Bug Report OBS Crash when streaming 1080p
Maltahl
I had OCed my Intel HD 4600 to 1400 Mhz ( Rock Stable) and was trying 1080p 60 fps with best quality.
Log file from session ( since i could not add 3 files to the post)
15:06:06: CUDA loaded successfully
15:06:07: 1 CUDA capable devices found
15:06:07: [ GPU #0 - < GeForce GTX 765M > has Compute SM 3.0, NVENC Available ]
15:06:21: Open Broadcaster Software v0.612b - 64bit ( ^ω^)
15:06:21: -------------------------------
15:06:21: CPU Name: Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
15:06:21: CPU Speed: 2394MHz
15:06:21: Physical Memory:  16303MB Total, 10866MB Free
15:06:21: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
15:06:21: monitor 1: pos={-1920, 0}, size={1920, 1080}
15:06:21: monitor 2: pos={0, 0}, size={1920, 1080}
15:06:21: Windows Version: 6.2 Build 9200
15:06:21: Aero is Enabled
15:06:21: OBS Modules:
15:06:21: Base Address     Module
15:06:21: 0000000052270000 OBS.exe
15:06:21: 00000000EF290000 OBSApi.dll
15:06:21: 0000000003AA0000 DShowPlugin.dll
15:06:21: 0000000004B00000 GraphicsCapture.dll
15:06:21: 0000000004AA0000 NoiseGate.dll
15:06:21: 0000000004A50000 PSVPlugin.dll
15:06:21: ------------------------------------------
15:06:21: Adapter 1
15:06:21:   Video Adapter: NVIDIA GeForce GTX 765M
15:06:21:   Video Adapter Dedicated Video Memory: 2085482496
15:06:21:   Video Adapter Shared System Memory: 2147610624
15:06:21:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
15:06:21:   Video Adapter Output 2: pos={-1920, 0}, size={1920, 1080}, attached=true
15:06:21: Adapter 2
15:06:21: =====Stream Start: 2014-02-21, 15:06:21===============================================
15:06:21:   Multithreaded optimizations: On
15:06:21:   Base resolution: 1920x1080
15:06:21:   Output resolution: 1920x1080
15:06:21: Loading up D3D10 on NVIDIA GeForce GTX 765M (Adapter 1)...
15:06:21: Audio Format: 44100hz
15:06:21: Playback device Default
15:06:21: Using desktop audio input: Speakers (VIA High Definition Audio)
15:06:21: Using auxilary audio input: Microphone (VIA High Definition Audio)
15:06:21: Audio Encoding: AAC
15:06:21:     bitrate: 128
15:06:21: Using Window Capture
15:06:21: Using text output
15:06:21: Using bitmap image
15:06:21:     device: \\?\usb#vid_046d&pid_082d&mi_00#6&10e9ac1a&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:06:21:     device id \\?\usb#vid_046d&pid_082d&mi_00#6&10e9ac1a&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:06:21:     chosen type: I420, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000
15:06:21:     use buffering: false - 0, fourCC: 'I420'
15:06:21:     audio device: Disable,
15:06:21:     audio device id Disabled,
15:06:21:
15:06:21: Using directshow input
15:06:21: Scene buffering time set to 700
15:06:21: Found QSV hardware support
15:06:22: ------------------------------------------
15:06:22: QSV version 1.6 using MFX_IMPL_HARDWARE_ANY | MFX_IMPL_VIA_D3D11 (actual: MFX_IMPL_HARDWARE | MFX_IMPL_VIA_D3D11)
15:06:22: Using 13 bitstreams and 13 frame buffers
15:06:22: Video Encoding: QSV
15:06:22:     fps: 60
15:06:22:     width: 1920, height: 1080
15:06:22:     target-usage: MFX_TARGETUSAGE_1_BEST_QUALITY
15:06:22:     profile: MFX_PROFILE_AVC_MAIN
15:06:22:     CBR: yes
15:06:22:     CFR: yes
15:06:22:     max bitrate: 3500
15:06:23: Using RTMP service: Twitch / Justin.tv
15:06:23:   Server selection: rtmp://live-ams.justin.tv/app
15:06:23:   Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
15:06:24: Completed handshake with rtmp://live-ams.justin.tv/app in 513 ms.
