Bug Report OBS Crash when using Elgato *LOG BELOW*
Everytime I try to preview or stream it crashes ONLY when I use my Elgato. Drivers are up to date. Idk what to do. Please help, This has been happening for over a week now.
17:13:01: Open Broadcaster Software v0.638b - 32bit (´・ω・`)
17:13:01: -------------------------------
17:13:01: CPU Name: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
17:13:01: CPU Speed: 2294MHz
17:13:01: Physical Memory: 4095MB Total, 3655MB Free
17:13:01: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
17:13:01: monitor 1: pos={0, 0}, size={1024, 768}
17:13:01: Windows Version: 6.1 Build 7601 S
17:13:01: Aero is Disabled
17:13:01: OBS Modules:
17:13:01: Base Address Module
17:13:01: 008D0000 OBS.exe
17:13:01: 52090000 OBSApi.dll
17:13:01: 5D5B0000 DShowPlugin.dll
17:13:01: 5D6F0000 GraphicsCapture.dll
17:13:01: 5D550000 NoiseGate.dll
17:13:01: 5D590000 PSVPlugin.dll
17:13:01: ------------------------------------------
17:13:01: Adapter 1
17:13:01: Video Adapter: NVIDIA GeForce GT 650M
17:13:01: Video Adapter Dedicated Video Memory: 1019019264
17:13:01: Video Adapter Shared System Memory: 2901571584
17:13:01: Video Adapter Output 1: pos={0, 0}, size={1024, 768}, attached=true
17:13:01: Adapter 2
17:13:01: =====Stream Start: 2014-12-03, 17:13:01===============================================
17:13:01: Multithreaded optimizations: On
17:13:01: Base resolution: 1024x768
17:13:01: Output resolution: 1024x768
17:13:01: Loading up D3D10 on NVIDIA GeForce GT 650M (Adapter 1)...
17:13:02: ------------------------------------------
17:13:02: Audio Format: 48000 Hz
17:13:02: Audio Channels: 2 Ch
17:13:02: Playback device Default
17:13:02: Using desktop audio input: Speakers (Sound Blaster Recon3Di)
17:13:02: Global Audio time adjust: 0
17:13:02: Using auxilary audio input: Microphone Array (Sound Blaster Recon3Di)
17:13:02: Mic time offset: 0
17:13:02: Audio Encoding: AAC
17:13:02: bitrate: 128
17:13:02: device: Elgato Game Capture HD,
17:13:02: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
17:13:02: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 166833-166833
17:13:02: use buffering: false - 0, fourCC: 'UYVY'
17:13:02:
17:13:02: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
17:13:02: Using directshow input
17:13:02: Scene buffering time set to 700
17:13:02: Video Encoding: x264
17:13:02: fps: 30
17:13:02: width: 1024, height: 768
17:13:02: preset: veryfast
17:13:02: profile: high
17:13:02: keyint: 250
17:13:02: CBR: yes
17:13:02: CFR: yes
17:13:02: max bitrate: 1800
17:13:02: buffer size: 1800
