Bug Report OBS crash on quit
EricSV
Not a real big deal, since it only happens when I quit the program. Figured I would post the crash logs though. Last thing I did in OBS was add NightDevs follower notifier and customized it a little bit. I believe you are supposed to use 32-bit OBS with all of NightDevs tools, but since I had everything going in 64-bit already with a 64-bit CLR plugin I just went ahead and stuck with that. Works fine. Up until closing anyways.
  • OBSCrashLog2014-07-12_4.txt
  • OBSCrashDump2014-07-12_4.7z
dodgepong
Administrator
Community Helper
The 64bit version of the CLR Browser source is unstable, and is not recommended. That is what is crashing here in this case.
