TavidzTV
I cannot find the dump files on my computer. They don't exist.
I'm trying to select "El Gato HD60" layer and Right Click. Then I try and select "Properties". It opens then I select Configure. After that I try selecting the option to lower the resolution for the Xbox 360 (which may be the reason my stream is terrible looking...) and then it crashes.
I have superb hardware and cannot figure out why OBS is not outputting perfect quality streams.
Here's what's happening here:
This crash appears to have occured in the 'c:\program files (x86)\obs\plugins\dshowplugin.dll' module.
Fault address: 6EAED5B0 (c:\program files (x86)\obs\plugins\dshowplugin.dll)
OBS version: Open Broadcaster Software v0.651b
CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Crashing thread stack trace:
276AF5C0 6EAED5B0 391D4000 35440000 00001E00 000001E0 dshowplugin.dll!DeviceSource::Convert422To444+0x110
276AF5E0 6EAE60F8 00000000 00000000 00000024 01000101 dshowplugin.dll!DeviceSource::Preprocess+0x1c8
276AF630 00EDDFE3 766A919F 00000000 276AF9B4 7703A8CB obs.exe!OBS::MainCaptureLoop+0xb23
276AF968 00EDBDF5 00000000 276AF9B4 7703A8CB 00000000 obs.exe!OBS::MainCaptureThread+0x5
276AF96C 766A919F 00000000 0CD3B399 00000000 00000000 kernel32.dll!0x766a919f
276AF978 7703A8CB FFFFFFFF 7702F676 00000000 00000000 ntdll.dll!0x7703a8cb
276AF9BC 7703A8A1 00EDBDF0 00000000 00000000 00000000 ntdll.dll!0x7703a8a1
A minidump was saved to C:\Users\Daveed\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-05-01_1.dmp.
List of loaded modules:
Base Address Module
