OBS is crash, pls help my problem
This crash appears to have occured in the 'c:\windows\system32\nvwgf2um.dll' module.
Fault address: 685DC60D (c:\windows\system32\nvwgf2um.dll)
OBS version: Open Broadcaster Software v0.60b
CPU: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
Crashing thread stack trace:
0E4DEC58 685DC60D 0423C7C8 043C27C4 6A19D07C 00000000 nvwgf2um.dll!0x685dc60d
0E4DEC8C 686BE78A 0423C7C8 043C27C4 6A19D07C 0E4DED88 nvwgf2um.dll!0x686be78a
0E4DECBC 687EADA4 0423C7C8 05FE21DC 043C27C4 6A19D07C nvwgf2um.dll!0x687eada4
0E4DED50 687E3D81 0423C7C8 0E4DED88 05FE21DC 6A19D07C nvwgf2um.dll!0x687e3d81
0E4DED74 68641044 0423C7C8 0E4DEF0C 05FE21DC 6A19D07C nvwgf2um.dll!0x68641044
0E4DEDAC 60A6A0B0 0E4DEF0C 05FE21DC 6A19D07C 0E4DEDF0 nvumdshim.dll!0x60a6a0b0
0E4DEDC4 60A66F27 0069CF80 0E4DEF0C 05FE21DC 6A19D07C nvumdshim.dll!0x60a66f27
0E4DEDD8 60A73262 0E4DEF0C 05FE21DC 6A19D07C 0E4DEF38 nvumdshim.dll!0x60a73262
0E4DEDF8 60A5E337 042395D4 0E4DEF0C 05FE21DC 6A19D07C nvumdshim.dll!0x60a5e337
0E4DEE0C 6A1EA22A 05FE21BC 00000000 0E4DEFF8 840B2FD8 d3d11.dll!0x6a1ea22a
0E4DEF40 6A1BEC17 05FE2180 0E4DEFF8 6A19B910 05FE2130 d3d11.dll!0x6a1bec17
0E4DEF84 6A1BB399 05FE2180 05FE2144 05FE2100 6A19B910 d3d11.dll!0x6a1bb399
0E4DEFB8 6A1B239F 0069C56C 0E4DF354 05FE2100 05FE2130 d3d11.dll!0x6a1b239f
0E4DF294 6A1A250F 0069C52C 00000004 0E4DF354 0000001C d3d11.dll!0x6a1a250f
0E4DF2AC 6A1D4599 00000004 0E4DF354 0000001C 05FE2100 d3d11.dll!0x6a1d4599
0E4DF2D4 6A1D3D1E 05FE2100 6A19B910 05FE2118 840B3300 d3d11.dll!0x6a1d3d1e
0E4DF31C 6A1CD0EE 0E4DF470 0000001C 05FE2100 6A19B910 d3d11.dll!0x6a1cd0ee
0E4DF3AC 6A1A2682 0069C26C 00000004 0E4DF470 0000001C d3d11.dll!0x6a1a2682
0E4DF3C8 6A1DCD1B 05FE2100 0E4DF4A8 05FE2100 6A19D07C d3d11.dll!0x6a1dcd1b
0E4DF414 6A1DC975 0E4DF4A8 0069C240 05FE2100 6A19D07C d3d11.dll!0x6a1dc975
0E4DF45C 6A1DC24E 0069C240 00000004 0E4DF520 0000001C d3d11.dll!0x6a1dc24e
0E4DF4E0 6A1B9AC4 0E4DF590 00000001 840B35CC 0E4DF660 d3d11.dll!0x6a1b9ac4
0E4DF508 6A1A8C42 0069C56C 00000003 0E4DF590 00000001 d3d11.dll!0x6a1a8c42
0E4DF570 6A1DE5D9 00000000 060B4D38 0E4DF5A8 0E4DF5C0 d3d11.dll!0x6a1de5d9
0E4DF590 001BE626 000000A0 0000001B 0E4DF644 737C43D6 obs.exe!D3D10Texture::CreateFromSharedHandle+0x136
0E4DF604 001BC6B3 000000A0 0000001B 800014C0 023038C0 obs.exe!D3D10System::CreateTextureFromSharedHandle+0x13
0E4DF614 737C43D6 0E4DF660 02302560 00440000 023038C0 graphicscapture.dll!SharedTexCapture::Init+0x116
0E4DF64C 737C2D7E 02302560 00000000 49F6653B 0E4DF6B8 graphicscapture.dll!GraphicsCaptureSource::NewCapture+0x2ce
0E4DF690 737C36DD 3D23D70A 00000000 00000000 0E4DF9C8 graphicscapture.dll!GraphicsCaptureSource::Tick+0xad
0E4DF6A8 6DCC218F 3D23D70A 00000000 00000000 00000000 obsapi.dll!Scene::Tick+0x2f
0E4DF6BC 001DFAFB 74F6336A 00000000 0E4DFA18 771E9F72 obs.exe!OBS::MainCaptureLoop+0xa0b
0E4DF9D0 001DDDB5 00000000 0E4DFA18 771E9F72 00000000 obs.exe!OBS::MainCaptureThread+0x5
0E4DF9D4 74F6336A 00000000 784B6DE2 00000000 00000000 kernel32.dll!0x74f6336a
0E4DF9E0 771E9F72 001DDDB0 00000000 00000000 00000000 ntdll.dll!0x771e9f72
0E4DFA20 771E9F45 001DDDB0 00000000 00000000 00000000 ntdll.dll!0x771e9f45
A minidump was saved to C:\Users\Kuba\AppData\Roaming\OBS\crashDumps\OBSCrashDump2014-02-12_4.dmp.
List of loaded modules:
Base Address Module
