Bug Report OBS Crash Kernel
Mosky89
Hi,
Yesterday OBS begins to crash when attempting to record/stream/preview.
Last Sunday ( 2 days ago) OBS works fine and I don't update anything in my computer (drivers nvidia/windows/obs...).
Here is the content of the error log:
https://obsproject.com/ - include the contents of this crash log and the
This crash appears to have occured in the 'c:\windows\system32\kernelbase.dll' module.
**** UNHANDLED EXCEPTION: e0434352
Fault address: 7645DAE8 (c:\windows\system32\kernelbase.dll)
OBS version: Open Broadcaster Software v0.658b
Windows version: 10.0 (Build 10586)
CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Crashing thread stack trace:
26B5F268 7645DAE8 E0434352 00000001 00000005 26B5F328 kernelbase.dll!0x7645dae8
26B5F2C8 71BAA701 00000000 B842CF69 69C9DB30 26B5F454 clr.dll!0x71baa701
26B5F364 71BAAEEC 0541EE1C 100EE790 0E6B8983 9A15AD58 clr.dll!0x71baaeec
26B5F42C 0E01D90B 00000000 3F800000 3EAA0000 3C000000 <unknown>!0xe01d90b
26B5F46C 0E6B977B 00000000 00000000 0745E128 71AA29EC <unknown>!0xe6b977b
26B5F79C 0E6B1090 00000000 69C9DB30 0E6B1050 100EE790 <unknown>!0xe6b1090
26B5F7D8 07711F02 134FCD70 00000000 00000000 9A15AD58 <unknown>!0x7711f02
26B5F808 0DCC0DE4 00000000 00000000 71FDDCE0 FFFFFFFF <unknown>!0xdcc0de4
26B5F848 0E6B84F7 00000000 003B2C08 02459EC0 00000000 <unknown>!0xe6b84f7
26B5FBD8 62604063 26B5FC30 00000000 26B5FF74 0DCC2DF4 d3d11.dll!0x62604063
26B5FC24 003DF9C9 768C38F4 00000000 768C38D0 0F9C7038 obs.exe!OBS::MainCaptureLoop+0x1649
26B5FF7C 003DCCA5 00000000 768C38D0 0F9C7038 26B5FFD4 obs.exe!OBS::MainCaptureThread+0x5
26B5FF80 768C38F4 00000000 8F0F25E9 00000000 00000000 kernel32.dll!0x768c38f4
26B5FF94 77A55DE3 FFFFFFFF 77A7B7B6 00000000 00000000 ntdll.dll!0x77a55de3
26B5FFDC 77A55DAE 003DCCA0 00000000 00000000 00000000 ntdll.dll!0x77a55dae
A minidump was saved to C:\Users\Mosky\AppData\Roaming\OBS\crashDumps\OBSCrashDump2016-08-30_2.dmp.
List of loaded modules:
Base Address Module
  • OBSCrashLog2016-08-30_2.txt
R1CH
This looks like some 3rd party software has messed with your system and is hooking D3D apps with CLR code injection. What did you install recently?
Mosky89
Ty for the reply,
now I delete all the browser sources that I was using and the error continues:
2593F0A8 7645DAE8 E0434352 00000001 00000005 2593F168 kernelbase.dll!0x7645dae8
2593F108 71BAA701 00000000 3C2CAA57 69C9DB30 2593F294 clr.dll!0x71baa701
2593F1A4 71BAAEEC 05A5ECC0 0E152DF8 0F1F8CE3 1D476135 clr.dll!0x71baaeec
2593F26C 0EACD90B 00000000 3F800000 3EAA0000 3C000000 <unknown>!0xeacd90b
2593F2AC 0F1F9ADB 00000000 00000000 0792E308 71AA29EC <unknown>!0xf1f9adb
2593F5DC 0F1F1090 00000000 69C9DB30 0F1F1050 0E152DF8 <unknown>!0xf1f1090
2593F618 07BF1F02 0E152618 00000000 00000000 1D476135 <unknown>!0x7bf1f02
2593F648 0E7B0DE4 00000000 00000000 0E153D40 0D3D0280 <unknown>!0xe7b0de4
2593F688 0F1F8857 00000000 003B2C08 02D984C0 00000000 <unknown>!0xf1f8857
2593FA18 62604063 2593FA70 00000000 2593FDBC 0E7B2DF4 d3d11.dll!0x62604063
2593FA64 003DF9C9 768C38F4 00000000 768C38D0 4CD75FB1 obs.exe!OBS::MainCaptureLoop+0x1649
2593FDC4 003DCCA5 00000000 768C38D0 4CD75FB1 2593FE1C obs.exe!OBS::MainCaptureThread+0x5
2593FDC8 768C38F4 00000000 A29FC3A4 00000000 00000000 kernel32.dll!0x768c38f4
2593FDDC 77A55DE3 FFFFFFFF 77A7B7C7 00000000 00000000 ntdll.dll!0x77a55de3
2593FE24 77A55DAE 003DCCA0 00000000 00000000 00000000 ntdll.dll!0x77a55dae
A minidump was saved to C:\Users\Mosky\AppData\Roaming\OBS\crashDumps\OBSCrashDump2016-08-30_6.dmp.
Base Address Module
I didn't install anything between the Sunday and yesterday :S
R1CH
You've installed something that is interfering with D3D. Maybe some overlay, driver, FPS monitor, etc.
