Bug Report OBS Crash, can no longer use OBS.
rex_rovaan
Been having this crash constantly. I can no longer record, or stream, with OBS.
After clicking "Preview Stream" or "Begin Streaming" the program looks like it begins streaming. However, the indicator in the bottom right corner remains grey, the FPS remains at 0. Upon attempting to click "Stop Preview" or "Stop Streaming" OBS becomes unresponsive, and then crashes.
I have uninstalled, reinstalled, updated all my drivers, used both x64 and x86 versions of the program, and basically have exhausted all solutions I have found upon querying Google.
This crash appears to have occured in the 'c:\windows\system32\kernelbase.dll' module.
**** UNHANDLED EXCEPTION: 80000003
Fault address: 768E8EF2 (c:\windows\system32\kernelbase.dll)
OBS version: Open Broadcaster Software v0.651b
CPU: Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
Crashing thread stack trace:
Stack  EIP  Arg0  Arg1  Arg2  Arg3  Address
003DF1F8 768E8EF2 000006D4 00007532 747CA420 02510800 kernelbase.dll!0x768e8ef2
003DF208 00168F9A 00000001 00000001 747CA420 02510800 obs.exe!OBS::Stop+0x19a
003DF250 0016238E 561D4D90 003DFB50 0015A6AC 00000001 obs.exe!OBS::~OBS+0x2e
003DF680 001622FB 00000001 001AC573 00000001 00000000 obs.exe!OBS::`vector deleting destructor'+0xb
003DF68C 0015A6AC 00110000 00000000 0077221D 00000001 obs.exe!WinMain+0x9bc
003DFB58 001AC67A FEC39000 74D27BE0 16755CC9 003DFBF8 obs.exe!__tmainCRTStartup+0xfd
003DFBA4 74D27C04 FEC39000 159E4021 00000000 00000000 kernel32.dll!0x74d27c04
003DFBB8 76FFB54F FFFFFFFF 76FE03FA 00000000 00000000 ntdll.dll!0x76ffb54f
003DFC00 76FFB51A 001AC573 FEC39000 00000000 00000000 ntdll.dll!0x76ffb51a
Video thread stack trace:
0FECE8DC 5899A7D4 029ACB28 5899A71E 0FECE8F8 5ADF116B nvumdshim.dll!0x5899a7d4
0FECE8E4 5ADF12D1 02A89070 00000000 FFFFFFFF 02A89070 igd10iumd32.dll!0x5adf12d1
0FECE8F8 5AA8AD45 02A89070 00000003 05627EC0 00000000 igd10iumd32.dll!0x5aa8ad45
0FECE928 5AA888B0 00000000 00000000 00000000 02A8D4C0 igd10iumd32.dll!0x5aa888b0
0FECE954 5AA8428D 02A89070 00000003 00000000 0FECE9E8 igd10iumd32.dll!0x5aa8428d
0FECE974 5ADFACA0 05627968 02A8D110 5ADE34D7 029ACB28 igd10iumd32.dll!0x5adfaca0
0FECE9BC 5ADFC073 0FECE9E8 029ACB28 029EA510 0FECEB2C igd10iumd32.dll!0x5adfc073
0FECE9D8 5899CA26 0FECEB2C 029EA510 0FECEC78 029AD31C nvumdshim.dll!0x5899ca26
0FECEA98 589A12BC 0FECEB2C 07C8403D 0001505F 00000010 nvumdshim.dll!0x589a12bc
0FECEAF0 6AE27AFB 0299F934 0FECEC70 00000001 056E48D8 d3d11.dll!0x6ae27afb
0FECEBB0 6137368D 0FECF460 00000000 00000000 00000000 dxgi.dll!0x6137368d
0FECF3A8 61380BAE 0FECF460 00000000 00000000 00000000 dxgi.dll!0x61380bae
0FECF420 613813F1 0562E360 00000000 00000000 0016BDF0 dxgi.dll!0x613813f1
0FECF4B4 0016EB09 74D27C04 00000000 74D27BE0 19A45F69 obs.exe!OBS::MainCaptureLoop+0x1649
0FECF800 0016BDF5 00000000 74D27BE0 19A45F69 0FECF858 obs.exe!OBS::MainCaptureThread+0x5
0FECF804 74D27C04 00000000 1A4F4381 00000000 00000000 kernel32.dll!0x74d27c04
0FECF818 76FFB54F FFFFFFFF 76FE03FA 00000000 00000000 ntdll.dll!0x76ffb54f
0FECF860 76FFB51A 0016BDF0 00000000 00000000 00000000 ntdll.dll!0x76ffb51a
A minidump was saved to C:\Users\Hunter\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-04-06_1.dmp.
