Bug Report OBS Crash (64 bit/ 32 bit)
A New Home
Hi All,
I'm getting Application errors from OBS Crashing when doing local records or streaming.
From the Windows Error Logs:
Faulting application OBS.exe, version 0.6.5.7, time stamp 0x565399c9, faulting module ntdll.dll, version 6.0.6002.19514, time stamp 0x561e783a, exception code 0xc0000005, fault offset 0x0000000000048c20, process id 0x26fc, application start time 0x01d12f5682b07dfa.
Fault bucket 108614374, type 28
Event Name: APPCRASH
Response: None
Cab Id: 120322965890
Problem signature:
P1: OBS.exe
P2: 0.6.5.7
P3: 565399c9
P4: ntdll.dll
P5: 6.0.6002.19514
P6: 561e783a
P7: c0000005
P8: 0000000000048c20
P9:
P10:
L:\Users\X\AppData\Local\temp\WER86BE.tmp.version.txt
L:\Users\X\AppData\Local\temp\WER9677.tmp.appcompat.txt
L:\Users\X\AppData\Local\temp\WER986C.tmp.mdmp
These files may be available here:
C:\Users\X\AppData\Local\Microsoft\Windows\WER\ReportArchive\Report26e3da49
Included OBS Log
This is where OBS Freezes and reports it has an error.
The system used to work fine on earlier versions of OBS.
OS: Windows Vista x64
Memory: 16 GB
GPU: 970 GTX
Nvidia Drivers are: 12/1/2015 (Version 359.06) WHQL
The Crash I am getting is consistently to do with the ntdll.dll file.
- I previously had no problems with OBS.
Any suggestions on how to fix this would be appreciated?
  • 2015-12-05-1214-37.log
