124BFF08 77A59F45 00104E50 00000000 00000000 00000000 ntdll.dll!0x77a59f45
A minidump was saved to C:\Users\Ziyad\AppData\Roaming\OBS\crashDumps\OBSCrashDump2014-07-01_6.dmp.
List of loaded modules:
Base Address Module
I don't understand why its happening.
Lain
Lain
Hm, I need to get the LGP. Did you manually change the resolution? If you change it higher than the default resolution it can cause this crash (which is really my fault for allowing). You're using the avermedia stream engine, correct?
Soliduz
I had my settings for OBS & LGP at 1920x1080 resolution. I remember when starting at the PS3 menu the preview stream works fine but I when I get into a game it crashes.
Lain
Lain
Try setting the LGP to 1280x720 instead -- I can't help but wonder if the device is dynamically changing the resolution or something, that seems very unusual. I may have to buy that device to check it out. How do you have your PS3 connected to the LGP? I assume component?
Soliduz
yes it component. ok I tried it and it seems to work fine when I put a game on. I'm really confused why would it crash when playing a game but not on the PS3 menu. anyways thanks for the help.
Hopewithinchaos
Most PS3 games don't run at 1080P. So while the main XMB menu runs at 1080P, it'll switch to 720P when you launch the game. This will cause that crash.