15:06:25: SO_SNDBUF was at 65536
15:06:25: SO_SNDBUF is now 65536
15:06:26: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 0 / 463872)
15:06:51: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 0 / 463872)
15:07:05: Using graphics capture
15:07:10: SharedTexCapture hooked
15:07:14: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 524288 (buffer: 0 / 463872)
15:07:16: Capture window 0x0014093E invalid or changing, terminating capture
15:07:29: SharedTexCapture hooked
15:07:45: Capture window 0x00020776 invalid or changing, terminating capture
15:07:48: Total frames encoded: 5139, total frames duplicated: 792 (15.41%)
15:07:48: Number of frames skipped due to encoder lag: 130 (2.53%)
15:07:48: Total frames rendered: 4943, number of late frames: 52 (1.05%) (it's okay for some frames to be late)
15:07:48: RTMPPublisher::SocketLoop: Graceful loop exit
15:07:49: Average send payload: 8690 bytes, average send interval: 19 ms
15:07:49: Number of times waited to send: 0, Waited for a total of 0 bytes
15:07:49: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:07:49: Number of bytes sent: 37596785
15:07:49:
15:07:49: Profiler time results:
15:07:49:
15:07:49: ==============================================================
15:07:49: video thread frame - [100%] [avg time: 6.111 ms] [children: 73.4%] [unaccounted: 26.6%]
15:07:49: | scene->Preprocess - [69.8%] [avg time: 4.264 ms]
15:07:49: | GPU download and conversion - [3.58%] [avg time: 0.219 ms] [children: 2.45%] [unaccounted: 1.13%]
15:07:49: | | flush - [1.72%] [avg time: 0.105 ms]
15:07:49: | | CopyResource - [0.605%] [avg time: 0.037 ms]
15:07:49: | | conversion to 4:2:0 - [0.131%] [avg time: 0.008 ms]
15:07:49: Convert444Threads - [100%] [avg time: 1.857 ms] [children: 99.7%] [unaccounted: 0.323%]
15:07:49: | Convert444toNV12 - [99.7%] [avg time: 1.851 ms]
15:07:49: encoder thread frame - [100%] [avg time: 3.384 ms] [children: 99.2%] [unaccounted: 0.827%]
15:07:49: | QueueEncodeTask - [57.6%] [avg time: 1.949 ms]
15:07:49: | ProcessEncodedFrame - [40.6%] [avg time: 1.375 ms]
15:07:49: | sending stuff out - [0.946%] [avg time: 0.032 ms]
15:07:49:
15:07:49:
15:07:49: Profiler CPU results:
15:07:49:
15:07:49: video thread frame - [cpu time: avg 4.147 ms, total 20500 ms] [avg calls per frame: 1]
15:07:49: | scene->Preprocess - [cpu time: avg 3.29 ms, total 16265.6 ms] [avg calls per frame: 1]
15:07:49: | GPU download and conversion - [cpu time: avg 0.164 ms, total 812.5 ms] [avg calls per frame: 1]
15:07:49: | | flush - [cpu time: avg 0.091 ms, total 453.125 ms] [avg calls per frame: 1]
15:07:49: | | CopyResource - [cpu time: avg 0.038 ms, total 187.5 ms] [avg calls per frame: 1]
15:07:49: | | conversion to 4:2:0 - [cpu time: avg 0.009 ms, total 46.875 ms] [avg calls per frame: 1]
15:07:49: Convert444Threads - [cpu time: avg 1.893 ms, total 18546.9 ms] [avg calls per frame: 2]
15:07:49: | Convert444toNV12 - [cpu time: avg 1.888 ms, total 18500 ms] [avg calls per frame: 2]
15:07:49: encoder thread frame - [cpu time: avg 0.042 ms, total 218.75 ms] [avg calls per frame: 1]
15:07:49: | QueueEncodeTask - [cpu time: avg 0.003 ms, total 15.625 ms] [avg calls per frame: 1]
15:07:49: | ProcessEncodedFrame - [cpu time: avg 0.021 ms, total 109.375 ms] [avg calls per frame: 1]
15:07:49: | sending stuff out - [cpu time: avg 0.012 ms, total 62.5 ms] [avg calls per frame: 1]
15:07:49:
15:07:49: =====Stream End: 2014-02-21, 15:07:49=================================================
15:09:28: =====Stream Start: 2014-02-21, 15:09:28===============================================
15:09:28:   Multithreaded optimizations: On
15:09:28:   Base resolution: 1920x1080
15:09:28:   Output resolution: 1920x1080
15:09:28: ------------------------------------------
15:09:28: Loading up D3D10 on NVIDIA GeForce GTX 765M (Adapter 1)...
15:09:28: Audio Format: 44100hz
15:09:28: Playback device Default
15:09:28: Using desktop audio input: Speakers (VIA High Definition Audio)
15:09:28: Using auxilary audio input: Microphone (VIA High Definition Audio)
15:09:28: Audio Encoding: AAC
15:09:28:     bitrate: 128
15:09:28: Using Window Capture
15:09:28: Using text output
15:09:28: Using bitmap image
15:09:28:     device: \\?\usb#vid_046d&pid_082d&mi_00#6&10e9ac1a&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:09:28:     device id \\?\usb#vid_046d&pid_082d&mi_00#6&10e9ac1a&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:09:28:     chosen type: I420, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000
15:09:28:     use buffering: false - 0, fourCC: 'I420'
15:09:28:     audio device: Disable,
15:09:28:     audio device id Disabled,
15:09:28:
15:09:28: Using directshow input
15:09:28: Using graphics capture
15:09:29: Scene buffering time set to 700
15:09:29: Found QSV hardware support
15:09:29: ------------------------------------------
15:09:29: QSV version 1.6 using MFX_IMPL_HARDWARE_ANY | MFX_IMPL_VIA_D3D11 (actual: MFX_IMPL_HARDWARE | MFX_IMPL_VIA_D3D11)
15:09:29: Using 13 bitstreams and 13 frame buffers
15:09:29: Video Encoding: QSV
15:09:29:     fps: 60
15:09:29:     width: 1920, height: 1080
15:09:29:     target-usage: MFX_TARGETUSAGE_1_BEST_QUALITY
15:09:29:     profile: MFX_PROFILE_AVC_MAIN
15:09:29:     CBR: yes
15:09:29:     CFR: yes
15:09:29:     max bitrate: 3500
15:09:30: Using RTMP service: Twitch / Justin.tv
15:09:30:   Server selection: rtmp://live-ams.justin.tv/app
15:09:30:   Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
15:09:31: Completed handshake with rtmp://live-ams.justin.tv/app in 403 ms.
15:09:32: SO_SNDBUF was at 65536
15:09:32: SO_SNDBUF is now 65536
15:09:33: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 0 / 463872)
15:09:42: SharedTexCapture hooked
15:09:47: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 524288 (buffer: 47682 / 463872)
15:10:20: RTMPPublisher::SocketLoop: Received FD_CLOSE, 5036 ms since last send (buffer: 0 / 463872)
15:10:20: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
15:10:50: WARNING: Forcibly terminating a thread after 30000 ms timeout!
  • OBSCrashLog2014-02-21_1.txt