List of loaded modules:
Base Address  Module
MOST RECENT LOG:
03:23:22: Open Broadcaster Software v0.651b - 32bit (´・ω・`)
03:23:22: -------------------------------
03:23:22: CPU Name: Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
03:23:22: CPU Speed: 2394MHz
03:23:22: Physical Memory:  4095MB Total, 4004MB Free
03:23:22: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
03:23:22: monitor 1: pos={0, 0}, size={1920, 1080}
03:23:22: monitor 2: pos={1920, 0}, size={1360, 768}
03:23:22: Windows Version: 6.2 Build 9200
03:23:22: Aero is Enabled
03:23:22: OBS Modules:
03:23:22: Base Address  Module
03:23:22: 00110000  OBS.exe
03:23:22: 561B0000  OBSApi.dll
03:23:22: 61460000  DShowPlugin.dll
03:23:22: 04B40000  GraphicsCapture.dll
03:23:22: 5E550000  NoiseGate.dll
03:23:22: 5E530000  PSVPlugin.dll
03:23:22: 5E510000  scenesw.dll
03:23:22: ------------------------------------------
03:23:22: Adapter 1
03:23:22:  Video Adapter: NVIDIA GeForce GTX 770M
03:23:22:  Video Adapter Dedicated Video Memory: 3138342912
03:23:22:  Video Adapter Shared System Memory: 1156558848
03:23:22:  Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
03:23:22:  Video Adapter Output 2: pos={1920, 0}, size={1360, 768}, attached=true
03:23:22: Adapter 2
03:23:22: =====Stream Start: 2015-04-06, 03:23:22===============================================
03:23:22:  Multithreaded optimizations: Off
03:23:22:  Base resolution: 1920x1080
03:23:22:  Output resolution: 852x480
03:23:22: Loading up D3D10 on NVIDIA GeForce GTX 770M (Adapter 1)...
03:23:23: ------------------------------------------
03:23:23: Audio Format: 48000 Hz
03:23:23: Audio Channels: 2 Ch
03:23:23: Playback device Default
03:23:23: Using desktop audio input: Speakers (Conexant SmartAudio HD)
03:23:23: Global Audio time adjust: 0
03:23:23: Using auxilary audio input: Microphone (Conexant SmartAudio HD)
03:23:23: Mic time offset: 0
03:23:23: Audio Encoding: AAC
03:23:23:  bitrate: 128
03:23:23: Using Monitor Capture
03:23:23: Scene buffering time set to 700
03:23:23: Video Encoding: x264
03:23:23:  fps: 30
03:23:23:  width: 852, height: 480
03:23:23:  preset: veryfast
03:23:23:  profile: high
03:23:23:  keyint: 250
03:23:23:  CBR: yes
03:23:23:  CFR: yes
03:23:23:  max bitrate: 1000
03:23:23:  buffer size: 1000
03:23:48: Total frames encoded: 0, total frames duplicated: 0 (0.00%)
03:24:18: WARNING: Forcibly terminating a thread after 30002 ms timeout!
Any help anybody could provide would be of great use.
  • OBSCrashDump2015-04-06_1.zip
R1CH
Your video drivers are crashing. Try updating them or use a desktop PC as laptop drivers are quite unstable.
